t6963c,lcd 由用过t6963c驱动lcd的吗?
我读状态位好像不怎么稳定
还有,怎么显示数据,才接触,高手请指点 答 1: re//240*64点阵屏,下面是显示“公司”的程序,俺从老程序中cut出来的,不知道管不管用,大虾见笑了,呵呵
//#include <reg52.h>
#define CMD XBYTE [0x9000]
#define DAT XBYTE [0x7000]
unsigned char code LMM[]={
/*-- 文字1: 公 --*/
0x00,0x00,0x04,0x40,0x06,0x40,0x04,0x40,0x08,0x20,0x08,0x10,0x10,0x18,0x22,0x0E,
0x43,0x04,0x02,0x00,0x04,0x20,0x08,0x10,0x11,0xF8,0x3F,0x18,0x10,0x10,0x00,0x00,
/*-- 文字2: 司 --*/
0x00,0x00,0x3F,0xFC,0x00,0x04,0x00,0x04,0x7F,0xE4,0x00,0x04,0x00,0x04,0x3F,0xC4,
0x20,0x44,0x20,0x44,0x3F,0xC4,0x20,0x44,0x20,0x04,0x00,0x14,0x00,0x08,0x00,0x00,};
/********* 手动写忙吗? *********/
void check()
unsigned char TEMP;
TEMP=0; while (TEMP != 0x03)
TEMP = CMD & 0x03;
/********** 自动写忙吗? *********/
void check1()
unsigned char temp;
temp=0;
while (temp!=0x08)
temp = CMD & 0x08;
/********* 初始化显示屏 *********/
void init_lcd()
unsigned int t1;
check();
CMD=0x0B2; /* DISABLE AUTO R/W */
check();
CMD=0x09C; /* TXT AND GRAPH SHARING MODEL */
check();
CMD=0x88; /* SELECT CGRAM ,"AND" LOGIC DISPLAY */
check();
DAT=0;
check();
DAT=0;
check();
CMD=0x40; /* TXT AREA START ADDRESS IS 0000H */
check();
DAT =30;
check();
DAT =0;
check();
CMD =0x41; /* TXT AREA 30 WORDS A ROW */
check();
DAT=0;
check();
DAT=8;
check();
CMD=0x42; /* GRAPH AREA START ADDRESS IS 800H */
check();
DAT =30;
check();
DAT =0;
check();
CMD =0x43; /* GRAH AREA 30 WORDS A ROW */
check();
DAT =0;
check();
DAT =0;
check();
CMD =0x24; /* ADDRESS POINTER IS 00H */
check();
DAT =0x1f;
check();
DAT =0;
check();
CMD =0x22; /* CGRAM FIRST ADDRESS IS 0x2000H */
//check();
//CMD =0x0A0; /* SELECT CURSOR SHAPE */
check();
DAT =0;
check();
DAT =0;
check();
CMD =0x24;
check();
CMD =0x0B0;
for(t1=0;t1<0xf800;t1++)
check1();
DAT=0;
check();
CMD = 0x0B2; /* DISABLE AUTO R/W */
/********* 汉字代码输入 **********/
void INPUT_CGRAM()
unsigned char i,j;
unsigned int t1;
check();
DAT = 0;
check();
DAT = 0xf8;
check();
CMD = 0x24;
check();
CMD = 0xB0;
t1=0;
for(i=0;i<2;i++)
for(j=0;j<16;j++)
check1();
DAT = LMM[j+j+t1];
for(j=0;j<16;j++)
check1();
DAT = LMM[j+j+1+t1];
t1=t1+32;
check();
CMD = 0x0B2;
void disp_company()
unsigned char i,k;
k=2;
check();
DAT=k;
check();
DAT=0;
check();
CMD=0x24;
check();
CMD=0xB0;
for(i=0;i<4;i++)
check1();
DAT=i+i;
check();
CMD=0xB2;
check();
DAT=k+30;
check();
DAT=0;
check();
CMD=0x24;
check();
CMD=0xB0;
for(i=0;i<4;i++)
check1();
DAT=i+i+1;
check();
CMD=0xB2;
void main()
EA=0;
init_lcd();
INPUT_CGRAM();
disp_company();
while(1)
} 答 2: 这是我的程序,怎么显示不了东西呢?//240*64点阵屏,下面是显示“公司”的程序,俺从老程序中cut出来的,不知道管不管用,大虾见笑了,呵呵
/*-- 文字1: 公 --*/
/*-- 文字2: 司 --*/
void check()
unsigned char TEMP;
TEMP = CMD & 0x03;
void check1()
unsigned char temp;
temp=0;
while (temp!=0x08)
temp = CMD & 0x08;
void init_lcd()
unsigned int t1;
check();
check();
check();
check();
DAT=0;
check();
DAT=0;
check();
check();
DAT =30;
check();
DAT =0;
check();
check();
DAT=0;
check();
DAT=8;
check();
check();
DAT =30;
check();
DAT =0;
check();
check();
DAT =0;
check();
DAT =0;
check();
check();
DAT =0x1f;
check();
DAT =0;
check();
//check();
check();
DAT =0;
check();
DAT =0;
check();
CMD =0x24;
check();
CMD =0x0B0;
check1();
DAT=0;
check();
void INPUT_CGRAM()
unsigned char i,j;
unsigned int t1;
check();
DAT = 0;
check();
DAT = 0xf8;
check();
CMD = 0x24;
check();
CMD = 0xB0;
t1=0;
for(i=0;i<2;i++)
for(j=0;j<16;j++)
check1();
DAT = LMM[j+j+t1];
for(j=0;j<16;j++)
check1();
t1=t1+32;
check();
CMD = 0x0B2;
void disp_company()
unsigned char i,k;
k=2;
check();
DAT=k;
check();
DAT=0;
check();
CMD=0x24;
check();
CMD=0xB0;
for(i=0;i<4;i++)
check1();
DAT=i+i;
check();
CMD=0xB2;
check();
DAT=k+30;
check();
DAT=0;
check();
CMD=0x24;
check();
CMD=0xB0;
for(i=0;i<4;i++)
check1();
DAT=i+i+1;
check();
CMD=0xB2;
void main()
EA=0;
init_lcd();
INPUT_CGRAM();
disp_company();
while(1)
答 3: re:re不会是头文件没定义的原因吧?考虑你可能使用自己的头文件,我把它屏蔽了,
如果编译没报错,请检查一下硬件连线是否正确,RST CS C/D都好好看一下,我的C/D接的是P2.7,另外如果用背光的话,注意调节负压,-7v左右足够。
祝你成功!
答 4: 我发错了,这是我的程序,请指教!#include <stdio.h>
#include <90s4414.h>
#include <delay.h>
char lcd_state=0;
void state01_check()
DDRC.0=1;//CD
PORTC.0=1;
DDRC.1=1;//CE
PORTC.1=0;
DDRD.6=1;//RD
PORTD.6=0;
DDRD.7=1;//WR
PORTD.7=1;
do
DDRA=0x00;
lcd_state=PINA;
while((lcd_state&0x03)!=3);
PORTD.6=1;
void send_data(char data)
state01_check();
DDRD.6=1;//RD
PORTD.6=1;
DDRC.0=1;//CD
PORTC.0=0;
DDRC.1=1;//CE
PORTC.1=0;
DDRA=0xFF;
PORTA=data;
DDRD.7=1;//WR
PORTD.7=0;
PORTD.7=1;//WR
PORTC.0=1;//CD
void cmnd_write(char cmnd)
state01_check();
DDRD.6=1;//RD
PORTD.6=1;
DDRC.0=1;//CD
PORTC.0=1;
DDRC.1=1;//CE
PORTC.1=0;
DDRA=0xFF;
PORTA=cmnd;
DDRD.7=1;//WR
PORTD.7=0;
PORTD.7=1;
PORTC.0=0;
void initLCD()
cmnd_write(0x0B2);
send_data(0x00);//text area addr
send_data(0x00);
cmnd_write(0x40);
send_data(0x20);//text area wide
send_data(0x00);
cmnd_write(0x41);
send_data(0x00);//graphic area addr
send_data(0x08);
cmnd_write(0x42);
send_data(0x20);//graphic area wide
send_data(0x00);
cmnd_write(0x43);
cmnd_write(0xA7);//cursor pattern
cmnd_write(0x80);//display mode
void main(void)
initLCD();
cmnd_write(0x9C);
send_data(0x00);
send_data(0x00);
cmnd_write(0x24);
send_data(0x21);
while(1)
/*-- 文字1: 公 --*/
/*-- 文字2: 司 --*/
void check()
unsigned char TEMP;
TEMP = CMD & 0x03;
void check1()
unsigned char temp;
temp=0;
while (temp!=0x08)
temp = CMD & 0x08;
void init_lcd()
unsigned int t1;
check();
check();
check();
check();
DAT=0;
check();
DAT=0;
check();
check();
DAT =30;
check();
DAT =0;
check();
check();
DAT=0;
check();
DAT=8;
check();
check();
DAT =30;
check();
DAT =0;
check();
check();
DAT =0;
check();
DAT =0;
check();
check();
DAT =0x1f;
check();
DAT =0;
check();
//check();
check();
DAT =0;
check();
DAT =0;
check();
CMD =0x24;
check();
CMD =0x0B0;
check1();
DAT=0;
check();
void INPUT_CGRAM()
unsigned char i,j;
unsigned int t1;
check();
DAT = 0;
check();
DAT = 0xf8;
check();
CMD = 0x24;
check();
CMD = 0xB0;
t1=0;
for(i=0;i<2;i++)
for(j=0;j<16;j++)
check1();
DAT = LMM[j+j+t1];
for(j=0;j<16;j++)
check1();
t1=t1+32;
check();
CMD = 0x0B2;
void disp_company()
unsigned char i,k;
k=2;
check();
DAT=k;
check();
DAT=0;
check();
CMD=0x24;
check();
CMD=0xB0;
for(i=0;i<4;i++)
check1();
DAT=i+i;
check();
CMD=0xB2;
check();
DAT=k+30;
check();
DAT=0;
check();
CMD=0x24;
check();
CMD=0xB0;
for(i=0;i<4;i++)
check1();
DAT=i+i+1;
check();
CMD=0xB2;
void main()
EA=0;
init_lcd();
INPUT_CGRAM();
disp_company();
while(1)
/*-- 文字1: 公 --*/
/*-- 文字2: 司 --*/
void check()
unsigned char TEMP;
TEMP = CMD & 0x03;
void check1()
unsigned char temp;
temp=0;
while (temp!=0x08)
temp = CMD & 0x08;
void init_lcd()
unsigned int t1;
check();
check();
check();
check();
DAT=0;
check();
DAT=0;
check();
check();
DAT =30;
check();
DAT =0;
check();
check();
DAT=0;
check();
DAT=8;
check();
check();
DAT =30;
check();
DAT =0;
check();
check();
DAT =0;
check();
DAT =0;
check();
check();
DAT =0x1f;
check();
DAT =0;
check();
//check();
check();
DAT =0;
check();
DAT =0;
check();
CMD =0x24;
check();
CMD =0x0B0;
check1();
DAT=0;
check();
void INPUT_CGRAM()
unsigned char i,j;
unsigned int t1;
check();
DAT = 0;
check();
DAT = 0xf8;
check();
CMD = 0x24;
check();
CMD = 0xB0;
t1=0;
for(i=0;i<2;i++)
for(j=0;j<16;j++)
check1();
DAT = LMM[j+j+t1];
for(j=0;j<16;j++)
check1();
t1=t1+32;
check();
CMD = 0x0B2;
void disp_company()
unsigned char i,k;
k=2;
check();
DAT=k;
check();
DAT=0;
check();
CMD=0x24;
check();
CMD=0xB0;
for(i=0;i<4;i++)
check1();
DAT=i+i;
check();
CMD=0xB2;
check();
DAT=k+30;
check();
DAT=0;
check();
CMD=0x24;
check();
CMD=0xB0;
for(i=0;i<4;i++)
check1();
DAT=i+i+1;
check();
CMD=0xB2;
void main()
EA=0;
init_lcd();
INPUT_CGRAM();
disp_company();
while(1)
祝你成功!
#include <delay.h>
char lcd_state=0;
DDRC.0=1;//CD
PORTC.0=1;
DDRC.1=1;//CE
PORTC.1=0;
DDRD.6=1;//RD
PORTD.6=0;
DDRD.7=1;//WR
PORTD.7=1;
do
DDRA=0x00;
lcd_state=PINA;
PORTD.6=1;
state01_check();
DDRD.6=1;//RD
PORTD.6=1;
DDRC.0=1;//CD
PORTC.0=0;
DDRC.1=1;//CE
PORTC.1=0;
DDRA=0xFF;
PORTA=data;
DDRD.7=1;//WR
PORTD.7=0;
PORTD.7=1;//WR
PORTC.0=1;//CD
state01_check();
DDRD.6=1;//RD
PORTD.6=1;
DDRC.0=1;//CD
PORTC.0=1;
DDRC.1=1;//CE
PORTC.1=0;
DDRA=0xFF;
PORTA=cmnd;
DDRD.7=1;//WR
PORTD.7=0;
PORTD.7=1;
PORTC.0=0;
void initLCD()
cmnd_write(0x0B2);
send_data(0x00);
cmnd_write(0x40);
send_data(0x00);
cmnd_write(0x41);
send_data(0x08);
cmnd_write(0x42);
send_data(0x00);
cmnd_write(0x43);
void main(void)
initLCD();
cmnd_write(0x9C);
send_data(0x00);
send_data(0x00);
cmnd_write(0x24);
send_data(0x21);
while(1)
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
