1.
中文名称:Mapinfo professional 8.0 SCP
版本:Release Build 18
发行时间:2005年
制作发行:MapInfo
地区:美国
语言:英语
简介:
已通过杀毒软件检测,卡巴50390,病毒库2005-12-07
已通过安装测试,测试平台:Windows Server2003 SP1
本资源发布仅为交流与学习,如果你下载后,觉得喜欢,请购买正版软件!
共享时间:每天0:00~23:00,共享服务器:R2
[img]http://img.verycd.com/posts/0512/post-266015-1133971174.jpg[/img]
[img]http://img.verycd.com/posts/0512/post-266015-1133970836.gif[/img]
原图:http://img.verycd.com/posts/0512/post-266015-1133970836.gif | 764x532
[img]http://extranet.mapinfo.com/products/mipro/v80_slp/images/header.gif[/img]
原图: http://extranet.mapinfo.com/products/mipro/v80_slp/images/header.gif | 707x150
Use MapInfo Professional to:
Create highly detailed maps to enhance presentations and aid in decision making
Reveal patterns and trends in your data that may otherwise be impossible to see in spreadsheets and charts
Perform sophisticated and extensive data analysis
Understand customer and marketplace demographics
Manage geographically based assets, such as stores, people and property
Plan logistics and prepare for emergency response
Increased Flexibility
Work with greater efficiency and higher quality even as demands increase. Version 8.0 helps you with:
New data creation and analytical capabilities, including stream digitizing, orthogonal polygon creation, bivariate thematic analysis and an enhanced distance calculator
Increased settings in geographical object support — now objects can store more than 134 million nodes per single polyline orpolygon object
New legend size options and cartographic legend window formatting
Greater Collaboration
Increase sharing of information and minimize translation costs through industry and interoperability standards endorsed and promoted by MapInfo.
Version 8.0 helps you:
Share your work with others through enhanced MapInfo Workspace and extended OGC support
With new and updated support for both raster and vector formats, including the latest DWG/DXF and DGN formats, shape files with M and Z values, ASRP along with export to GIF, TIFF, LZW and more
More Value
Get more out of your investment via IT-friendly capabilities, additional free data and MapBasic® support:
Install on a central computer and use remotely via MS Terminal Services and CITRIX
Get multiple-user support through silent and unattended installs
Enjoy support for Oracle Workspace Manager including data version
MapInfo Professional 是一套业界中领先的Windows平台的地图化解决方案。
使用MapInfo Professional,提供地图绘制、编辑、地理分析、网格影像等功能。
利用MapInfo提供的最佳决策支持系统,商业分析专家和GIS专家可以方便的将数据和地理信息的关系直观的展现。它复杂而深层次的可视化地理分析功能可以帮助用户在数据库中不同的数据之间建立关联,在同一个环境下显示,并迅速揭示数据之间的关系以及易被忽视的数据模式,从而作出快速有效的决策,提高运作效率,加强竞争能力。
MapInfo Professionala发行最新的中文版本7.0,为新老用户提供了更强大的数据维护、可视化、数据展现、输出能力和更好的可用性。本文介绍了MapInfo Professional 7.0中文版的基本情况,其中有些特性是广大用户盼望已久的。
功能特色
MapInfo Professional提供一整套功能强大的工具来进行复杂的商业地图化、数据可视化和GIS功能。通过MapInfo Professional可连接本地及服务器端的数据库,创建地图和图表以揭示数据行列背后的真正含义。也可以定制MapInfo Professional以满足用户的特定需要。事实上,电讯、民用、零售和政府等几乎所有领域都将MapInfo Professional应用到市场分析、选址、客户服务、应急等各方面。MapInfo Professional功能强大、简单易用、物超所值、是世界上领先的地图化解决方案。
数据分析
采用几种方式加工和显示数据以便更好地理解数据库记录背后的含义:
◆ 图层-将不同的数据迭加在同一地图上,从而揭示数据之间的地理关系。
◆ 专题图及其模板-根据数据的数值为地图渲染,以帮助用户更容易地可视化模式和趋势。可以从上百种颜色、符号和线型中进行选择,从而进一步区分数据。
◆ 连续的专题渲染-对于数据集提供连续的彩色可视化以产生易于理解的地图。也可以存储常用的模板以便于将来的引用和修改。
◆ 栅格图象持-能使用栅格图象,如扫描的纸张地图、卫星地图、照片、标志符号,以提供详细内容的地图图层。
◆ 将数据与地图建立关联-只需单击地图上的某个点,就可以浏览与该点相关的信息,如名称、地址和账目历史等。
◆ 专题和制图图例-允许地理图层的样式信息可视化表示,提供增强的注释能力和更高质量的地图
◆ 链接视图-可以同时以三种方式浏览和编辑数据-行列方式、统计图和地图。
◆ 地理分析
◆ 使用MapInfo Professional,用户可以进行功能强大的地理搜索和查询,例如:
◆ 创建和存储查询以便于访问和集成来自多个表中的数据。经常使用的查询只需写一次,便可分发到其它地方使用。
◆ 使用缓冲区和区域选择工具可进行详细的地理搜索。
◆ 集成地理运算符到数据库查询过程中(包含、相交、全包含等)。
◆ 可进行复杂的重分区操作,以便平衡区域范围、测试排列单元和发现如何改进区域划分的合理性(院校区、选举区、开发区等)。
◆ 通过多边迭加、合并或分割创建新的地图对象,可在这些新创建的区域中进行数据操作。
◆ 表现方式:增强了地图的表现方式。可把地图拖放到Microsoft Word、Excel、PowerPoint和 CoreIDRAW TM等其它应用程序中或把地图直接输出到Adobe PhotoShop中。使用来自Seagate Crystal Reports的内置报表书写器可提供可视化分析的其它支持。
数据管理和访问
◆ 对于希望给单个用户或整个部门提供强大的数据可视化和分析功能的机构来说,MapInfo Professional是最理想的地图化解决方案。
◆ 通用翻译器-允许MapInfo Professional和其它地图化环境间双向转换数据,包括AutoCAD、ESRI和Intergraph/Bentley。可以转换的文件格式有DOG、DGN、Shape和EOO。
◆ 实时ODBC或数据源的OCI访问-可直接访问和更新数据源而不需要下载大文件。而对于本地存储的数据类型可提供直接读/写功能,如dBASE、Microsoft Access、Microsoft Excel、Lotus1-2-3和ASCII。也提供对于远程数据库的实时访问,如Oracle8i、IBM DB2、Informix、SQL Server及其它支持ODBC的数据。
◆ 复杂空间对象的服务器端存储和管理-适用于Oracle8i、IBM DB2 Extender和Informix Universal Server。
◆ 内置冲突管理-当多个用户向服务器写入数据时帮助协调数据之间的冲突。
数据
◆ 与MapInfo Professional软件同时提供了一系列全球范围内的数据集,包括:演示图片、商业统计、地图点和边界,如欧洲、大洋州、中国、日本等的州和省、邮政编码、县、主要高速公路和城市、同时也提供满足每一种商业地图化需求的全方位的附加数据产品。
物超所值
◆ MapInfo Professional可嵌入已存在的应用系统内或完整地集成到商业系统中,从而创建出用户定制的解决方案。目前还没有其它的地图化软件可为开发者提供这样的灵活性。
◆ 集成的地图化-OLE Automation技术使开发者能够将MapInfo Professional集成到普通编程语言开发的应用系统中,如VisualBasic、PowerBuilder和C++。
◆ MapInfo MapBasic-一种强健的地图化编程语言(单独销售),可创建特定应用的用户界面,添加菜单和选项,增强特性和功能,实现过程的自动调用和把MapInfo集成到其它应用中。
◆ 动态图层- MapBasic编程人员使用动态图层功能,可以几乎同时对数据进行实时显示,例如,实时显示由GPS接口接收的数据。
GPS连接能力
◆ 直接从GPS设备获取坐标信息并动态地在地图上显示其位置。
运行平台
◆ 可运行于Microsoft Windows 2000、98、95和Windows NT4.0版。
其它标准特性
◆ 步步深入的对话框结构、增强的绘图工具以及自动/手动添加地图标注。
◆ 对象的缓冲区分析和先进的地理编码功能。
◆地理选择、搜索和查找。
◆ 有关表达式地理扩展的完全SQL查询能力。
◆ 将纸张地图数字化用以创建矢量地图。
◆ 可将地图拖放到其它应用程序中。
◆ 创建用户定制解决方案或将地图化功能集成到其它应用中。
2.
《中文版》(MapInfo Professional 7.0 SCP)
中文名称:中文版
英文名称:MapInfo Professional 7.0 SCP
发行时间:2003年
制作发行:MapInfo
简介:
之前lovesick发布过英文版本,现在这个是中文版本.在网上还是比较难找的
7.8是英文版本
之前lovesick发布过英文版本,现在这个是中文版本.在网上还是比较难找的 7.8是英文版本 MapInfo Professional 是一套业界中领先的Windows平台的地图化解决方案。 使用MapInfo Professional,提供地图绘制、编辑、地理分析、网格影像等功能。 利用MapInfo提供的最佳决策支持系统,商业分析专家和GIS专家可以方便的将数据和地理信息的关系直观的展现。它复杂而深层次的可视化地理分析功能可以帮助用户在数据库中不同的数据之间建立关联,在同一个环境下显示,并迅速揭示数据之间的关系以及易被忽视的数据模式,从而作出快速有效的决策,提高运作效率,加强竞……
[img]http://www.mapinfo.com.cn/static/files/graphic/1095573639592/home-main-banner-cn.gif[/img]
功能特色
数据分析
数据管理和访问
数据
[url=http://end.etowns.org/t/mapinfo.torrent]※快速下载※[/url]
[url=http://bgo.darktech.org/t/mapinfo.torrent]※快速下载※[/url]
[url=http://fbns.dvrdns.org/t/mapinfo.torrent]※快速下载※[/url]
