电子产品世界 » 论坛首页 » 综合技术 » 电源与模拟 » 液晶专业术语
液晶专业术语
2007-08-29 07:09:39     打赏
ASIC: Application Specific Integrated Circuit(特殊应用积体电路)
ASC(Auto-Sizing and Centering,自动调效屏幕尺寸和中心位置)
ASC(Anti Static Coatings,防静电涂层)
AGAS(Anti Glare Anti Static Coatings,防强光、防静电涂层)
BLA: Bearn Landing Area(电子束落区)
BMC(Black Matrix Screen,超黑矩阵屏幕)
CRC: Cyclical Redundancy Check(循环冗余检查)
CRT(Cathode Ray Tube,阴极射线管)
DDC:Display Data Channel,显示数据通道
DEC(Direct Etching Coatings,表面蚀刻涂层)
DFL(Dynamic Focus Lens,动态聚焦)
DFS(Digital Flex Scan,数字伸缩扫描)
DIC: Digital Image Control(数字图像控制)
Digital Multiscan II(数字式智能多频追踪)
DLP(digital Light Processing,数字光处理)
DOSD: Digital On Screen Display(同屏数字化显示)
DPMS(Display Power Management Signalling,显示能源管理信号)
Dot Pitch(点距)
DQL(Dynamic Quadrapole Lens,动态四极镜)
DSP(Digital Signal Processing,数字信号处理)
EFEAL(Extended Field Elliptical Aperture Lens,可扩展扫描椭圆孔镜头)
FRC: Frame Rate Control(帧比率控制)
HVD(High Voltage Differential,高分差动)
LCD(liquid crystal display,液晶显示屏)
LCOS: Liquid Crystal On Silicon(硅上液晶)
LED(light emitting diode,光学二级管)
L-SAGIC(Low Power-Small Aperture G1 wiht Impregnated Cathode,低电压光圈阴极管)
LVD(Low Voltage Differential,低分差动)
LVDS: Low Voltage Differential Signal(低电压差动信号)
MALS(Multi Astigmatism Lens System,多重散光聚焦系统)
MDA(Monochrome Adapter,单色设备)
MS: Magnetic Sensors(磁场感应器)
Porous Tungsten(活性钨)
RSDS: Reduced Swing Differential Signal(小幅度摆动差动信号)
SC(Screen Coatings,屏幕涂层)
Single Ended(单终结)
Shadow Mask(阴罩式)
TDT(Timeing Detection Table,数据测定表)
TICRG: Tungsten Impregnated Cathode Ray Gun(钨传输阴级射线枪)
TFT(thin film transistor,薄膜晶体管)
UCC(Ultra Clear Coatings,超清晰涂层)
VAGP: Variable Aperature Grille Pitch(可变间距光栅)
VBI: Vertical Blanking Interval(垂直空白间隙)
VDT(Video Display Terminals,视频显示终端)
VRR: Vertical Refresh Rate(垂直扫描频率)
LCD     Liquid Crystal Display    液晶显示
LCM     Liquid Crystal Module     液晶模块
TN      Twisted Nematic           扭曲向列。液晶分子的扭曲取向偏转90°
STN     Super Twisted Nematic     超级扭曲向列。约180~270°扭曲向列
FSTN    Formulated Super Twisted Nematic    格式化超级扭曲向列。一层光程补偿片加于STN,用于单色显示
TFT    Thin Film Transistor       薄膜晶体管
Backlight                背光 源
Inverter                   逆变器
OSD     On Screen Display         在屏上显示
DVI     Digital Visual Interface (VGA)数字接口
TMDS    Transition Minimized Differential Signaling
LVDS    Low Voltage Differential Signaling    低压差分信号
Panelink
IC     Integrate Circuit          集成电路
TCP    Tape Carrier Package       柔性线路板
COB    Chip On Board   通过邦定将IC裸片固定于印刷线路板上
COF    Chip On FPC  将IC固定于柔性线路板 上
COG    Chip On Glass  将芯片固定于玻璃上
Duty     —     占空比,高出点亮的阀值电压的部分在一个周期中所占的比率
LED     Light Emitting Diode  发光二极管
EL     Electro Luminescence  电致发光。EL层由高分子量薄片构成
CCFL(CCFT)    Cold Cathode Fluorescent Light/Tube    冷阴极荧光灯
PDP  Plasma Display Panel    等离子显示屏
CRT    Cathode Radial Tube    阴极射线管
VGA    Video Graphic Array    视频图形阵列
PCB    Printed Circuit Board    印刷电路板
Composite video   —  复合视频
S-video   —  S端子,与复合视频信号比,将对比和颜色分离传输
NTSC    National Television Systems Committee  NTSC制式,全国电视系统委员会制式
PAL     Phase Alternating Line  PAL制式(逐行倒相制式)
SECAM    SEquential Couleur Avec Memoire  SECAM制式(顺序与存储彩色电视系统)
VOD     Video On Demand 视频点播
DPI    Dot Per Inch    点每英寸
HSYNC   行同步信號
VSYNC   場同步信號
关键词: 液晶     专业     术语
