共1条
VT100终端编码
ASCII Character Set (Nonprinting)
7 BEL (Bell)
8 BS (Backspace)
9 HT (Horizontal tab)
10 LF (Linefeed)
11 VT (Vertical tab)
12 NP (New Page or Formfeed (FF))
13 CR (Carriage Return)
27 ESC (Escape)
127 DEL (Delete)
VT220 user defined graphics is at: http://kipper.york.ac.uk/vt220udg.html
VT404 Control Characters
Note: The "^" character signifies holding down the control key. For ^G
this is the same as sending 0x8 (a G with bit 7,8 set to zero)
Bell - ^G
Back Space - ^H
Line Feed - ^J
Reverse Line Feed - ^Z
Cursor Return - ^M
Cursor Up - ^Z
Cursor Down - ^J
Cursor Right - ^U
Cursor Left - ^H
Cursor Home - ^Y
Home and Clear - ^X
Clear to End of Line - ^V
Clear to End of Screen - ^W
Read Cursor Address - ^-
Read Character at Cursor - ^N J
Address Lead In - ^P
Address Order Row Column
Type of Addressing Bin.Bin.
Cursor On - ^N N
Cursor Off - ^N O
VT100 Terminal Codes
All sequences must follow the escape character immediately and all cases must be as shown.
Moving the Cursor
n,r,c are numbers.
[nA - Up, no scroll.
[nB - Down, no scroll.
[nC - Right n columns.
[nD - Left n columns.
[nE - CR and down, no scroll.
[nF - CR and up, no scroll.
[nG - CR
[r;cH - Move to row r, column c.
[nI - Tab
[nL - Inserts a blank line at cursor.
[n` - Moves cursor to column n.
D - Down, scroll in region.
E - CR and cursor down (with scroll)
M - Up, scroll in region (see later).
7 - Save position and attributes.
8 - Restore position and attributes.
Display Characteristics
[0m - Normal (default).
[1m - Bold.
[2m - Dim mode
[4m - Underline.
[5m - Blinking.
[7m - Reverse video.
[8m - Invisible mode.
#3 - Double height, double width (top).
#4 - Double height, double width (bottom).
#: - Double height, single width (top).
#; - Double height, single width (bottom).
#5 - Single width (default).
#6 - Double width.
Erasing
[0K - From cursor to end of line.
[1K - From beginning of line to cursor.
[2K - Entire line.
[0J - From cursor to bottom of screen.
[1J - From top of screen to cursor.
[2J - Entire screen.
[M - Removes the line that the cursor is on.
Character Sets
(B - US (default).
(A - UK (shift 3 = pound).
(0 - Line graphics.
(1 - Other graphics.
(S - User defined graphics.
n - First half of char. set to same as second.
N - Same as n but for next char only.
P1;n;1;5{S - Starts definition of UDGs at character code n+32.
\ - Ends definition of UDGs.
Scrolling regions
t,b are numbers.
[t;br - define scrolling region.
[?6h - cursor position 0;0 is upper left of region.
[?6l - cursor position 0;0 is upper left of screen. (Default)
Terminal Operations
c - Resets terminal.
[3h - Display controls mode.
[30h - Invisible screen.
[30l - Visible screen.
[?1h - Application keypad.
[?1l - Normal keypad.
[?2l - VT52 mode.
[?3h - 132 Columns.
[?3l - 80 Columns.
[?4h - Smooth-4 scroll.
[?4l - Jump scroll.
[?5h - Light screen.
[?5l - Dark screen.
[?25l - Cursor off.
[?25h - Cursor on.
关键词: VT100 终端 编码
共1条
| 2026年“我要开发板活动”第三季,开始了! | |
| PTC与NTC功能常规对比被打赏¥14元 | |
| 【分享开发笔记,赚取电动螺丝刀】关于3pin锂电池接口的介绍/使用被打赏¥16元 | |
