- 杂志
 搜 索:
 论坛 » 无线技术 » Avago ALM-42316匹配功率放大方案
广告招商
版主: 暂无版主
 发表新贴
 发表回复
 Avago ALM-42316匹配功率放大方案  发表于 2008-07-16 23:01:10 [您是本帖的第109位阅读者]     [1楼]
呢称:fulingqi
加我为好友
Avago公司的ALM-42316是全匹配功率放大模块,具有高度线性和低电压特性,工作频率在3.3-3.8GHz. ALM-42316是3级功率放大器,增益30dB,3.3V电源时的效率达14.5%, P1dB为30.5dBm,可广泛应用在IEEE 802.16移动端和固定端的高线性放大器和WLL放大器.本文介绍了ALM-42316的主要性能和技术指标, 内部电路图, 应用电路图及其元件布局和所用材料清单(BOM).
Avago Technologies’ ALM-42316 is a fully-matched Power amplifier module for use in the (3.3-3.8)GHz band. High linear output power at 3.3V is achieved through the use of Avago Technologies’ proprietary 0.25um GaAs Enhancement-mode pHEMT process. It is housed in a miniature 5.0 x 5.0 x 1.1mm MCOB module. It includes shutdown and
switchable gain functions. A detector is also included onchip. The compact footprint and low profile coupled with high gain and high efficiency make the ALM-42316 an ideal choice as a power amplifier for IEEE 802.16 (Wimax) and WLL applications.
主要特性:
High Efficiency of 14.5% at low 3.3V supply voltage
High gain: 30dB
High linearity performance: 23dBm at 2.5% EVM (64 QAM   FEC rate OFDMA).
Broadband Fully-matched 50 Ohm input and output impedances
45dBc 2nd harmonic attenuation
Built-in detector and shutdown switches
Switchable gain : 18 dB attenuation using one single CMOS compatible switch pin
GaAs E-pHEMT Technology
Low cost small package size: 5.0 x 5.0 x 1.1 mm3
Useable at 5V supplies for higher output power
技术指标:
3.5GHz; 3.3V, Iqtotal=240 mA (typ)
30 dB Gain
23dBm linear Pout (2.5% EVM, 64QAM OFDMA)
24.5dBm linear Pout (2.5% EVM, 64QAM OFDMA) @ Vdd=5V
P1dB : 30.5dBm
Detector range : 10dB (0.3V – 2.0V)
18 dB switchable gain attenuation
Shutdown current : < 20uA
应用:
High linearity amplifier for IEEE 802.16 mobile and fixed terminal amplifier
WLL amplifier
图1. ALM-42316内部电路图
图2. ALM-42316应用电路图
图3. ALM-42316演示板元件布局图
表1.演示板材料清单(B)M):
共1条 1/1 1
   快速回复主题
  用户名 : 匿名不能发帖!请先 [ 登陆 ]
  标 题:
  内 容 :
EEPW元器件搜索  强力提供
关于我们 | 广告服务 | 企业会员服务 | 新手上路 | 联系我们 | 友情链接
Copyright ©2002 ELECTRONIC ENGINEERING & PRODUCT WORLD. All rights reserved.
京ICP备060382号
