电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 如何设置S3C6410开发板telnet Linux主机
2011-02-13 11:42:38     打赏
//平台:友坚恒天UT-S3C6410开发板
1.
关于telnet命令的相关信息
[root@urbetter /]# telnet --help
BusyBox v1.13.3 (2009-03-25 15:48:45 CST) multi-call binary
Usage: telnet [-a] [-l USER] HOST [PORT]
Connect to telnet server
Options:
        -a      Automatic login with $USER variable
        -l USER Automatic login as USER
2.开发板telnet登录到其他提供了telnet服务器的主机
---确认开发板的ip地址,确认开发板能连接Internet
   ifconfig
   ping 内网的ip     ping 外网的ip
---设置路由iproute add default gw 192.168.1.1
---登录:telnet 202.112.7.137
3.开发板设置好网络,登录Internet
---设置网关:route add default gw 192.168.1.1(根据实际情况设定)
---确认连通Internet:ping 202.112.17.137
---设置域名解析服务器:
   查看你pc机上的DNS服务器的ip地址 202.96.128.96
   vim /etc/resolv.conf  添加 nameserver 202.96.128.96
   或者rm /etc/resolv.conf ;touch /etc/resolv.conf;
       echo nameserver 202.96.128.96 >> /etc/resolv.conf
4.开发板登录Linux主机
4.1Linux主机安装telnet服务
   sudo apt-get install xinetd telnetd
   修改配置
  sudo vi /etc/inetd.conf并加入以下一行
   telnet stream tcp nowait telnetd /usr/sbin/tcpd  /usr/sbin/in.telnetd
   4.2sudo vi /etc/xinetd.conf并加入以下内容:
# Simple configuration file for xinetd
# Some defaults, and include /etc/xinetd.d/
defaults
# Please note that you need a log_type line to be able to use log_on_success
# and log_on_failure. The default is the following :
# log_type = SYSLOG daemon info
instances = 60
log_type = SYSLOG authpriv
log_on_success = HOST PID
log_on_failure = HOST
cps = 25 30
includedir /etc/xinetd.d
4.3sudo vi /etc/xinetd.d/telnet并加入以下内容:
# default: on
# description: The telnet server serves telnet sessions; it uses
# unencrypted username/password pairs for authentication.
service telnet
disable = no
flags = REUSE
socket_type = stream
wait = no
user = root
server = /usr/sbin/in.telnetd
log_on_failure += USERID
5. 重启机器或重启网络服务sudo /etc/init.d/xinetd restart
6. 使用TELNET客户端远程登录;
   ifconfig -a   显示本机地址。
来源:友坚恒天技术中心http://www.urbetter.com/index.asp
关键词: 如何     设置     S3C6410     开发     telnet     L
