电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 乐高4种马达的技术参数(英文)
乐高4种马达的技术参数(英文)
2011-03-15 14:34:06     打赏
乐高4种马达的技术参数(英文)
写于: 星期五 14 三月 @ 19:35:38
乐高(LEGO)机器人乐高一共生产了4种马达的技术参数,这篇文章详细介绍了这些马达的技术参数,了解这些特征,才能更好地利用这些马达。
    Lego 9V Technic Motors compared characteristics
    The roster
    Electric Technic Motor 9V
    Lugnet Partsref 2838c01, Peeron 2838c01, Lego 74569
    The older 9V Technic motor (1990). Ungeared, it has a high rotation speed and low torque, so for most applications it requires an external gear reduction.
    Electric Technic Micromotor
    Lugnet Partsref 2986, Peeron 2986, Lego 70823
    Appeared in 1993, this small, light weight motor turns slowly and offer low torque - but respectable torque for its size. Must be used with pulley and generally top and base.
    Electric Technic Mini-Motor 9v
    Lugnet Partsref 71427c01, Peeron 71427c01, Lego 71427
    Since 1997, this motor replaces 2838. Geared down and quite efficient, this is the motor of choice for most applications.
    Lego 43362
    In 2002, Lego replaced 71427 motor with a new type, 43362. Externally almost identical, its internal structure is very different. Performances are almost as good, and its weight is much lower.
    Weight
    2838
    2986
    71427
    43362
    48g
    10g
    42g
    28g
    Supposed to be equivalent to 71427, 43362 motor is 30% lighter. This is generally an advantage, except when the motor is used as a counterweight, or to balance the structure, for example in COG-shifting walkers.
    No-load characteristics
    Test conditions: motor is powered by a variable, regulated power supply. An ammeter measures current flowing through the motor, a voltmeter monitors tension across. The rotation speed is measured by a RCX equipped with a light sensor, looking at an half-white/half black cylinder.
    9 V supply
    2838
    2986
    71427
    43362
    Rotation speed
    (rotations per minute)
    4100 rpm
    35 rpm
    360 rpm
    340 rpm
    No-load current
    35 mA
    6 mA
    3.5 mA
    9 mA
    43362 has a higher no-load current than 71427, probably caused by higher internal friction.
    As is usual for DC motors, rotation speed is proportionnal to voltage applied to them, this can be seen on graphs below. No-load current depends little on voltage.
    Stalled characteristics
    Stalled current consumption is simply measured with motor axle shaft locked by hand. Stalled torque is established from the maximum weight that can be lifted by the machine described below. Note that stalled torque measure is VERY imprecise.
    9 V supply
    2838
    2986
    71427
    43362
    Stalled torque
    0.85 N.cm
    1.6 N.cm
    6 N.cm
    5.5 N.cm
    Stalled current
    700 mA
    80 mA
    360 mA
    340 mA
    Take care to avoid extended period stall condition, as power dissipated in motor case is quite high (6 Watts for 2838, 3 W for 71427) will cause a rapid temperature rise. Note that 43362 motor, equipped with a thermistor, should be protected against frying (not tested though !!!)
    Loaded characteristics
    Here is the setup used to measure motors under load. Electrical power is measured with voltmeter and ammeter. Mechanical power delivered by the motor is evaluated from the time used to lift the weight by some height (5 cylinder turns - the first two turns are not counted to eliminate initial acceleration). Torque applied is obtained from weight and cylinder radius.
    Cylinder is directly placed on motor axle shaft, except for 2838 motor where a 1/5 gear reduction was used. Additionnal friction introduced may have somewhat impacted 2838 efficiency, but anyway this gearing is necessary for most applications. Torque displayed for this motor corrects gear reduction.
    2838
    Torque
    Rotation
    speed
    Current
    Mechanical
    power
    Electrical
    power
    Efficiency
    6 V
    0.45 N.cm
    580 rpm
    0.32 A
    0.27 W
    1.9 W
    14 %
    7 V
    0.45 N.cm
    1000 rpm
    0.32 A
    0.46 W
    2.3 W
    20 %
    9 V
    0.45 N.cm
    2000 rpm
    0.32 A
    0.9 W
    3 W
    31 %
    12 V
    0.45 N.cm
    3300 rpm
    0.33 A
    1.5 W
    4 W
    39 %
    71427
    Torque
    Rotation
    speed
    Current
    Mechanical
    power
    Electrical
    power
    Efficiency
    4.5 V
    2.25 N.cm
    57 rpm
    0.12 A
    0.13 W
    0.54 W
    24 %
    7 V
    2.25 N.cm
    160 rpm
    0.12 A
    0.38 W
    0.85 W
    45 %
    9 V
    2.25 N.cm
    250 rpm
    0.12 A
    0.58 W
    1.1 W
    54 %
    12 V
    2.25 N.cm
    375 rpm
    0.12 A
    0.88W
    1.5 W
    61 %
    43362
    Torque
    Rotation
    speed
    Current
    Mechanical
    power
    Electrical
    power
    Efficiency
    4.5 V
    2.25 N.cm
    50 rpm
    0.12 A
    0.12 W
    0.54 W
    22 %
    7 V
    2.25 N.cm
    140 rpm
    0.12 A
    0.33 W
    0.85 W
    39 %
    9 V
    2.25 N.cm
    219 rpm
    0.12 A
    0.51 W
    1.1 W
    47 %
    12 V
    2.25 N.cm
    333 rpm
    0.12 A
    0.77W
    1.5 W
    54 %
    2986
    Torque
    Rotation
    speed
    Current
    Mechanical
    power
    Electrical
    power
    Efficiency
    9 V
    1.28 N.cm
    16 rpm
    0.04 A
    0.021 W
    0.36 W
    16 %
    12 V
    1.28 N.cm
    28 rpm
    0.04 A
    0.038W
    0.48 W
    28 %
    The speed of 43362 motor is about 12 % lower than speed of 71427. Though this is in the range of variations measured by Steve Baker among a bunch of nine 71427 motors, my measures on three 71427 and two 43362 showed the 12 % difference between the two groups.
    Speed and current vs. torque
    Conclusion
    Each of these motors has unique characteristics which makes it more or less suitable for different applications.
    • Micromotor 2986 is at its best when space or weight is at a premium. But its mechanical power is quite low.
    • Technic motor 2838 is a real power hog, with poor efficiency, but it can deliver 30% more power than Minimotor.
    • Minimotor 71427 is probably the best performer of the pack overall.
    • The new 43362 is roughly equivalent to 71427, with slightly degraded performances. But its light weight can be a boon for many uses.
    Caution ! Though I tested motors with a 12V supply,
    I can't guarantee that they bear the extra load for extended time period.
    Use that at your own risks !
关键词: 乐高     马达     技术     参数     英文     motor     spee
