这是参考Altera官方的一个声明,链接http://www.altera.com/download/drivers/dri-bb-vista32.html,在Win7下测试正常。
Driver Installation- From the Start menu, choose Run.
- In the Open field, type cmd and then click OK. The command prompt window appears.
- To install the Altera ByteBlaster driver with the BBLPT utility, type the following command at the command prompt:
<Quartus II Installation Path>\bin\bblpt /i ↵ - When the ByteBlaster Device Driver Installation window appears, click OK.
- You may now connect the Altera ByteBlaster download cable to the PC. Complete the installation by setting up programming hardware:
- To remove the Altera ByteBlaster driver with the BBLPT utility, type the following command at the command prompt:
<Quartus II Installation Path>\bin\bblpt /r ↵ - When the ByteBlaster Device Driver Installation window appears, click OK.
