电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » Win7下Quartus 11安装ByteBlaster II驱动的方法
2011-08-15 12:42:20     打赏
这是参考Altera官方的一个声明,链接http://www.altera.com/download/drivers/dri-bb-vista32.html,在Win7下测试正常。
Driver Installation
  1. From the Start menu, choose Run.
  2. In the Open field, type cmd and then click OK. The command prompt window appears.
  3. To install the Altera ByteBlaster driver with the BBLPT utility, type the following command at the command prompt:
    <Quartus II Installation Path>\bin\bblpt /i ↵
  4. When the ByteBlaster Device Driver Installation window appears, click OK.
  5. You may now connect the Altera ByteBlaster download cable to the PC. Complete the installation by setting up programming hardware:
  6. To remove the Altera ByteBlaster driver with the BBLPT utility, type the following command at the command prompt:
    <Quartus II Installation Path>\bin\bblpt /r ↵
  7. When the ByteBlaster Device Driver Installation window appears, click OK.
关键词: Quartus     安装     ByteBlaster     驱动
2011-08-17 09:48:30     打赏
是啊,为了在win7上把要用的软件环境建立起来,真是不容易啊。 软件要用最新版的才行,驱动要用各种迂回方式安装。有些老的软件直接不能用。 哈哈,个人感觉win7用起来比win xp更方便,尤其是win7的文件管理,非常人性化。
