共7条
开始
#include "include/1602.h"
#include < AT89X52.H >
#include < intrins.h >
#define delayNOP() ; {_nop_() ;_nop_() ;_nop_() ;_nop_() ;} ;
sbit LCD_RS = P2^4 ;
sbit LCD_RW = P2^5 ;
sbit LCD_EN = P2^6 ;
U_8b code MyDef[8] = {0x0C,0x12,0x12,0x0C,0x00,0x00,0x00,0x00};
//P0 为LCD数据口
/*检查LCD忙状态 */
/*lcd_busy为1时,忙,等待。lcd-busy为0时,闲,可写指令与数据。 */
bit LCD_Busy()
bit result ;
LCD_RS = 0 ;
LCD_RW = 1 ;
LCD_EN = 1 ;
delayNOP() ;
result = (bit)(P0&0x80) ;
LCD_EN = 0 ;
return(result) ;
void LCD_CMD(U_8b cmd)
while(LCD_Busy()) ;
LCD_RS = 0 ;
LCD_RW = 0 ;
LCD_EN = 0;
P0 = cmd ;
delayNOP() ;
LCD_EN = 1 ;
delayNOP() ;
LCD_EN = 0 ;
void Init_LCD()
delay_ms(15);
LCD_CMD(0x01); //清除LCD的显示内容
LCD_CMD(0x38); //16*2显示,5*7点阵,8位数据
delay_ms(5);
LCD_CMD(0x38);
delay_ms(5) ;
LCD_CMD(0x38);
delay_ms(5);
LCD_CMD(0x0c);
delay_ms(5);
LCD_CMD(0x06);
delay_ms(5);
LCD_CMD(0x01);
delay_ms(5); //地址自增 光标不显示
void PutChar(U_8b set_x,U_8b set_y,U_8b LCD_data )
while(LCD_Busy()) ;
if (set_y == 0)
LCD_CMD((0x80 | set_x));
}else{
LCD_CMD((0xC0 | set_x));
while(LCD_Busy());
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = LCD_data;
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
delayNOP();
/*自定义字符写入CGRAM */
void LCD_Write_Def()
U_8b i;
LCD_CMD(0x40) ; //写CGRAM
for (i = 0 ; i< 8 ; i++)
while(LCD_Busy());
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = MyDef[i];
delayNOP() ;
LCD_EN = 1 ;
delayNOP() ;
LCD_EN = 0 ;
//P0 为LCD数据口
/*检查LCD忙状态 */
bit LCD_Busy()
bit result ;
LCD_RS = 0 ;
LCD_RW = 1 ;
LCD_EN = 1 ;
delayNOP() ;
LCD_EN = 0 ;
return(result) ;
while(LCD_Busy()) ;
LCD_RS = 0 ;
LCD_RW = 0 ;
LCD_EN = 0;
P0 = cmd ;
delayNOP() ;
LCD_EN = 1 ;
delayNOP() ;
LCD_EN = 0 ;
void Init_LCD()
delay_ms(15);
delay_ms(5);
LCD_CMD(0x38);
delay_ms(5) ;
LCD_CMD(0x38);
delay_ms(5);
LCD_CMD(0x0c);
delay_ms(5);
LCD_CMD(0x06);
delay_ms(5);
LCD_CMD(0x01);
while(LCD_Busy()) ;
if (set_y == 0)
}else{
while(LCD_Busy());
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = LCD_data;
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
delayNOP();
/*自定义字符写入CGRAM */
U_8b i;
while(LCD_Busy());
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = MyDef[i];
delayNOP() ;
LCD_EN = 1 ;
delayNOP() ;
LCD_EN = 0 ;
7楼
手机照的,身边没有数码相机!呵呵!
LCD1602上面就是显示了下温度,硬件单片机没有使用STC的我用的是原来剩下的AT89S52单片机。
共7条
