//编的有点粗心,但是我确实有干活的,版主,手下留情,不要让我进黑名单啦、、、、、//
#include <reg52.H>
#include<intrins.h>
//心形显示
//unsigned char code tabP0[]={0x30,0x48,0x44,0x22,0x44,0x48,0x30,0x00};
//unsigned char code tabP2[]={0xBF,0x0DF,0x0EF,0x0F7,0x0FB,0x0FD,0x0FE,0x7F};
//自定义 "江"
//unsigned char code tabP0[]={0x85,0x4A,0x20,0x44,0x44,0x7C,0x44,0x44,0x00};
unsigned char code tabP2[]={0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,0xFF};
//'0'
//unsigned char code tabP0[]={0x00,0xff,0x81,0x81,0x81,0xff,0x00,0x00,0x00};
//'1'
//unsigned char code tabP0[]={0x00,0x00,0x84,0xfe,0xff,0x80,0x00,0x00,0x00};
//'2'
//unsigned char code tabP0[]={0x00,0xf1,0x91,0x91,0x91,0x9f,0x00,0x00,0x00};
//'3'
//unsigned char code tabP0[]={0x00,0x91,0x91,0x91,0x91,0xff,0x00,0x00,0x00};
//'4'
//unsigned char code tabP0[]={0x00,0x1f,0x10,0x10,0x10,0xff,0x00,0x00,0x00};
//'5'
//unsigned char code tabP0[]={0x00,0x8f,0x89,0x89,0x89,0xf9,0x00,0x00,0x00};
//'6'
//unsigned char code tabP0[]={0x00,0xff,0x91,0x91,0x91,0xf1,0x00,0x00,0x00};
//'7'
//unsigned char code tabP0[]={0x00,0x01,0x01,0x01,0x01,0xff,0x00,0x00,0x00};
//'8'
//unsigned char code tabP0[]={0x00,0xff,0x89,0x89,0x89,0xff,0x00,0x00,0x00};
//'9'
//unsigned char code tabP0[]={0x00,0x9f,0x91,0x91,0x91,0xff,0x00,0x00,0x00};
unsigned char code tabP0[]={0x00,0xff,0x81,0x81,0x81,0xff,0x00,0x00,0x00,0x00,0x00,0x84,0xfe,0xff,0x80,0x00,0x00,0x00,
0x00,0xf1,0x91,0x91,0x91,0x9f,0x00,0x00,0x00,0x00,0x91,0x91,0x91,0x91,0xff,0x00,0x00,0x00,
0x00,0x1f,0x10,0x10,0x10,0xff,0x00,0x00,0x00,0x00,0x8f,0x89,0x89,0x89,0xf9,0x00,0x00,0x00,
0x00,0xff,0x91,0x91,0x91,0xf1,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0xff,0x00,0x00,0x00,
0x00,0xff,0x89,0x89,0x89,0xff,0x00,0x00,0x00,0x00,0x9f,0x91,0x91,0x91,0xff,0x00,0x00,0x00};
sbit beep = P1^0;
//unsigned char code tabP0[]={0x85,0x4A,0x20,0x51,0x6A,0xFD,0x6B,0x51,0x00};
//unsigned char code tabP2[]={0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,0xFF};
unsigned int i,j,m;
unsigned char Count;
//圆形显示
//unsigned char code tabP0[]={0x00,0x3c,0x42,0x42,0x42,0x42,0x3c,0x00};
//unsigned char code tabP2[]={0x7F,0xBF,0x0DF,0x0EF,0x0F7,0x0FB,0x0FD,0x0FE};
//菱形显示
//unsigned char code tabP0[]={0x00,0x08,0x14,0x22,0x41,0x22,0x14,0x08};
//叉形显示
//unsigned char code tabP0[]={0x00,0x41,0x22,0x14,0x08,0x14,0x22,0x41};
//中字显示
//unsigned char code tabP0[]={0x00,0x1e,0x12,0x12,0x7f,0x12,0x12,0x1e};
* 名称 : Time0_Init()
* 功能 : 定时器的初始化,11.0592MZ晶振,50ms
* 输入 : 无
* 输出 : 无
void Time0_Init(void)
IE =0x82;
TMOD = 0x01;
TH0 = 0xB1;
TL0 = 0xDF;
TR0 = 1;
void Time0_Int() interrupt 1
TH0 = 0xB1;
TL0 = 0xDF;
Count++; //长度加1
if(Count==50)
m++;
if(m==90){m=0;}
Count=0;
* 名称 : Main()
* 功能 : 主函数
* 输入 : 无
* 输出 : 无
void main()
Time0_Init();
beep = 0;
while(1)
for(i=0;i<9;i++)
P0=0;
P2=tabP2[i];
_nop_();
_nop_();
_nop_();
// if((j+m)==90) P0=tabP0[(j+m)-90];
P0=tabP0[j+m];
_nop_();
_nop_();
_nop_();
j++;
if(j==9)j=0;
