电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Calculating the Error Budget in Precisio
Calculating the Error Budget in Precision Digital-to-Analog Converter (DAC) Appl
2012-04-12 12:33:39     打赏
Calculating the Error Budget in Precision Digital-to-Analog Converter (DAC) Applications
关键词: voltage references, voltage reference, DAC reference, three terminal reference, reference accuracy, DAC, digital to analog converter, DAC design examples, error budget
Abstract: This application note analyses the parameters that affect the errors in precision digital-to-analog converter (DAC) applications. The analysis focuses on the factors introduced by both the data converter and the voltage reference. It describes the calculations required to select the data converter and the reference to meet the system's target specifications. The calculations are available in a spreadsheet.
  Calculating the Error Budget in Precision Digital-to-Analog Converter (DAC) Applications.pdf
关键词: Calculating     Error     Budget
