摘要:
The principle of vector control of electrical drives is based on the control of both the magnitude and the phase of each phase current and voltage. For as long as this type of control considers the three phase system as three independent systems the control will remain analog and thus present several drawbacks. Since high computational power silicon devices, such as the TMS320F240 from TI, came to market it has been possible to realize far more precise digital vector control algorithms. The most common of these accurate vector controls is presented in this document: the Field Orientated Control, a digital implementation which demonstrates the capability of performing direct torque control, of handling system limitations and of achieving higher power conversion efficiency.
文档:bpra073.pdf
链接:http://www.ti.com.cn/general/cn/docs/litabsmultiplefilelist.tsp?literatureNumber=bpra073
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
