Multiply Your Sampling Rate with Time-Interleaved Data Converters
关键词: interleaving, time-interleaving, high-speed, analog-to-digital converter, high-speed ADC, coarse quantizer, fine quantizer, flash converter, bandwidth limitation, offset error, gain error, mismatches, nonlinearities, clock phase noise, clock jitter
Abstract: Interleaving multiple analog-to-digital converters (ADCs) is usually performed with the intent to increase a converters effective sample rate, especially if there are no or only few off-the-shelf ADCs available that fulfill the desired sample, linearity and AC requirements of such applications. However, time-interleaving data converters is not an easy task, because even with perfectly linear components, gain/offset mismatches and timing errors can cause undesired spurs in the output spectrum. The following article provides valuable insight into the theoretical approach of time-interleaved analog-to-digital converters and the kind of roadblocks (and how to compensate for them) a designer usually encounters when building a time-interleaved system.
Multiply Your Sampling Rate with Time-Interleaved Data Converters.pdf
【有奖活动】分享技术经验,兑换京东卡 | |
话不多说,快进群! | |
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
打赏了!打赏了!打赏了! |
