电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Class D Audio Amplifier Output Filter Op
Class D Audio Amplifier Output Filter Optimization
2012-04-19 12:28:39     打赏
关键词: Class D, audio amplifiers, switching amplifier, output filter, modulation noise, PWM, filterless, amplifiers, amplifer
Abstract: This application note examines the effect of the output filter on audio Class D amplifier performance. Switch-mode amplifiers such as the MAX4295 and MAX4297 offer improved efficiency over their more traditional Class AB counterparts. By understanding the operation of these devices, the modulation noise spectrum and the loudspeaker loads they are required to drive, it is possible to completely eliminate the output filter while retaining the efficiency benefits of Class D amplifiers.
 Class D Audio Amplifier Output Filter Optimization.pdf
关键词: Class     Audio     Amplifier     Out
