电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Shut Down a Current-Sense Amplifier via
Shut Down a Current-Sense Amplifier via Its Supply Pins
2012-04-22 11:16:20     打赏
关键词: current-sense amplifiers, battery operation, NMOS transistors, shutdown
Abstract: You can shut down a current-sense amplifier by connecting an NMOS transistor in its ground path and driving it with logic-level signals capable of turning the transistor ON and OFF. When ON the amplifier operates normally, but when OFF it shuts down because its ground is floating.
 Shut Down a Current-Sense Amplifier via Its Supply Pins.pdf
关键词: Current-Sense     Amplifier     S
