电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Minimize Short-Circuit Current Pulse in
Minimize Short-Circuit Current Pulse in Hot-Swap Controller
2012-04-22 11:35:35     打赏
关键词: hot-swap controllers, inrush current, circuit protection, short-circuit current
Abstract: Because of internal circuit-breaker delay and limited MOS-gate pulldown current, many hot-swap controllers do not limit current during the first 10µs to 50µs following a shorted output. The result can be a brief flow of several hundred amperes. A simple external circuit counters this problem by minimizing the initial current spike and terminating the short circuit within 200ns to 500ns.
 Minimize Short-Circuit Current Pulse in Hot-Swap Controller.pdf
关键词: Minimize     Short-Circuit     Cu
