关键词: WLED, White LED, active ballast, current mirror, LED, boost, LED driver, transistor
Abstract: This application note presents a technique that allows you to mix LED quantities and types, and requires just one power-supply voltage.
Circuit Drives Mixed Types and Quantities of LEDs.pdf
