电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Circuit Drives Mixed Types and Quantitie
Circuit Drives Mixed Types and Quantities of LEDs
2012-04-22 15:17:27     打赏
关键词: WLED, White LED, active ballast, current mirror, LED, boost, LED driver, transistor
Abstract: This application note presents a technique that allows you to mix LED quantities and types, and requires just one power-supply voltage.
 Circuit Drives Mixed Types and Quantities of LEDs.pdf
关键词: Circuit     Drives     Mixed     Type
