【应用手册】Initializing the UniPHY Nios II Sequencer in HardCopy Devices using FPP Configuration Scheme
This application note describes the reuse of the fast passive parallel (FPP)
configuration interface, which is more commonly used in the Altera® FPGA
configuration, to initialize the UniPHY Nios® II sequencer for HardCopy® device
migration.
There are different methods to initialize the Nios II sequencer in HardCopy devices.
Altera recommends re-using the existing FPGA configuration interface to initialize
the Nios II sequencer to save resources and avoid a board re-spin.
an650.pdf
共1条
共1条
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
