共3条
LPC938控制1602液晶显示的问题???
各位好!我现在用LPC938单片机控制1602液晶显示,但为什么显示不出来,问一下,IO配置为推挽输出还是准双向口?演示用多大?代码如下,哪位大神解释下:
#include
#include
sbit rs=P1^1;
sbit rw=P2^6;
sbit e=P2^7;
sbit led=P1^0;
#define dataport P0
void delay_us(unsigned int t) //延时(t*2+5) us
t *= 6;
while(--t);
void delay_ms(unsigned int t) //延时t ms
while(t--)
delay_us(245);
delay_us(245);
void LPC938_Init(void)
//CLK_RESET_Init();
// UCFG1=0x40; //禁止看门狗复位、禁止掉电检测、使能P1.5复位,使用外部高频晶振12MHz
DIVM=0x00; //外部晶振作为CPU时钟,不分频
//IO_Init();
P0M1=0x00;
P0M2=0xff;
P1M1=0x2c; //P15(RST)、P12(SCL/T0)、P13(SDA/INT0)配置为输入,其他的均为准双向口
P1M2=0xd3;
P2M1=0x00;
P2M2=0xff;
void lcd_write_com(unsigned char com)
// while(lcd_check_busy()); //忙则等待
rs=0;
rw=0;
e=1;
dataport=com;
_nop_();
e=0;
void lcd_write_data(unsigned char dat)
rs=1;
rw=0;
e=1;
dataport=dat;
_nop_();
e=0;
void lcd_clear(void)
lcd_write_com(0x01);
delay_ms(5);
void lcd_write_char(unsigned char x,unsigned char y,unsigned char dat)
if (y==0)
lcd_write_com(0x80+x);
else
lcd_write_com(0xC0+x);
lcd_write_data(dat);
void lcd_write_string(unsigned char x,unsigned char y,unsigned char *s)
while(*s)
lcd_write_char(x,y,*s);
s++;x++;
void lcd_init(void)
lcd_write_com(0x38); /*显示模式设置*/
delay_ms(5);
delay_ms(5);
delay_ms(5);
lcd_write_com(0x08); /*显示关闭*/
lcd_write_com(0x01); /*显示清屏*/
lcd_write_com(0x06); /*显示光标移动设置*/
delay_ms(5);
lcd_write_com(0x0C); /*显示开及光标设置*/
main()
LPC938_Init();
lcd_init();
lcd_clear();
lcd_write_string(0,1,"lcd1602");
delay_ms(500);
while(1)
led =~ led;
delay_ms(500);
下载时时钟配置为:高频外部晶振12MHz,使能P1^5,那位有用过的代码让我参考下!!!谢谢啦!!!
关键词: LPC938 控制 液晶显示 问题 delay u
#include
#define uchar unsigned char
#define uint unsigned int
sbit rs=P3^5;
sbit lcden=P3^4;
sbit dula=P2^6;
sbit wela=P2^7;
uchar table1[]="TX-1B MCU";
uchar table2[]="www.mcuhx.com";
void delay(uint x)
uint a,b;
for(a=x;a0;a--)
for(b=10;b0;b--);
void delay1(uint x)
uint a,b;
for(a=x;a0;a--)
for(b=100;b0;b--);
void write_com(uchar com)
P0=com;
rs=0;
lcden=0;
delay(10);
lcden=1;
delay(10);
lcden=0;
void write_date(uchar date)
P0=date;
rs=1;
lcden=0;
delay(10);
lcden=1;
delay(10);
lcden=0;
void init()
dula=0;
wela=0;
write_com(0x38);
delay(20);
write_com(0x0f);
delay(20);
write_com(0x06);
delay(20);
write_com(0x01);
delay(20);
字数超了
void init()
dula=0;
wela=0;
write_com(0x38);
delay(20);
write_com(0x0f);
delay(20);
write_com(0x06);
delay(20);
write_com(0x01);
delay(20);
void main()
uchar a;
init();
write_com(0x80+19);
delay(20);
for(a=0;a
不知道为什么贴不上去,网上很多的,自己找找吧。
共3条
