【应用手册】AN 603: Active Serial Remote System Upgrade Reference Design
This application note provides a reference design for the active serial (AS) remote
system upgrade feature in Arria II GX, Stratix III, and Stratix IV devices. The AS
remote system upgrade feature enables supported Altera devices to receive new
configuration data from a remote source, update of the flash memory content, and
reconfigure the device with new configuration data, allowing you to overcome
difficult challenges such as shorten design cycles, evolving standards, and system
deployments in remote locations.
This reference design instantiates the ALTREMOTE_UPDATE megafunction and a
user logic to initiate the reconfiguration cycle. Use this reference design to begin using
the remote system upgrade feature in Arria II GX, Stratix III, and Stratix IV devices
and then you can modify the design to suit your system usage.an603.pdf
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
