【应用笔记】主动串行存储器接口控制器参考设计(Active Serial Memory Interface Controller Reference Design)
如果你正在使用Altera的Stratix II、Cyclone II或Cyclone FPGA做设计,这个主动串行存储器接口(ASMI)控制器参考设计,在存取Altera的EPCS1、EPCS4、EPCS16和EPCS64等串行配置器件的未使用部分时,是非常有用的。
If you are designing with Altera® Stratix® II, Cyclone™ II, or Cyclone
FPGAs, the active serial memory interface (ASMI) controller reference
design is useful in accessing the unused portion of Altera EPCS1, EPCS4,
EPCS16, and EPCS64 serial configuration devices. The Nios® II
embedded processor also provides a complete solution for this capability
by using the EPCS Controller module in SOPC Builder.an379.pdf
共1条
共1条
