【应用笔记】AN367:在Stratix II器件中实现PLL重配置(AN 367: Implementing PLL Reconfiguration in Stratix II Devices)
锁相环(Phase-locked loops,PLLs)使用几个分频计数器和不同的压控振荡器(voltage-controlled oscillator,VCO)相位节拍,来实现频率综合和相移。
Phase-locked loops (PLLs) use several divide counters and different
voltage-controlled oscillator (VCO) phase taps to perform frequency synthesis and
phase shifts. In Stratix® II enhanced and fast PLLs, you can reconfigure both the
counter settings and phaseshift the PLL output clock in real time. You can also change
the charge pump and loop filter components, which dynamically affects the PLL
bandwidth. You can use these PLL components to update the output clock frequency,
PLL bandwidth, and phaseshift in real time, without reconfiguring the entire FPGA.an367.pdf
共1条
共1条
| 2026年“我要开发板活动”第三季,开始了! | |
