电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » FPGA实验连载(二、数码管1)
FPGA实验连载(二、数码管1)
2012-10-12 23:23:38     打赏
-- 7段数码管实验2:递增方式在4位数码管上向上计数显示从0000-0001->0002……..9999….0000….0001….
-- 设计了一个4位十进制计数器,并用数码管显示当前计数值
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY seg1 IS
   PORT (
      clk                     : IN std_logic;
      rst                     : IN std_logic;
      dataout                 : OUT std_logic_vector(7 DOWNTO 0);   --各段数据输出
      en                      : OUT std_logic_vector(3 DOWNTO 0));  --COM使能输出
END seg1;
ARCHITECTURE arch OF seg1 IS
signal div_cnt : std_logic_vector(24 downto 0 );
signal data4 :    std_logic_vector(3 downto 0);
signal dataout_xhdl1 : std_logic_vector(7 downto 0);
signal en_xhdl : std_logic_vector(3 downto 0);
signal cntfirst :std_logic_vector(3 downto 0);
signal cntsecond : std_logic_vector(3 downto 0);
signal cntthird  : std_logic_vector(3 downto 0);
signal cntlast   : std_logic_vector(3 downto 0);
signal first_over: std_logic;
signal second_over: std_logic;
signal third_over : std_Logic;
signal last_over  : std_logic;
begin
  dataout<=dataout_xhdl1;
  en<=en_xhdl;
 process(clk,rst)
 begin
   if(rst='0')then
   div_cnt<="0000000000000000000000000";
   elsif(clk'event and clk='1')then
   div_cnt<=div_cnt+1;
   end if;
 end process;
process(div_cnt(24),rst,last_over)                 ---first 10 counter
begin
 if(rst='0')then
   cntfirst<="0000";
   first_over<='0';
 elsif(div_cnt(24)'event and div_cnt(24)='1')then
   if(cntfirst="1001" or last_over='1')then
      cntfirst<="0000";
      first_over<='1';
   else
      first_over<='0';
      cntfirst<=cntfirst+1;
   end if;
  end if;
end process;
process(first_over,rst)               --second 10  counter
begin
 if(rst='0')then
   cntsecond<="0000";
   second_over<='0';
 elsif(first_over'event and first_over='1')then
   if(cntsecond="1001")then
      cntsecond<="0000";
      second_over<='1';
   else
      second_over<='0';
      cntsecond<=cntsecond+1;
   end if;
  end if;
end process;
process(second_over,rst)               --second 10  counter
begin
 if(rst='0')then
   cntthird<="0000";
   third_over<='0';
 elsif(second_over'event and second_over='1')then
   if( cntthird="1001")then
       cntthird<="0000";
      third_over<='1';
   else
      third_over<='0';
       cntthird<= cntthird+1;
   end if;
  end if;
end process;
process(third_over,rst)               --second 10  counter
begin
 if(rst='0')then
   cntlast<="0000";
   last_over<='0';
 elsif(third_over'event and third_over='1')then
   if( cntlast="1001")then
       cntlast<="0000";
      last_over<='1';
   else
      last_over<='0';
       cntlast<= cntlast+1;
   end if;
  end if;
end process;
---****************显示部分***************--
 process(rst,clk,div_cnt(19 downto 18))
 begin
  if(rst='0')then
    en_xhdl<="1110";
    case div_cnt(19 downto 18) is
     when"00"=> en_xhdl<="1110";
     when"01"=> en_xhdl<="1101";
     when"10"=> en_xhdl<="1011";
     when"11"=> en_xhdl<="0111";
    end case;
  end if;
关键词: 实验     连载     数码     logic     vector     sig
站长统计
Digikey let's do
· 2025年第1期限时报名开启,5月8日截止
· Digikey助力,提供一站式免费器件支持
· 跟大佬一起 【DIY 功率监测与控制系统】
