RainlyWy进程贴-(万年历LCD显示带按键设置保存)
1.开发板焊接(12.10.1---12.10.7) ---------- 2楼
2.LED流水(12.10.17) ---------- 3楼
3.LED闪烁,跑马,流水组合(12.10.18)-------- 6楼
4.按键消抖控制LED灯(12.10.18)---------------- 7楼
5.数码管静态显示(12.10.19)------------------- 9楼
6.数码管动态显示-时钟显示(12.10.19)-------- 10楼
7.蜂鸣器-警报声(12.10.20)------------------ 11楼
8.蜂鸣器-电子琴(12.10.20)------------------ 13楼
9.蜂鸣器-自动播放音乐-祝你生日快乐(12-10-21) 16楼
10.LCD1602显示(12-10-23)------------------- 17楼
11.串口通信-协议控制LED流水------------------ 19楼
12.万年历-数码管-1602显示-带按键设置保存时间- 22楼
-----------隔断-------------------隔断-----------------------
12-11-20 好久没上来了 公司一直忙啊忙的,今天终于有空上来瞧瞧了,发现自己的帖子跑第三页了都,赶紧冒一下喽!!!!!
关键词: RainlyWy 进程 万年历 显示 按键 设置
源码:
module aaa(
input sysClk,
input sysReset,
output wire [7:0] led,
output wire power_led,
output wire work_led
parameter DELAY = 5000000;
reg [31:0] delay_cnt = 0;
always @(posedge sysClk,negedge sysReset)
begin
if(!sysReset)
delay_cnt <= 32'd0;
else if(delay_cnt >= DELAY)
delay_cnt <= 32'd0;
else
delay_cnt <= delay_cnt + 1'b1;
end
reg calWorkLed = 0;
reg calPowerLed = 0;
begin
if(!sysReset)
begin
calWorkLed <= 1'b0;
calPowerLed <= 1'b0;
end
begin
calWorkLed <= ~calWorkLed;
end
end
reg [3:0] sta = 0;
reg [7:0] calLed = 8'b11111111;
reg [7:0] OverCnt = 0;
always @(posedge sysClk)
begin
if(!sysReset)
calLed <= 8'b11111111;
begin
case(sta)
0:
begin
OverCnt <= OverCnt + 1;
calLed <= ~calLed;
if(OverCnt >= 6)
begin
calLed <= 8'b11111110;
OverCnt <= 8'd0;
sta <= 4'd1;
end
end
1:
begin
calLed <= {calLed[6:0],calLed[7]};
if(OverCnt >= 7)
begin
calLed <= 8'b1111_1111;
OverCnt <= 8'd0;
sta <= 4'd2;
end
end
2:
begin
calLed <= {1'b0,calLed[7:1]};
if(OverCnt >= 7)
begin
calLed <= 8'b0000_0000;
OverCnt <= 8'd0;
sta <= 4'd3;
end
end
3:
begin
calLed <= {calLed[6:0],1'b1};
if(OverCnt >= 7)
begin
calLed <= 8'b0111_1111;
OverCnt <= 8'd0;
sta <= 4'd4;
end
end
4:
begin
calLed <= {calLed[0],calLed[7:1]};
if(OverCnt >= 7)
begin
OverCnt <= 8'd0;
sta <= 4'd0;
end
end
endcase
end
end
assign led = calLed;
assign power_led = calPowerLed;
assign work_led = calWorkLed;
endmodule
源码:
1.顶层
module aaa(
input sysClk,
input sysReset,
input [7:0]key,
begin
if(!sysReset)
delay_cnt <= 32'd0;
delay_cnt <= 32'd0;
else
end
reg calWorkLed = 0;
begin
if(!sysReset)
begin
calWorkLed <= 1'b0;
end
begin
end
end
//assign led = key;
WipeJitter wipeJitter0(.clk(sysClk),.rstn(sysReset),.key(key[0]),.key_v(led[0]));
WipeJitter wipeJitter1(.clk(sysClk),.rstn(sysReset),.key(key[1]),.key_v(led[1]));
WipeJitter wipeJitter2(.clk(sysClk),.rstn(sysReset),.key(key[2]),.key_v(led[2]));
WipeJitter wipeJitter3(.clk(sysClk),.rstn(sysReset),.key(key[3]),.key_v(led[3]));
WipeJitter wipeJitter4(.clk(sysClk),.rstn(sysReset),.key(key[4]),.key_v(led[4]));
WipeJitter wipeJitter5(.clk(sysClk),.rstn(sysReset),.key(key[5]),.key_v(led[5]));
WipeJitter wipeJitter6(.clk(sysClk),.rstn(sysReset),.key(key[6]),.key_v(led[6]));
WipeJitter wipeJitter7(.clk(sysClk),.rstn(sysReset),.key(key[7]),.key_v(led[7]));
endmodule
2.消抖模块
module WipeJitter(
input clk,
input rstn,
input key,
output reg key_v
//delay key
reg key_d = 0;
always @(posedge clk,negedge rstn)
begin
if(!rstn)
key_d <= 1'b0;
else
key_d <= key;
end
//generate nenedge key
reg negeKey = 0;
begin
if(!rstn)
negeKey <= 1'b0;
else
negeKey <= (key_d == 1'b1) & (key == 1'b0);
end
reg [19:0] DelayCnt = 0;
begin
if(!rstn)
DelayCnt <= 20'd0;
else if((negeKey == 1'b1) | (key == 1'b1))
DelayCnt <= 20'd0;
else if(DelayCnt == 500000)
DelayCnt <= DelayCnt;
else if(key == 1'b0)
DelayCnt <= DelayCnt + 1;
end
begin
if(!rstn)
key_v <= 1'b1;
key_v <= 1'b0;
else
key_v <= 1'b1;
end
endmodule
数码管静态显示:
源码:
module aaa(
input sysClk,
input sysReset,
output [7:0] led,
output [7:0] SEG,
output [7:0] DIG
parameter DELAY = 10000;
begin
if(!sysReset)
delay_cnt <= 32'd0;
delay_cnt <= 32'd0;
else
end
reg [7:0] dig_show[9:0];
initial begin
dig_show[0] = 8'hC0;
dig_show[1] = 8'hF9;
dig_show[2] = 8'hA4;
dig_show[3] = 8'hB0;
dig_show[4] = 8'h99;
dig_show[5] = 8'h92;
dig_show[6] = 8'h82;
dig_show[7] = 8'hF8;
dig_show[8] = 8'h80;
dig_show[9] = 8'h90;
end
reg [7:0] dig_d = 8'b1111_1110;
reg [7:0] digCnt = 0;
begin
begin
dig_d <= {dig_d[6:0],dig_d[7]};
digCnt <= digCnt + 1;
if(digCnt == 8'd7)
digCnt <= 8'd0;
end
end
assign SEG = dig_show[digCnt];
assign DIG = dig_d;
assign led = dig_d;
endmodule
效果图:
动态数码管显示:
视频效果:
关键代码:
module aaa(
input sysClk,
input sysReset,
output [7:0] led,
output [7:0] SEG,
output [7:0] DIG
begin
if(!sysReset)
delay_cnt <= 32'd0;
delay_cnt <= 32'd0;
else
end
initial begin
end
wire [7:0] dig_out[9:0];
assign dig_out[5] = 8'hbf;
assign dig_out[2] = 8'hbf;
//---s
wire [3:0] s_h,s_l;
wire m_en;
time_s s(
.clk(sysClk),
.rstn(sysReset),
.s_h(s_h),
.s_l(s_l),
.m_en(m_en)
//---m
wire [3:0]m_h,m_l;
wire h_en;
time_m m(
.clk(sysClk),
.rstn(sysReset),
.en(m_en),
.m_h(m_h),
.m_l(m_l),
.h_en(h_en)
//---h
wire [3:0] h_h,h_l;
time_h time_h(
.clk(sysClk),
.rstn(sysReset),
.en(h_en),
.h_h(h_h),
.h_l(h_l)
//chioce data
assign dig_out[7] = dig_show[h_h];
assign dig_out[6] = dig_show[h_l];
assign dig_out[4] = dig_show[m_h];
assign dig_out[3] = dig_show[m_l];
assign dig_out[1] = dig_show[s_h];
assign dig_out[0] = dig_show[s_l];
begin
begin
if(digCnt == 8'd7)
digCnt <= 8'd0;
end
end
assign SEG = dig_out[digCnt];
assign DIG = dig_d;
assign led = dig_d;
endmodule
秒模块
module time_s(
input clk,
input rstn,
output [3:0] s_h,
output [3:0] s_l,
output m_en
parameter DELAY = 50_000_000;
begin
if(!rstn)
delay_cnt <= 32'd0;
delay_cnt <= 32'd0;
else
end
reg [3:0] s_h_d = 4,s_l_d = 5;
reg m_en_d = 0;
begin
if(!rstn)
begin
s_h_d <= 4'd4;
s_l_d <= 4'd3;
end
begin
m_en_d <= 1'b0;
s_l_d <= s_l_d + 1'b1;
if(s_l_d == 4'd9)
begin
s_l_d <= 4'd0;
s_h_d <= s_h_d + 1'b1;
if(s_h_d == 4'd5)
begin
m_en_d <= 1'b1;
s_h_d <= 4'd0;
end
end
end
else
m_en_d <= 1'b0;
end
assign s_h = s_h_d;
assign s_l = s_l_d;
assign m_en = m_en_d;
endmodule
分模块:
module time_m(
input clk,
input rstn,
input en,
output [3:0] m_h,
output [3:0] m_l,
output h_en
reg [3:0] m_h_d = 2,m_l_d = 7;
reg h_en_d = 0;
begin
if(!rstn)
begin
m_h_d <= 4'd2;
m_l_d <= 4'd7;
end
else if(en)
begin
h_en_d <= 1'b0;
m_l_d <= m_l_d + 1'b1;
if(m_l_d == 4'd9)
begin
m_l_d <= 4'd0;
m_h_d <= m_h_d + 1'b1;
if(m_h_d == 4'd5)
begin
h_en_d <= 1'b1;
m_h_d <= 4'd0;
end
end
end
else
h_en_d <= 1'b0;
end
assign m_h = m_h_d;
assign m_l = m_l_d;
assign h_en = h_en_d;
endmodule
时模块:
module time_h(
input clk,
input rstn,
input en,
output [3:0] h_h,
output [3:0] h_l
reg [3:0] h_h_d = 2,h_l_d = 3;
begin
if(!rstn)
begin
h_l_d <= 4'd3;
h_h_d <= 4'd2;
end
else if(en)
begin
h_l_d <= h_l_d + 1'b1;
if(h_l_d == 4'd9)
begin
h_l_d <= 4'd0;
h_h_d <= h_h_d + 1'b1;
end
else if((h_h_d == 4'd2) & (h_l_d == 4'd3))
begin
h_h_d <= 4'd0;
h_l_d <= 4'd0;
end
end
end
assign h_h = h_h_d;
assign h_l = h_l_d;
endmodule
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! | |
【有奖活动】伙伴们:您的“需求”解决了吗? |
打赏帖 | |
老胖子聊电路--分析一个反馈电路被打赏50分 | |
放大↔震荡被打赏50分 | |
【换取手持数字示波器】RTduino驱动ssd1306+sht31温湿度计被打赏40分 | |
【换取手持数字示波器】称植国产开源TobudOS到雅特力AT32F425被打赏40分 | |
【分享评测,赢取加热台】+Telink-泰凌微电子B91点灯篇被打赏20分 | |
【换取手持数字示波器】+精英板驱动LCD屏被打赏50分 | |
【换取手持数字示波器】+DFR0216全彩灯带WS2812示例分享被打赏50分 | |
【换取手持数字示波器】安装雅特力国产IDE-AT32IDE被打赏30分 | |
【换取手持数字示波器】+DFR0654板卡驱动数码管和串口功能分享被打赏50分 | |
【换取手持数字示波器】+DFPlayerMini模块推喇叭示例分享被打赏50分 |
