电子产品世界 » 论坛首页 » 嵌入式开发 » 软件与操作系统 » 替一网友请教问题:ucos移植到stm32. 在做外部触发中断时遇到了问题
2013-09-25 14:22:20     打赏
本人菜鸟一个,刚接触ucos移植到stm32. 在做外部触发中断时遇到了问题,请大侠指点迷津。。。。。
目的:程序建立了一个任务App_Task_Key按键控制LED灯的闪烁,开启了EXTI_Line13的中断,当按下按钮的时候,会触发中断,进而关灭LED灯。
问题:现有三个任务在程序中,前两个也是LED的任务,两个LED能够顺利轮训闪烁运行,但是增加第三个中断控制任务时, 当我按下按键触发中断,就是一直死在那里中断里出不来。另两个任务也无法运行了。
void App_TaskCreate(void)
#if OS_TASK_NAME_SIZE > 7
    INT8U  err;
#endif
    OSTaskCreate((void (*)(void *)) App_TaskToggleLED,
           (void          * ) 0,
           (OS_STK        * )&App_TaskToggleLEDStk[APP_CFG_TASK_ToggleLED_STK_SIZE - 1],
           (INT8U           ) APP_CFG_TASK_ToggleLED_PRIO
    OSTaskCreate((void (*)(void *)) App_LED2task,
                    (void           *) 0,
                    (OS_STK         *)&App_TaskToggleLED2Stk[APP_CFG_TASK_ToggleLED2_STK_SIZE - 1],
                    (INT8U           ) APP_CFG_TASK_ToggleLED2_PRIO
   OSTaskCreate((void (*)(void *)) App_Task_Key,
                    (void           *) 0,
                    (OS_STK         *)&App_TaskToggleKeyStk[APP_CFG_TASK_ToggleKey_STK_SIZE - 1],
                    (INT8U           ) APP_CFG_TASK_ToggleKey_PRIO
#endif
#if OS_TASK_NAME_SIZE > 14
    OSTaskNameSet(APP_CFG_TASK_ToggleLED_PRIO, (INT8U *)"uC/OS-II LED", &err);
    OSTaskNameSet(APP_CFG_TASK_ToggleLED2_PRIO, (INT8U *)"uC/OS-II LED", &err);
    OSTaskNameSet(APP_CFG_TASK_ToggleKey_PRIO, (INT8U *)"uC/OS-II LED", &err);
#endif
static void App_Task_Key(void* p_arg)
      (void) p_arg ;
      INT8U  err;
      Sem_Task_Key=OSSemCreate(0);
      while(1)
            OSSemPend(Sem_Task_Key,0,&err);// 等待信号量
            GPIO_SetBits(GPIOB, GPIO_Pin_13);
            OSTimeDlyHMSM(0,0,1,0);
void EXTI13_IRQHandler(void)
     OSIntEnter();
     OSSemPost(Sem_Task_Key);
     EXTI_ClearITPendingBit(EXTI_Line13);
     OSIntExit();
void BSP_NVICConfiguration(void)
  NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);           //抢占式优先级别设置为无抢占优先级
  NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn ;    //指定中断源
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;        //指定响应优先级别1
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;         //使能外部中断通道3
  NVIC_Init(&NVIC_InitStructure);
static void BSP_ExtIntrInit(void)
    GPIO_InitTypeDef  gpio_init;
    EXTI_InitTypeDef  EXTI_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
    gpio_init.GPIO_Pin   = GPIO_Pin_13;
    gpio_init.GPIO_Speed = GPIO_Speed_50MHz;
    gpio_init.GPIO_Mode  = GPIO_Mode_IN_FLOATING;
    GPIO_Init(GPIOC, &gpio_init);
    /* Enable AFIO Clock*/
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
    /* Connect EXTI13 Line to PC.13 pin */
    GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource13);  //将PA3连接到外部中断通道3
    /* Configure EXTI13 Line */
    EXTI_InitStructure.EXTI_Line = EXTI_Line13;
    EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
    EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
    EXTI_InitStructure.EXTI_LineCmd = ENABLE;
    EXTI_Init(&EXTI_InitStructure);
关键词: 网友     请教     问题     移植     stm32.     在做     外部
