电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » 有个问题想求助下!!
有个问题想求助下!!
2014-05-06 22:35:54     打赏
所编写的.vhd文件,编译的时候出现info:Information On Architecture CTRL-ART  was not stored?? 是什么意思呢??主控程序是一个密码锁控制电路,出现了一些问题,其中程序在下面:
--CTRL.VHD
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY CTRL IS
PORT   (DATA_N: IN STD_LOGIC_VECTOR(3 DOWNTO 0);
        DATA_F: IN STD_LOGIC_VECTOR(3 DOWNTO 0);
        FLAG_N: IN STD_LOGIC;
        FLAG_F: IN STD_LOGIC;
        CLK: IN STD_LOGIC;
        ALERT:OUT STD_LOGIC;    --报警端口
        ENLOCK: OUT STD_LOGIC;  --1: LOCK 上锁, 0: UNLOCK打开
        DATA_BCD: OUT STD_LOGIC_VECTOR (15 DOWNTO 0));
END ENTITY CTRL ;
ARCHITECTURE ART OF CTRL IS
    SIGNAL ACC, REG: STD_LOGIC_VECTOR (15 DOWNTO 0);
           --ACC用于暂存键盘输入的信息,REG用于存储输入的密码
    SIGNAL NC: STD_LOGIC_VECTOR (2 DOWNTO 0);
    SIGNAL RR2, CLR, BB, QA, QB: STD_LOGIC;
    SIGNAL CNT:STD_LOGIC_VECTOR(1 DOWNTO 0);
    SIGNAL R1, R0: STD_LOGIC;
BEGIN
--寄存器清零信号的产生进程
PROCESS(CLK)
  BEGIN
    IF CLK'EVENT AND CLK='1' THEN
       R1<=R0; R0<=FLAG_F;
    END IF;
       RR2<=R1 AND NOT R0;
       CLR<=RR2;
END PROCESS;
--按键输入数据的存储、清零进程
KEYIN_PROCESS : BLOCK IS
   SIGNAL RST, D0, D1: STD_LOGIC ;
     BEGIN
   RST  <= RR2;
 PROCESS(FLAG_N, RST) IS
     BEGIN
  IF RST = '1' THEN
    ACC <= "0000000000000000" ;   --CLEAR INPUT
    NC <= "000" ;
  ELSE
   IF  FLAG_N'EVENT AND FLAG_N = '1'  THEN
      IF NC < 4 THEN
       ACC <= ACC(11 DOWNTO 0) & DATA_N ;
              NC <= NC + 1 ;
      END IF;
    END IF ;
  END IF ;
 END PROCESS ;
END BLOCK KEYIN_PROCESS ;
--上锁/开锁控制进程
PROCESS(CLK, DATA_F) IS
   BEGIN
 IF (CLK'EVENT AND CLK = '1') THEN
  IF NC = 4  THEN
   IF DATA_F(2) = '1' THEN    --上锁控制信号有效 (0100)
      REG <= ACC ;       --密码存储
      QA <= '1' ;  QB <= '0';
   ELSIF DATA_F(0) = '1' THEN --开锁控制信号有效 (0001)
    IF  REG = ACC THEN   --密码核对
     QA<= '0';  QB <= '1' ;
    ELSE
           IF CNT="11" THEN
           ALERT<='1'; CNT<="00";
           ELSE
           CNT<= CNT+1; QA<= '1';  QB <= '0' ; ALERT<='0';
           END IF;
    END IF;
    ELSIF  ACC = "1000100010001000" THEN
          --设置"8888"为万用密码
    QA <= '0' ;  QB<= '1';
   END IF ;
  END IF;
 END IF ;
END PROCESS ;
--输出上锁/开锁控制信号
ENLOCK <= QA AND NOT QB ;
--输出显示信息
  DATA_BCD<= ACC ;
END ARCHITECTURE ART;
望各位大神求助!!!
错误如下:
