Character (Serial Code) 100-999 Device for consumer or entertainment use Y## Industrial service (No letter Z), ## is a W## Registration number from 10_99
Japanese Semiconductor Numbering System
2 SC 82DA
1 23 4 5
1) Kind of device, indicating the number of effective electrical
connections minus one
2) For a semiconductor registered with the EIAJ this letter is always an S
3) Third letter designates the polarity and application
A PNP transistor, high-frequency
B PNP transistor, low-frequency
C NPN transistor, high-frequency
D NPN transistor, low-frequency
E P-gate thyristor
F N-gate thyristor
H N-base unijunction transistor
J P-channel FET
K N-channel FET
M Bi-directional triode thyristor
4) These figures designate the order of application for EIAj registration,
starting with 11
5) This letter indicates the level of improvement. An improved device
may be used in place of a previous-generation device , but not
necessarily the other way around
Transistors sorted by using
Output Input Typ Supply
Power Power Gain Voltage
Device (W) (W) (dB) (V) Case Mfr
1.5 to 30 MHz, HF SSB/CW
2SC2086 0.3 - 13 12 TO-92 MI
BLV10 1 - 18 12 SOT123 PH
BLV11 2 - 18 12 SOT123 PH
MRF476 3 0.1 15 12.5-13.6 221A-04/1 MO
BLW87 6 - 18 12 SOT123 PH
2SC2166 6 - 13.8 12 TO-220 MI
BLW83 10 - 20 26 SOT123 PH
MRF475 12 1.2 10 12.5-13.6 221A-04/1 MO
MRF433 12.5 0.125 20 12.5-13.6 211-07/1 MO
2SC3133 13 - 14 12 TO-220 MI
MRF485 15 1.5 10 28 221A-04/1 MO
2SC1969 16 - 12 12 TO-220 MI
BLW50F 16 - 19.5 45 SOT123 PH
MRF406 20 1.25 12 12.5-13.6 211-07/1 MO
SD1285 20 0.65 15 12.5 M113 SG
MRF426 25 0.16 22 28 211-07/1 MO
MRF427 25 0.4 18 50 211-07/1 MO
MRF477 40 1.25 15 12.5-13.6 211-11/1 MO
MRF466 40 1.25 15 28 211-07/1 MO
BLW96 50 - 19 40 SOT121 PH
2SC3241 75 - 12.3 12.5 TO-45E MI
SD1405 75 3.8 13 12.5 M174 SG
2SC3241 75 - 12.3 13.5 TO-40E MI
MRF464 80 2.53 10 28 211-11/1 MO
MRF421 100 10 10 12.5-13.6 211-11/1 MO
SD1405 100 7.9 11 12.5 M174 SG
2SC2904 100 - 11.5 12.5 TO-40E MI
SD1729 130 8.2 12 28 M174 SG
MRF422 150 15 10 28 211-11/1 MO
MRF428 150 7.5 13 50 211-11/1 MO
SD1726 150 6 14 50 M174 SG
PT9790 150 4.8 15 50 211-11/1 MO
MRF448 250 15.7 12 50 211-11/1 MO
MRF430 600 60 10 50 368-02/1 MO
50 MHz
MRF475 4 0.4 10 12.5-13.6 211A-04/1 MO
MRF497 40 4 10 12.5-13.6 211A-04/1 MO
SD1446 70 7 10 12.5 M113 SG
MRF492 70 5.6 11 12.5-13.6 211-11/1 MO
SD1405 100 20 7 12.5 M174 SG
VHF to 175 MHz
2N4427 0.7 - 8 7.5 TO-39 PH
2N3866 1 - 10 28 TO-39 PH
BFQ42 1.5 - 8.4 7.5 TO-39 PH
2SC2056 1.6 - 9 7.2 TO-41 MI
2N3553 2.5 0.25 10 28 79-04/1 MO
BFQ43 3 - 9.4 7.5 TO-39 PH
SD1446 4 0.25 12 12.5 M135 SG
2SC2056 5 - 13 12.5 T-40 MI
2N6541 7 1 8.4 28 144B-05/1 MO
MRF340 8 0.4 13 28 221A-04/2 MO
BLW29 9 - 7.4 7.5 SOT120 PH
SD1143 10 1 10 12.5 M135 SG
2SC1729 14 - 10 13.5 T-31E MI
SD1014-02 15 3.5 6.3 12.5 M135 SG
BLV11 15 - 8 13.5 SOT123 PH
2N6542 20 3 8.2 28 145A-09/1 MO
MRF342 24 1.9 11 28 221A-04/2 MO
BLW87 25 - 6 13.5 SOT123 PH
2SC1946 28 - 6.7 13.5 T-31E MI
MRF314 30 3 10 28 221-07/1 MO
SD1018 40 14 4.5 12.5 M135 SG
2N5643 40 6.9 7.6 28 145A-09/1 MO
BLW40 40 - 10 12.5 SOT120 PH
MRF315 45 5.7 9 28 221-07/1 MO
TP9733 50 10 7 28 145A-09/1 MO
MRF344 60 15 6 28 221A-04/2 MO
2SC2964 70 - 6.7 12.5 T-40 MI
BLV75/12 75 - 6.5 12.5 SOT119 PH
MRF316 80 8 10 28 316-01/1 MO
SD1477 100 25 6 12.5 M111 SG
BLW78 100 - 6 28 SOT121 PH
MRF316 100 12.5 9 28 316-01/1 MO
TP9386 150 15 10 28 316-01/1 MO
220 MHz
MRF207 1 0.15 8.2 12.5 79-04/1 MO
MRF227 3 0.13 13.5 12.5 79-05/5 MO
MRF208 10 1 10 12.5 145A-09/1 MO
MRF226 13 1.6 9 12.5 145A-09/1 MO
2SC2133 30 - 8.2 28 T-40E MI
2SC2134 60 - 7 28 T-40E MI
2SC2609 100 - 6 28 T-40E MI
UHF to 512 MHz
2N4427 0.4 - 10 12.5 TO-39 PH
2SC2133 0.5 - 14 12.5 T-43 MI
MRF581 0.6 0.03 13 12.5 317-01/2 MO
2SC2133 1 - 4 12.5 TO-39 MI
2SC2133 1.4 - 6.7 13.5 TO-39 MI
BLX65E 2 - 9 12.5 TO-39 PH
BLW89 2 - 12 28 SOT122 PH
MRF630 3 0.33 9.5 12.5 79-05/5 MO
2SC2133 3 0.3 10 12.5 TO-31E MI
BLW80 4 - 8 12.5 SOT122 PH
BLW90 4 - 11 12.5 SOT122 PH
MRF652 5 0.5 10 12.5 244-04/1 MO
2SC3021 7 1.2 7.6 12.5 TO-31E MI
BLW81 10 - 6 12.5 SOT122 PH
MRF653 10 2 7 12.5 244-04/1 MO
BLW90 10 - 9 28 SOT122 PH
MRF654 15 2.5 7.8 12.5 244-04/1 MO
2SC3022 18 6 4.7 12.5 TO-31E MI
BLU20/12 20 - 6.5 12.5 SOT119 PH
BLX94A 25 - 6 28 SOT48/2 PH
2SC2695 28 - 4.9 13.5 TO-31E MI
BLU30/12 30 - 6 12.5 SOT119 PH
BLU45/12 45 - 4.8 12.5 SOT119 PH
2SC2905 45 - 4.8 12.5 TO-40E MI
MRF650 15 15.8 5 12.5 316-01/1 MO
TP5051 50 6 9 24 333A-02/2 MO
BLU60/12 60 - 4.4 12.5 SOT119 PH
2SC3102 60 20 4.8 12.5 TO-41E MI
BLU60/28 60 - 7 28 SOT119 PH
MRF658 65 25 4.15 12.5 316-01/1 MO
MRF338 80 15 7.3 28 333-04/1 MO
SD1464 100 28.2 5.5 28 M168 SG
UHF to 960 MHz
MRF581 0.6 0.06 10 12.5 317-01/2 MO
MRF8372 0.75 0.11 8 12.5 751-04/1 MO
MRF557 1.5 0.23 8 12.5 317D-02/2 MO
BLV99 2 - 9 24 SOT172 PH
SD1420 2.1 0.27 9 24 M122 SG
MRF839 3 0.46 8 12.5 305A-01/1 MO
MRF896 3 0.3 10 24 305-01/1 MO
MRF891 5 0.63 9 24 319-06/2 MO
2SC2932 6 - 7.8 12.5 TO-31E MI
SD1398 6 0.6 10 24 M142 SG
2SC2933 14 3 6.7 12.5 TO-31B MI
SD1400-03 14 1.6 9.5 24 M118 SG
MRF873 15 3 7 12.5 319-06/2 MO
SD1495-03 30 6 7 24 M142 SG
SD1424 30 5.3 7.5 24 M156 SG
MRF897 30 3 10 24 315B-01/1 MO
MRF847 45 16 4.5 12.5 319-06/1 MO
BLV101A 50 - 8.5 26 SOT273 PH
SD1496-03 55 10 7.4 24 M142 SG
MRF898 60 12 7 24 333A-02/1 MO
MRF880 90 12.7 8.5 26 375A-01/1 MO
MRF899 150 24 8 26 375A-01/1 MO
Japanese transistors sorted by frequency
Device Freq Vcc Pin Pout VceO
type (MHZ) (V) (W) (W) (V)
2N5070 30 28.0 1.2 25.0* 30
2N2876 50 28.0 2.0 10.0 60
2N5025 50 13.5 3.5 20.0 75
2N5687 50 12.5 1.5 20
2N5688 50 12.5 5.0 20
2N5689 50 12.5 10.0 40
2N5690 50 12.5 25.0 30
2N5847 50 12.5 .8 8.0 18
2N5848 50 12.5 20.0 24
2N5993 66 12.5 1.0 18.0 18
2Nl5O6 70 28.0 1.3 20
2N4932 70 13.5 3.5 12.0 25
2N4933 70 24.0 3.5 20.0 35
2N5071 70 24.0 3.0 24.0 30
2N5026 80 28.0 2.5 25.0 90
2N5992 88 12.5 .5 7.0 30
2N5102 136 24.0 6.0 15.0 50
2N5994 136 12.5 1.0 15.0 30
2N5682 150 27.0 15.0 90.0 120
2N3553 175 28.0 .25 2.5 40
2N3632 175 28.0 3.5 13.5 40
2N3924 175 13.6 1.0 4.0 18
2N3926 175 13.6 2.0 7.0 18
2N3927 175 13.6 4.0 12.0 18
2N4127 175 25.0 2.5 13.5 40
2N4128 175 24.0 6.0 24.0 40
2N4427 175 12.0 .1 1.0 20
2N5421 175 13.5 .12 1.0 18
2N5422 175 13.5 .31 2.0 18
2N5423 175 13.5 1.2 5.0 18
2N5424 175 13.5 4.1 13.0 18
2N5589 175 13.6 4.5 3.0 18
2N5590 175 13.6 3.3 10.0 18
2N5591 175 13.6 10.0 25.0 18
2N5702 175 12.5 1.5 18
2N5703 175 12.5 3.0 18
2N5704 175 12.5 12.0 18
2N5705 175 12.5 25.0 18
2N5913 175 12.5 .1 2.0 14
2N5995 175 12.5 .75 7.0 14
2N5996 175 5.3 5.3 15.0 18
2N6080 175 12.5 .3 4.0 18
2N6081 175 12.5 3.0 15.0 18
2N6082 175 12.5 6.2 25.0 18
2N6083 175 12.5 7.8 30.0 18
2N5109 200 15.0 .1 1.26 20
2N5215 200 28.0 3.1 10.0 70
2N5643 200 28.0 7.0 40.0 35
2N5943 200 15.0 30
2N3137 250 20.0 .1 .4 20
2N5642 250 28.0 3.0 20.0 35
2N5947 250 20.0 30
2N4073 300 20.0 .25 20
2N5641 300 28.0 1.0 7.0 35
2N3375 400 28.0 1.0 3.0 40
2N3733 400 28.0 4.0 10.0 40
2N3966 400 28.0 .1 10.0 30
2N3948 400 13.6 1.0 5.0 20
2N4040 400 28.0 3.0 8.0 40
2N4041 400 28.0 1.0 3.3 40
2N4440 400 28.0 1.7 5.0 40
2N5016 400 28.0 5.0 15.0 30
2N5090 400 28.0 .2 1.2 30
2N5637 400 28.0 7.0 20.0 35
2N5773 400 26.0 1.5 35
2N5774 400 26.0 8.0 17
2N5775 400 26.0 20.0 35
2N5918 400 28.0 1.5 10.0 30
2N5919 400 28.0 4.0 ll.0 30
2N5636 450 28.0 2.0 7.5 35
2N5644 470 12.5 1.5 1.0 18
2N5645 470 12.5 1.0 4.0 18
2N5646 470 12.5 4.0 12.0 18
2N5697 470 12.5 .25 18
2N5698 470 12.5 1.0 18
2N5699 470 12.5 3.5 18
2N5700 470 12.5 11.0 18
2N5701 470 12.5 20.0 18
2N4440
2N4428 500 28.0 0.7 .75 35
2N5635 500 28.0 .6 2.5 35
2N4429 1000 28.0 .3 1.0 35
2N4430 1000 28.0 .8 2.5 40
2N4431 1000 28.0 1.5 5.0 40
2N5922 1000 28.0 3.2 1.0 35
2N5932 1000 28.0 .79 2.5 35
2N5108 1200 24.0 .32 1.0 55
2NS108A 1200 24.0 .1 1.26 55
* DENOTES PEP
The following is a brief list of filters and Freq.
(+7dBm LO, up to +1dBm RF)
Type Fequency
lo/rf if
GRA-1 5-500 DC-500
GRA-3 .025-200 DC-200
GRA-6 .003-100 DC-100
GRA-8 .0005-10 DC-10
SRA-1 5-500 DC-500
SRA-1TX 5-500 DC-500
SRA-1W 1-750 DC-750
SRA1-1 1-500 DC-500
SRA-2 1-1000 5-500
SRA-2CM 5-1000 DC-1000
SRA-3 .025-200 DC-200
SRA-5 5-1500 10-600
SRA-6 .003-100 DC-100
SRA-8 .0005-10 DC-10
SRA-11 5-2000 10-600
SRA-12 800-1250 50-90
SRA-2000 100-2000 DC-600
SBL-1 1-500 DC-500
SBL-1X 10-1000 5-500
SBL-1Z 10-1000 DC-500
SBL-1-1 0.1-400 DC-400
SBL-3 0.25-200 DC-200
TAK-5 .01-250 DC-250
TAK-5R .05-200 DC-200
TAK-6 .5-600 DC-600
TAK-6R .5-600 DC-600
TAK-7 2-1000 5-500
GRA-1 5-500 DC-500
SRA-1 5-500 DC-500
SRA-1W 1-750 DC-750
SRA1-1 1-500 DC-500
SRA-2 1-1000 5-500
SRA-5 5-1500 10-600
SBL-1 1-500 DC-500
TAK-6 .5-600 DC-600
TAK-7 2-1000 5-500
UHF and SHF gasfet data
Type Freq Gain dB NF dB Idss Gates
MGF1302 4.0GHz 11.0 1.4 50mA 1
MGF1402 4.0GHz 13.0 1.1 50mA 1
MGF0904A 2.5GHz 28.0 vds 8v 1
MGF0905A 2.5GHz 38.0 vds 8v 1
MGF0906A 2.5GHz 37.0 vds 10v 1
MGF0907A 2.5GHz 40.0 vds 10v 1
MFG1100 4.0GHz 12.0 2.5 2
MGF1202 4.0GHz 8.0 1.4 osc up to 55GHz 1
MGF1203 4.0GHz 13.0 1.0 1
MGF1302 4.0GHz 11.0 1.4 1
MGF1303 12.0GHz 8.0 2.0 1
MGF1304 12.0GHz 8.0 1.7 1
MGF1305 12.0GHz 8.0 1.6 1
MGF1402 4.0GHz 13.0 1.1 (2SK274) osc @ 70GHz 1
MGF1412 4.0GHz 13.0 0.8 (2SK275) osc @ 70GHz 1
MGF1403 12.0GHz 10.5 1.8 (2SK276) osc @ 90GHz 1
MGF1404 12.0GHz 10.5 1.6 1
MGF1405 12.0GHz 10.5 1.4 1
MGF1425 12.0GHz 10.5 1.4 1
MGF3000 12.0GHz 12.0 S to KU band mixer 1
MGF1601 8.0GHz 8.0 150mW @ 8GHz low power amp 1
MGF1801 fmAx 45GHz 9dB @ 8GHz 200mW medium power (2SK279) 1
MGF1802 C to X band amp 1.5w power amp 1
MGF2116 0.4W @ 12GHz linear 7dB@12GHz 1
MGF2117 0.4W @ 12GHz linear 7dB@12GHz 1
MGF2124 1W @ 12GHz linear 6dB@12GHz 1
MGF2124F 0.7W @ 14GHz linear 5.5dB@14GHz 1
MFG2124G O.7W @ 14GHz linear 5.5dB@14GHz 1
MGF2148 1.6W @ 12GHz linear 5dB@12GHz 1
MGF2148F 1.2W @ 14GHz linear 4.7dB@14GHz 1
MFG2148G 1.2W @ 14GHz linear 4.7dB@14GHz 1
MGF2172 2.5W @ 8GHz linear 5.5dB@8GHz 1
MGF2205 3.0W @ 6GHz linear 6.5dB@6GHz 1
MGF2312 0.3W @ 14GHz linear 6dB@14GHz 1
MGF2324 0.6W @ 14GHz linear 5.5dB@14GHz 1
MGF2336 0.9W @ 14GHz linear 5dB@14GHz 1
MGF-X34M 2.3W @ 10GHz linear 6dB@10GHz 1
MGF-K30M 1.1W @ 14.5GHz linear 6.5dB@14.5GHz 1
MGF-K33M 2.0W @ 14.5GHz linear 6dB@14.5GHz 1
NE25137 1.0GHz 16.0 1.2 20mA 2
NE25139 1.0GHz 17.0 1.1 20mA 2
AFT10135 4.0GHz 13.0 0.5 100mA 1
AFT10236 4.0GHz 20.0 0.8 130mA 1
AFT10736 4.0GHz 20.0 1.3 140mA 1
AFT13136 12.0GHz 9.5 1.2 50mA 1
AFT13284 4.0GHz 15.0 0.7 50mA 1
AFT13484 12.0GHz 7.5 2.0 50mA 1
AFT13786 10.0GHz 16.5 osc 70mA 1
AFT20135 4.0GHz 12.0 1.1 100mA 1
AFT21186 2.0GHz 19.0 0.6 120mA 1
AFT26884 12.0GHz 18.0 2.2 50mA 1
AFT13036 12.0GHz 17.5 1.1 50mA 1
AFT13336 12.0GHz 17.5 1.4 50mA 1
AFT35076 12.0GHz 10.0 0.75 50mA 1
AFT35376 12.0GHz 10.0 1.0 50mA 1
AFT46101 4.0GHz 27.0 330mA 1
AFT45101 4.0GHz 29.0 600mA 1
AFT44101 4.0GHz 32.0 130mA 1
Some brief data on hf devices 2-30 MHz
Type P [W] Supply Type P [W] Supply
MRF401 25 12V MRF455 60 12V
MRF406 20 12V MRF455A 60 12V
MRF412 80 12V MRF458 80 12V
MRF412A 80 12V MRF460 60 12V
MRF421 100 12V MRF464 80 28V
MRF422 150 28V MRF466 40 28V
MRF426 25 12V MRF475 12 12V
MRF426A 25 12V MRF476 3 12V
MRF427 25 50V MRF477 40 12V
MRF428 150 50V MRF479 15 12V
MRF429 150 50V MRF485 15 28V
MRF433 12 12V MRF492 90 12V
MRF435 150 28V MRF492A 90 12V
MRF448 250 50V PT9847 100 12V
MRF449 30 12V SD1405 75 12V
MRF449A 30 12V SD1407 100 28V
MRF450 50 12V SD1452 80 12V
MRF450A 50 12V 2SC2290 80 12V
MRF453 60 12V 2SC2879 120 12V
MRF453A 60 12V 2SC2509 15 12V
MRF454 80 12V 2SC2097 85 12V
MRF454A 80 12V
SRF2072 65 12V SRF3662 120 12V
SRF3775 75 12V SRF3795 90 12V
SRF3800 110 12V
MRF454A 80 12V
SRF3800 110 12V
Some linear ic's and their function
Type Function
ADCO84 A-D converter
AN829 Dual attenuator
BDM1 Balanced mixer
CX7932 Delay circuit
MF10CN Audio filter
4N25 Opto coupler
78S40 Dual baud rate generator
SO41P Low power FM discriminator
SO42P High level mixer
TL061 Low power fet op-amp
TL062 Dual version of TL061
TL064 Fet quad op-amp
TL071 Fet op-amp
TL072 Dual fet op-amp
TL074 QUAD fet op-amp
TL081 JFET op-amp
TL082 Dual jfet op-amp
TL084 Quad jfet op-amp
TBA120s TV sound if fm
DG202CJ SPST Analogue switch
mAX232 RS232 interface
MB3756 Stabilized power ic
MC3859 FM IF
DG300ACJ Analogue switch
LM301 Op-amp
DG308ACJ Quad analogue switch
M51304L Mic amp
MB501 Divide by 64/65/127/128
MB501L Surface mount version of MB501
MC145146P PLL
NE542 Op-amp low noise
NE544 Servo driver
SL560C Wide band amp
NE564 PLL FM
NE565 Low freq PLL
NE566 LF VCO/Generator
LM567 Tone decoder
NE570 Compander ie compression/expander
LM571 As NE570
NE592 Video amp
MV601 Infra red device
NE602AN Mixer/osc
NE607 FM IF
PB571C Prescaler
SL610 RF/IF amp
TA7230P AF power amp 4w
TC4050 Buffer converter
TC5027 Counter
TC5036 Divider
Transistors parameters
2-30 MHz SSB Transistors
type Pin [W] Pout [W] Supply Gain
MRF476 0.1 3.0 pep 12V 15dB
2N6367 0.36 9.0 12V 14dB
MRF475 1.2 12.0 12V 10dB
MRF432 0.125 12.5 12V 20dB
MRF433 0.125 12.5 12V 20dB
MRF406 1.25 20 12V 12dB
MRF460 2.5 40 12V 12dB
MRF421 10 100 12V 10dB
2N6370 0.62 10 28V 12dB
MFR432 0.125 12.4 12V 20dB
2N5070 1.25 25 28V 13dB
MRF401 1.25 25 28V 13dB
MRF427A 1.56 25 50V 13dB
2N5941 2.0 40 28V 13dB
MRF463 2.53 80 28V 15dB
MRF464 2.53 80 28V 15dB
MRF464A 2.53 80 28V 15dB
MRF422 15 150 28V 10dB
MRF428 7.5 150 50V 13dB
MRF428A 7.5 150 50V 13dB
14-30 amateur Transistors
MRF8003 0.025 0.5 12V 13dB
MRF8004 0.35 3.5 12V 10dB
MRF449 0.30 30 13.6V 10dB
MRF449A 0.30 30 13.6V 10dB
MRF450 4.0 50 13.6V 10dB
MRF450A 4.0 50 13.6V 11dB
MRF453 4.8 60 13.6V 11dB
MRF453A 4.8 60 13.6V 11dB
MRF455 4.8 60 13.6V 11dB
MRF455A 4.8 60 13.6V 11dB
MRF454 5.0 80 12.5V 12dB
MRF454A 5.0 80 12.5V 12dB
130-175 VHF FM Transistors
MRF604A 0.1 1.0 12V 10dB
2N4427 0.1 1.0 12V 10dB
MRF607 0.1 1.75 12V 12.5dB
2N6255 0.5 3.0 12V 7.8dB
2N5589 0.44 3.0 13.6V 8.2dB
MRF237 0.25 4.0 13.6V 12dB
2N6080 0.25 4.0 12V 12dB
2N5590 3.0 10 12V 5.2dB
MRF212 1.25 10 12.5V 9dB
2N6081 3.3 15 12V 6.3dB
MRF221 3.3 15 12V 6.3dB
MRF215 0.33 20 12V 8.2dB
2N5591 9.0 25 13.6V 4.4dB
2N6082 6.0 25 12V 6.2dB
MRF222 6.0 25 12V 6.2dB
2N6083 8.1 30 12V 5.7dB
MRF223 8.1 30 12.5V 5.7dB
2N6084 14.3 40 12.5V 4.5dB
MRF224 14.3 40 12.5V 4.5dB
MRF216 8.5 40 12.5V 6.7dB
MRF243 12.0 60 12.5V 7.0dB
MRF245 18.2 80 12.5V 6.4dB
Information on MMIC Amplifiers
Type Gain @ 1GHz Noise dB P dBm
MAR-1 15.0 6.0 1.5
MAR-2 12.0 6.5 4.5
MAR-3 12.0 6.0 10.0
MAR-4 8.0 7.0 12.5
MAR-5 7.0 6.5 18.0
MAR-6 16.5 3.2 1.5
MAR-7 12.5 5.0 5.5
MAR-8 22.5 3.3 12.5
MAR-0311 12.0 6.0 10.0
MAR-0611 16.5 3.2 1.5
MAR-0711 12.5 5.0 5.5
Type Freq PL(W) Supply Case
BFQ42 VHF 175MHz 2 12.5w TO-39
BFQ43 VHF 175MHz 4 12.5 TO-39 e case
BFS22A HF/VHF 175MHz 4 12.5 TO-39
BFS23A HF/VHF 175MHz 4 28 TO-39
BGY21 UHF 420-470 1.2 12 Module
BGY22 UHF 380-512 2.5 13.5 Module
BGY22A UHF 420-480 2.5 12.5 Module
BGY23 UHF 380-512 7 13.5 Module
BGY23A UHF 420-480 7 12.5 Module
BGY32 VHF 68-88 18 12.5 Module
BGY33 VHF 88-108 18 12.5 Module
BGY35 VHF 132-156 18 12.5 Module
BGY36 VHF 148-174 18 12.5 Module
BLV10 HF/VHF 175 8 12.5 SOT123
BLV11 HF/VHF 175 15 12.5 SOT123
BLV20 HF/VHF 175 8 28 SOT123
BLV21 HF/VHF 175 15 28 SOT123
BLW29 VHF 175 15 12.5 SOT120
BLW31 VHF 175 28 12.5 SOT120
BLW32 BAND4/5 860 .5* 25 SOT122
BLW33 BAND4/5 860 1* 25 SOT122
BLW34 BAND4/5 860 2* 25 SOT122
BLW60 HF/VHF 28/175 30pep 12.5 SOT56
BLW60C HF/VHF 28/175 30pep 12.5 SOT120
BLW64 BAND/3 220 10* 25 SOT56
BLW75 BAND/3 220 14* 25 SOT105
BLW76 HF/VHF 28/108 80pep 28 SOT121
BLW77 HF/VHF 28/87.5 130pep 28 SOT121
BLW78 HF/VHF 28/150 100pep 28 SOT121
BLW79 VHF/UHF 175/470 2 12.5 SOT122
BLW80 VHF/UHF 175/470 4 12.5 SOT122
BLW81 VHF/UHF 175/470 10 12.5 SOT122
BLW82 UHF 470 30 12.5 SOT119
BLW83 HF 28 30pep 28 SOT123
BLW84 VHF 175 25 28 SOT123
BLW85 HF/VHF 28/175 30pep 12.5 SOT123
BLW86 HF/VHF 28/175 45pep 28 SOT123
BLW87 HF/VHF 175 25 12.5 SOT123
BLW98 BAND4/5 860 3.5* 25 SOT122
BLX13 HF 28 25pep 28 SOT56
BLX13C HF 28 25pep 28 SOT120
BLX14 HF 28 50pep 28 SOT56
BLX15 HF/VHF 28/108 150pep 50 SOT56
BLX39 HF/VHF 28/175 42.5pep 28 SOT120
BLX65 VHF/UHF 175/470 2 12.5 TO-39
BLX66 VHF/UHF 175/470 2.5 12.5 SOT48/4
BLX67 VHF/UHF 175/470 2.5 12.5 SOT48/3
BLX68 VHF/UHF 175/470 7 12.5 SOT48/3
BLX69A VHF/UHF 175/470 17 12.5 SOT48/2
BLX91A UHF 470 1 28 SOT48/3
BLX92A UHF 470 2.5 28 SOT48/3
BLX93A UHF 470 7 28 SOT48/3
BLX94A UHF 470 25 28 SOT48/2
BLX95 UHF 470 40 28 SOT56
BLX96 BAND4/5 860 .5* 25 SOT48/3
BLX97 BAND4/5 860 1* 25 SOT48/3
BLX98 BAND4/5 860 3.5* 25 SOT48/2
BLY33 VHF 175 3 28 TO-39
BLY34 VHF 175 3 13.8 TO-39
BLY35 VHF 175 13 24 TO-60
BLY36 VHF 175 13 13.8 TO-60
* = Pk sync
Microwave Transistors for amateur use
Type Muf Gain dB Noise dB
AT00511 2.7GHz 12.5 1.8
AT41411 3.5GHz 16.5 1.4
AT41511 4.0GHz 16.5 1.4
AT41486 4.0GHz 17.5 1.4
AT01635 2.2GHz 22.0 3.0
AT42086 3.5GHz 17.0 1.4
AT60585 4.0GHz 17.0 1.4
AT60111 1.9GHz 11.5 1.4
AT60211 2.1GHz 14.0 1.5
INA02186 1.0GHz 30.0 1.8
INA03184 2.4GHz 25.0 2.6
INA10386 2.4GHz 25.0 3.8
VHF/UHF brief data
Type P Freq Gain dB Type P Freq Gain dB
MRF207 1 225MHz 8.2 MRF627 0.5 512MHz 10.0
MRF208 10 225MHz 10 MRF629 2 512MHz 8.0
MRF212 10 174MHz 9 MRF630 3 512MHz 9.5
MRF220 4 174MHz 12 MRF641 15 512MHz 7.8
MRF221 15 175MHz 6.3 MRF644 25 512MHz 6.2
MRF222 25 175MHz n/k MRF646 40 512MHz 4.8
MRF224 40 175MHz 4.5 MRF648 60 512MHz 4.4
MRF226 13 225MHz 9.0 MRF652 5 512MHz 10.0
MRF227 3 225MHz 13.5 MRF653 10 512MHz 7.0
MRF229 1.5 88MHz 10.0 MRF654 15 512MHz 7.8
MRF231 3.5 88MHz 10.0 MRF660 7 512MHz 5.4
MRF233 15 88MHz 10.0 MRF752 2.5 512MHz 8.0
MRF234 25 88MHz 9.5 MRF754 8 512MHz 6.0
MRF237 4 174MHz 12.0 MRF843 15 960MHz 7.0
MRF238 30 174MHz 9.0 MRF843F 15 960MHz 7.0
MRF239 30 174MHz 10.0 MRF846 40 960MHz 7.0
MRF240 40 174MHz 9.0 MRF873 15 960MHz 7.0
MRF240A 40 174MHz 9.0 MRF1946 30 174MHz 10.0
MRF245 80 174MHz 6.4 MRF1946A 30 174MHz 10.0
MRF247 75 174MHz 7.0 MRF2628 15 225MHz 12.0
MRF248 80 174MHz 11.3 SD1278-1 40 174MHz 8.0
MRF250 50 174MHz 4.4 2N3553* 2.5 174MHz 10.0
MRF260 5 174MHz 10.0 2N3866* 1 400MHz 10.0
MRF261 10 174MHz 5.2 2N4427 1 174MHz 10.0
MRF262 15 174MHz 6.3 2N5090 2 174MHz 13.0
MRF264 30 174MHz 5.2 2N5589 3 174MHz 8.2
MRF309* 50 400MHz 7.0 2N5590 10 174MHz 5.2
MRF314* 30 200MHz 10.0 2N5591 25 174MHz 4.4
MRF314A* 30 200MHz 10.0 2N5641* 7 174MHz 8.4
MRF315* 45 200MHz 9.0 2N5642* 20 200MHz 8.2
MRF315A* 45 200MHz 9.0 2N5643* 40 200MHz 7.6
MRF316* 80 200MHz 10.0 2N5646 10 512MHz 6.0
MRF317* 100 200MHz 9.0 2N5944 2.0 512MHz 9.0
MRF321* 10 500MHz 12.0 2N5945 4 512MHz 8.0
MRF327* 80 400MHz 7.3 2N5946 10 512MHz 6.0
MRF340* 8 200MHz 13.0 2N6080 4 174MHz 12.0
MRF492 70 50MHz 11.0 2N6081 15 174MHz 6.3
MRF497 40 50MHz 10.0 2N6082 25 174MHz 6.2
MRF515 0.75 512MHz 8.0 2N6083 30 174MHz 5.7
MRF555 1.5 512MHz 10.0 2N6084 40 174MHz 4.5
MRF557 1.5 960MHz 8.0 2N6097PNP 40 174MHz n/k
MRF559 0.5 960MHz 8.0 2N6255 3 174MHz 7.8
MRF607 1.75 174MHz 11.5
* = 28v device
Mosfets
Power mosfets N-channel 1.5-30MHz
Type P out (W) Pin (W) Gain dB Supply
MRF138 30 0.6 17 28V
MRF140 150 4.7 15 28V
MRF148 30 0.5 18 50V
MRF150 150 2.9 17 50V
MRF153 300 6.0 17 50V
MRF154 600 12 17 50V
MRF156 600 6.0 20 50V
Power mosfets AM/FM 2.0-150MHz
Type P out (W) P in (W) Gain dB Supply
MRF134 5.0 0.4 11 28V
MRF136 15 0.75 13 28V
MRF136Y 30 1.9 12 28V
MRF137 30 1.9 12 28V
MRF141G 300 13 14 28V
MRF151G 600 5 17 50V
MRF171 45 2.8 12 28V
MRF172 80 8.0 10 28V
MRF174 125 15.8 9 28V
MRF175GV 200 8.0 14 28V
Power mosfets UHF 2-400MHz
Type P out(w) P in (W) Gain dB Supply
MRF161 5.0 0.4 11 28V
MRF162 15 1.2 11 28V
MRF163 25 2.5 10 28V
MRF175GU 150 9.5 12 28V
Power Modules
VHH-UHF Power Modules pt1
Type Freq P in P out(W) Class
PF0011 860-920 3mW 13 AB
SAU11 902-905 200mW 8 C
SAU12 870-915 1mW 8 C
SAU16H 450-470 150mW 5 AB
SAU16SH 490-512 150mW 5 AB
SAU17 870-915 1mW 8 C
SAU27AH(H) 490-512 200mW 32 n/k
SAU27M 450-490 200mW 32 n/k
SAV6 154-162 200mW 28 C
SAV7 144-148 200mW 28 C
SAV12 144-148 150mW 5 AB
SAV15 220-225 200mW 30 C
SAV16H 150-160 150mW 5 n/k
SAV16L 135-150 150mW 5 n/k
SAV16SH 174 150mW 5 n/k
SAV17 144-148 400mW 50 C
SAV22A 144-148 15mW 7 C
SAV24 144-148 400mW 50 C
BGY45B 148-175 150mW 28 C
K43 898-941 300mW 13 C
M57704EL 335-360 200mW 13 C
M57704L 400-420 200mW 13 C
M57704M 430-450 200mW 13 C
M57704H 450-470 200mW 13 C
M57704SH 490-512 200mW 13 C
M57704UH 470-490 200mW 13 C
M57706L 135-145 Gain 16dB 8 C
M57706 145-175 200mW 8 C
M57710A 156-160 200mW 25 C
M57713 144-148 200mW 10 AB
M57714 450-470 100mW 7 C
M57714EL 335-360 100mW 7 C
M57714M 430-450 100mW 7 C
M57714UH 470-490 100mW 7 C
M47715 144-148 200mW 10 C
M57716 430-450 200mW 10 AB
M57719 145-175 200mW 17 C
M57719N 142-163 200mW 10 C
M57719L 135-145 Gain 19dB 14 C
M57721M 400-450 10mW 7 n/k
M57726 144-146 200mW 40 C
M57726R 144-148 400mW 43 C
M57727 144-148 200mW 25 AB
M57729 430-450 600mW 30 C
M57729EL 335-360 200mW 30 C
M57729H 450-470 600mW 30 C
M57729SH 490-512 300mW 30 C
M57732 144-175 20mW 7 AB
M57732L 135-160 20mW 5 AB
M57735 50-54 200mW 10 AB
M47737 144-148 200mW 25 C
M57737R 144-148 200mW 25 C
M57739C 824-849 30mW 6 C
M57741L 148-160 200mW 25 C
M57741M 156-168 250mW 25 C
M57741H 164-175 300mW 25 C
M57744 905-915 400mW 13 C
M57745 430-450 300mW 25 AB
M57747 144-148 200mW 10 C
M57755 806-866 100mW 10 C
M57759 890-915 2mW 200mW n/k
M57762 1240-1300 1000mW 20 AB
M57764 800-830 400mW 15 C
M57774 220-225 300mW 30 C
M57782 825-851 1mW 7 n/k
M57783L 135-160 50mW 7 AB
VHF-UHF Power modules pt2
M57785L 135-150 50mW 7 AB
M57785M 150-162 50mW 7 AB
M57785H 162-174 50mW 7 AB
M57786M 430-470 2mW 7 AB
M57787 1240-1300 10mW 3 C
M57788H 450-470 400mW 45 C
M57788L 400-430 400mW 45 C
M57788M 430-450 400mW 45 C
M57788MR 430-450 400mW 45 C
M57791 890-915 1mW 7 n/k
M57792 806-870 400mW 20 n/k
M57796H 150-175 300mW 7 AB
M57796mA 144-148 200mW 7 AB
M57797H 450-470 200mW 7 AB
M57797mA 440-450 100mW 7 AB
M67702 150-175 5W 60 n/k
M67703H 450-470 10W 50 C
M67703SH 490-512 10W 50 C
M67703UH 470-490 10W 50 C
M67705L 400-430 20mW 7 AB
M67705M 430-470 20mW 7 AB
M67705H 470-512 20mW 7 AB
M67709 430-470 10mW 13 C
M67709L 350-390 10mW 13 C
M67709SH 490-512 10mW 13 C
M67710H 150-175 50mW 7 n/k
M67711 1240-1300 1000mW 16 AB
M67712 220-225 200mW 30 AB
M67715 1240-1300 10mW 1.5 AB
M67723 220-225 20mW 7 n/k
M67727 144-148 500mW 65 AB
M67728 430-450 14W 65 AB
M67730L 175-200 300mW 30 C
M67736 935-941 5mW 15 n/k
M67742 68-88 500mW 30 C
M67743H 77-88 30mW 7 AB
M67743L 68-81 30mW 7 n/k
M67748H 150-175 20mW 7 n/k
M67748L 144-148 20mW 7 n/k
M67748LR 135-150 20mW 7 n/k
M67749M 430-450 20mW 7 AB
M67749MR 430-450 20mW 7 AB
M67754 824-849 1mW 6 n/k
M67755H 150-175 2mW 7 n/k
M67755L 134-150 2mW 7 n/k
M67760L 806-870 400mW 25 n/k
M67764 940-960 7mW 12 n/k
M67766A 820-850 4mW 10 AB
M67769C 890-915 1mW 15 AB
M67776H 896-941 4mW 8 n/k
M67776L 806-870 4mW 8 n/k
M67785H 160-230 30mW 7 AB
M67796 1240-1300 10mW 1.5 n/kCharacter (Serial Code) 100-999 Device for consumer or entertainment use Y## Industrial service (No letter Z), ## is a W## Registration number from 10_99
2 SC 82DA
1 23 4 5
E P-gate thyristor
F N-gate thyristor
J P-channel FET
K N-channel FET
starting with 11
50 MHz
VHF to 175 MHz
220 MHz
UHF to 512 MHz
UHF to 960 MHz
2N5943 200 15.0 30
2N5947 250 20.0 30
2N4440
* DENOTES PEP
Type Fequency
lo/rf if
GRA-1 5-500 DC-500
SRA-1 5-500 DC-500
SRA-1W 1-750 DC-750
SRA1-1 1-500 DC-500
SRA-2 1-1000 5-500
SRA-5 5-1500 10-600
SBL-1 1-500 DC-500
TAK-6 .5-600 DC-600
TAK-7 2-1000 5-500
GRA-1 5-500 DC-500
SRA-1 5-500 DC-500
SRA-1W 1-750 DC-750
SRA1-1 1-500 DC-500
SRA-2 1-1000 5-500
SRA-5 5-1500 10-600
SBL-1 1-500 DC-500
TAK-6 .5-600 DC-600
TAK-7 2-1000 5-500
MRF454A 80 12V
SRF3800 110 12V
MRF454A 80 12V
SRF3800 110 12V
Type Function
BDM1 Balanced mixer
MF10CN Audio filter
4N25 Opto coupler
TL071 Fet op-amp
TL081 JFET op-amp
MC3859 FM IF
LM301 Op-amp
M51304L Mic amp
MC145146P PLL
NE544 Servo driver
NE564 PLL FM
NE565 Low freq PLL
LM567 Tone decoder
LM571 As NE570
NE592 Video amp
NE602AN Mixer/osc
NE607 FM IF
PB571C Prescaler
SL610 RF/IF amp
TC5027 Counter
TC5036 Divider
MAR-1 15.0 6.0 1.5
MAR-2 12.0 6.5 4.5
MAR-3 12.0 6.0 10.0
MAR-4 8.0 7.0 12.5
MAR-5 7.0 6.5 18.0
MAR-6 16.5 3.2 1.5
MAR-7 12.5 5.0 5.5
MAR-8 22.5 3.3 12.5
* = Pk sync
VHF/UHF brief data
* = 28v device
Mosfets
Power Modules
关键词: 各频段发 参数大全
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
