启动信息如下:
U-Boot SPL 2011.09-00000-gf63b270-dirty (Nov 14 2011 - 10:37:14)
Texas Instruments Revision detection unimplemented
No AC power, disabling frequency switch
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2011.09-00000-gf63b270-dirty (Nov 14 2011 - 10:37:14)
I2C: ready
DRAM: 256 MiB
No daughter card present
NAND: HW ECC Hamming Code selected
nand_get_flash_type: unknown NAND device: Manufacturer ID: 0x10, Chip ID: 0x10
No NAND device found!!!
0 MiB
MMC: OMAP SD/MMC: 0
*** Warning - readenv() failed, using default environment
Net: cpsw
Hit any key to stop autoboot: 0
SD/MMC found on device 0
reading uEnv.txt
33 bytes read
Loaded environment from uEnv.txt
Importing environment from mmc ...
reading uImage
3031456 bytes read
## Booting kernel from Legacy Image at 80007fc0 ...
Image Name: Angstrom/3.1/beaglebone
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3031392 Bytes = 2.9 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
XIP Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.067560] omap_l3_smx omap_l3_smx.0: couldn't find resource
[ 0.244350] _omap_mux_get_by_name: Could not find signal leds-gpio
[ 0.313839] omap2_set_init_voltage: unable to get clk dpll1_ck
[ 0.319996] omap2_set_init_voltage: unable to set vdd_mpu_iva
[ 0.326141] omap2_set_init_voltage: unable to get clk l3_ick
[ 0.332141] omap2_set_init_voltage: unable to set vdd_core
systemd-fsck[61]: Angstrom-Cloud9-: clean, 27400/874496 files, 774461/3494137 blocks
[ 14.579399] /usr/sbin/crond[91]: (CRON) INFO (Syslog will be used instead of sendmail.): No such file or directory
[ 16.118728]
[ 16.118738] CPSW phy found : id is : 0x7c0f1
[ 16.125685] PHY 0:01 not found
.---O---.
| | .-. o o
| | | __ | ---'| '--.| .-'| | |
The Angstrom Distribution beaglebone ttyO0
Angstrom v2011.10-core - Kernel 3.1.0+
beaglebone login:
输入root,进入系统后也点个灯玩玩吧:
点亮usr1,不要点usr0哈,usr0已经被linux系统用作系统心跳了。
root@beaglebone:~# echo 1 > /sys/class/leds/beaglebone::usr1/brightness
关闭usr1
root@beaglebone:~# echo 0 > /sys/class/leds/beaglebone::usr1/brightness
使用交叉网线连接BeagleBone板子和PC机:
设置板子IP:
root@beaglebone:~# ifconfig eth0 192.168.1.100
root@beaglebone:~# ping 192.168.1.124
PING 192.168.1.124 (192.168.1.124) 56(84) bytes of data.
64 bytes from 192.168.1.124: icmp_req=1 ttl=64 time=2.20 ms
64 bytes from 192.168.1.124: icmp_req=2 ttl=64 time=0.394 ms
64 bytes from 192.168.1.124: icmp_req=3 ttl=64 time=0.267 ms
64 bytes from 192.168.1.124: icmp_req=4 ttl=64 time=0.369 ms
另外一张卡的启动信息,有些不一样耶,加入了启动的时间打印
U-Boot SPL 2011.09 (Nov 04 2011 - 21:43:12)
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2011.09 (Nov 04 2011 - 21:39:19)
I2C: ready
DRAM: 256 MiB
WARNING: Caches not enabled
0 MiB
MMC: OMAP SD/MMC: 0
Net: cpsw
reading uEnv.txt
** Unable to read "uEnv.txt" from mmc 0:1 **
reading uImage
2870524 bytes read
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Arago/3.0+3.1-rc8-psp04.06.00.02
Data Size: 2870460 Bytes = 2.7 MiB
Loading Kernel Image ... OK
OK
Starting kernel ...
[ 0.000000] Linux version 3.1.0-rc8 (jenkins@sdit-build01) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #1 Sun Oct 30 06:40:25 CDT 2011
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: am335xevm
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES1.0 (neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait ip=dhcp
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 256MB = 256MB total
[ 0.000000] Memory: 253928k/253928k available, 8216k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffa00000 - 0xffe00000 ( 4 MB)
[ 0.000000] vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc051e000 (5208 kB)
[ 0.000000] .init : 0xc051e000 - 0xc0554000 ( 216 kB)
[ 0.000000] .data : 0xc0554000 - 0xc059e200 ( 297 kB)
[ 0.000000] .bss : 0xc059e224 - 0xc05ca200 ( 176 kB)
[ 0.000000] NR_IRQS:396
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[ 0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000242] Calibrating delay loop... 498.89 BogoMIPS (lpj=2494464)
[ 0.058626] pid_max: default: 32768 minimum: 301
[ 0.058790] Security Framework initialized
[ 0.058869] Mount-cache hash table entries: 512
[ 0.059322] CPU: Testing write buffer coherency: ok
[ 0.064048] print_constraints: dummy:
[ 0.064322] NET: Registered protocol family 16
[ 0.064526] GPMC revision 6.0
[ 0.065667] OMAP GPIO hardware version 0.1
[ 0.066626] omap_l3_smx omap_l3_smx.0: couldn't find resource
[ 0.066741] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.069308] platform omap_i2c.1: alias fck already exists
[ 0.070031] platform omap2_mcspi.1: alias fck already exists
[ 0.070147] platform omap2_mcspi.2: alias fck already exists
[ 0.078962] bio: create slab <bio-0> at 0
[ 0.079999] SCSI subsystem initialized
[ 0.080924] usbcore: registered new interface driver usbfs
[ 0.081070] usbcore: registered new interface driver hub
[ 0.081234] usbcore: registered new device driver usb
[ 0.081593] registerd cppi-dma Intr @ IRQ 17
[ 0.081611] Cppi41 Init Done Qmgr-base(d083a000) dma-base(d0838000)
[ 0.081625] Cppi41 Init Done
[ 0.098701] omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
[ 0.099578] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.100155] Bluetooth: Core ver 2.16
[ 0.100244] NET: Registered protocol family 31
[ 0.100260] Bluetooth: HCI device and connection manager initialized
[ 0.100281] Bluetooth: HCI socket layer initialized
[ 0.100296] Bluetooth: L2CAP socket layer initialized
[ 0.100329] Bluetooth: SCO socket layer initialized
[ 0.100530] Switching to clocksource gp timer
[ 0.108703] Switched to NOHz mode on CPU #0
[ 0.109486] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.109661] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[ 0.110731] musb-hdrc musb-hdrc.0: USB OTG mode controller at d080a000 using DMA, IRQ 18
[ 0.111000] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[ 0.111954] musb-hdrc musb-hdrc.1: USB OTG mode controller at d080c800 using DMA, IRQ 19
[ 0.112320] NET: Registered protocol family 2
[ 0.112544] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.112906] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.113131] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.113267] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.113285] TCP reno registered
[ 0.113302] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.113334] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.113572] NET: Registered protocol family 1
[ 0.113923] RPC: Registered named UNIX socket transport module.
[ 0.113940] RPC: Registered udp transport module.
[ 0.113953] RPC: Registered tcp transport module.
[ 0.113966] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.114236] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.114319] omap_init_opp_table: no hwmod or odev for iva, [8] cannot add OPPs.
[ 0.125674] VFS: Disk quotas dquot_6.5.2
[ 0.125759] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.126461] JFFS2 version 2.2. (NAND) (SUMMARY) 漏 2001-2006 Red Hat, Inc.
[ 0.126844] msgmni has been set to 495
[ 0.127767] io scheduler noop registered
[ 0.127785] io scheduler deadline registered
[ 0.127872] io scheduler cfq registered (default)
[ 0.128531] Could not set LED4 to fully on
[ 0.129716] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.131029] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[ 0.668125] console [ttyO0] enabled
[ 0.672198] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[ 0.679876] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[ 0.687594] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[ 0.695322] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[ 0.703015] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[ 0.717459] brd: module loaded
[ 0.724507] loop: module loaded
[ 0.727903] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 0.790576] No daughter card found
[ 0.794214] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 0.809522] Board name: A335BONE
[ 0.812939] Board version: 00A3
[ 0.816250] The board is a AM335x Beaglebone.
[ 0.821492] platform omap_hsmmc.0: alias fck already exists
[ 0.828515] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 0.835442] omap2-nand driver initializing
[ 0.839883] OneNAND driver initializing
[ 0.890610] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[ 0.897136] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[ 0.904167] davinci_mdio.0: probed
[ 0.907759] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver SMSC LAN8710/LAN8720
[ 0.916719] usbcore: registered new interface driver cdc_ether
[ 0.922958] usbcore: registered new interface driver cdc_subset
[ 0.929248] Initializing USB Mass Storage driver...
[ 0.934514] usbcore: registered new interface driver usb-storage
[ 0.940861] USB Mass Storage support registered.
[ 0.945791] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 0.951520] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 0.959462] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.966655] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.974278] usb usb1: Product: MUSB HDRC host driver
[ 0.979513] usb usb1: Manufacturer: Linux 3.1.0-rc8 musb-hcd
[ 0.985494] usb usb1: SerialNumber: musb-hdrc.1
[ 0.990877] hub 1-0:1.0: USB hub found
[ 0.994855] hub 1-0:1.0: 1 port detected
[ 0.999683] mousedev: PS/2 mouse device common for all mice
[ 1.006422] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
[ 1.013200] omap_rtc: already running
[ 1.017120] i2c /dev entries driver
[ 1.021654] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.028067] Bluetooth: HCI UART driver ver 2.2
[ 1.032791] Bluetooth: HCI H4 protocol initialized
[ 1.037842] Bluetooth: HCILL protocol initialized
[ 1.044494] usbcore: registered new interface driver usbhid
[ 1.050378] usbhid: USB HID core driver
[ 1.054901] usbcore: registered new interface driver snd-usb-audio
[ 1.062333] ALSA device list:
[ 1.065462] No soundcards found.
[ 1.069056] nf_conntrack version 0.5.0 (3967 buckets, 15868 max)
[ 1.076031] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.081813] TCP cubic registered
[ 1.085221] NET: Registered protocol family 17
[ 1.090183] Bluetooth: RFCOMM TTY layer initialized
[ 1.095385] Bluetooth: RFCOMM socket layer initialized
[ 1.100824] Bluetooth: RFCOMM ver 1.11
[ 1.104778] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.110376] Bluetooth: BNEP filters: protocol multicast
[ 1.115898] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.122344] Registering the dns_resolver key type
[ 1.127400] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 1.135517] ThumbEE CPU extension supported.
[ 1.140884] omap2_set_init_voltage: unable to get clk dpll1_ck
[ 1.147036] omap2_set_init_voltage: unable to set vdd_mpu_iva
[ 1.153129] omap2_set_init_voltage: unable to get clk l3_ick
[ 1.159097] omap2_set_init_voltage: unable to set vdd_core
[ 1.166267] Detected MACID=40:5f:c2:76:95:e0
[ 1.171784] omap_rtc omap_rtc: setting system clock to 2000-01-01 01:42:34 UTC (946690954)
[ 1.183833]
[ 1.183841] CPSW phy found : id is : 0x7c0f1
[ 1.190662] PHY 0:01 not found
[ 1.271668] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 1.282736] mmc0: new high speed SDHC card at address 1234
[ 1.289089] mmcblk0: mmc0:1234 SA04G 3.63 GiB
[ 1.296308] mmcblk0: p1 p2 p3
[ 4.181137] PHY: 0:00 - Link is Up - 100/Full
[ 4.210587] Sending DHCP requests ...... timed out!
[ 79.502552] IP-Config: Reopening network devices...
[ 79.510323]
[ 79.510329] CPSW phy found : id is : 0x7c0f1
[ 79.517223] PHY 0:01 not found
[ 81.501298] PHY: 0:00 - Link is Up - 100/Full
[ 81.520586] Sending DHCP requests ...... timed out!
[ 168.812465] IP-Config: Auto-configuration of network failed.
[ 168.825370] kjournald starting. Commit interval 5 seconds
[ 169.345186] EXT3-fs (mmcblk0p2): using internal journal
[ 169.350740] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[ 169.358046] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 169.364833] Freeing init memory: 216K
INIT: version 2.86 booting
Please wait: booting...
Error opening /dev/fb0: No such device
Starting udev
[ 169.952594] udevd (76): /proc/76/oom_adj is deprecated, please use /proc/76/oom_score_adj instead.
[ 174.524983] kjournald starting. Commit interval 5 seconds
[ 175.116274] EXT3-fs (mmcblk0p3): using internal journal
[ 175.121851] EXT3-fs (mmcblk0p3): mounted filesystem with ordered data mode
[ 177.167713] alignment: ignoring faults is unsafe on this CPU. Defaulting to fixup mode.
Remounting root file system...
Caching udev devnodes
ALSA: Restoring mixer settings...
/usr/sbin/alsactl: load_state:1625: No soundcards found...
Configuring network interfaces... [ 184.827430]
[ 184.827445] CPSW phy found : id is : 0x7c0f1
[ 184.834384] PHY 0:01 not found
udhcpc (v1.13.2) started
Sending discover...
[ 186.821334] PHY: 0:00 - Link is Up - 100/Full
Sending discover...
Sending discover...
No lease, forking to background
done.
Setting up IP spoofing protection: rp_filter.
Fri Nov 4 07:52:00 UTC 2011
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting Hardware abstraction layer hald
Creating Dropbear SSH server RSA host key.
Will output 1024 bit rsa secret key to '/etc/dropbear/dropbear_rsa_host_key'
Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgwCnlSedLCIvAEcPiZTFEeeKJ19shYIfTGIOtoeCPIBU8XArtaE9W7zuweLMzk/4WdAL9e9MF+NcJjbVAP2pytJHEETsomxWl0fziIeWQMa6RegvaJPgqLa4a1P1FSbmafUtbbjOmUU4MXMM6ZFqWfK8yMswNEt63Z3hscrbD37iuJYz root@am335x-evm
Fingerprint: md5 46:b2:f9:7f:87:60:e0:a0:e8:70:ca:5b:0c:b7:61:7d
Starting Dropbear SSH server: dropbear.
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpd.
Starting Lighttpd Web Server: lighttpd.
2011-11-04 07:52:01: (log.c.166) server started
[ 204.433527] gadget: Mass Storage Function, version: 2009/09/11
[ 204.439795] gadget: Number of LUNs=2
[ 204.443753] lun0: LUN: removable file: /dev/mmcblk0p1
[ 204.449178] lun1: LUN: removable file: /dev/mmcblk0p3
[ 204.454649] gadget: Mass Storage Gadget, version: 2009/09/11
[ 204.460737] gadget: userspace failed to provide iSerialNumber
[ 204.466915] gadget: g_mass_storage ready
[ 204.471207] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 204.476891] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[ 204.484874] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 204.492056] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 204.499673] usb usb2: Product: MUSB HDRC host driver
[ 204.504923] usb usb2: Manufacturer: Linux 3.1.0-rc8 musb-hcd
[ 204.510902] usb usb2: SerialNumber: musb-hdrc.0
[ 204.516400] hub 2-0:1.0: USB hub found
[ 204.520376] hub 2-0:1.0: 1 port detected
[ 205.483441] gadget: high speed config #1: Linux File-Backed Storage
NOTICE: This file system contains the followin GPLv3 packages:
binutils-dev
gdbserver
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
Starting Matrix GUI application.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am335x-evm ttyO0
Arago 2011.09 am335x-evm ttyO0
am335x-evm login:
