电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 51摇摇棒
共5条 1/1 1 跳转至
51摇摇棒
2014-09-10 18:23:21     打赏
对发光的东西比较感兴趣,然后做了一个摇摇棒。
附上程序
#include <AT89X52.h>
#define uchar unsigned char
#define uint unsigned int    //宏定义
#define KEY P3_7      //定义画面切换按键
uchar KY;    //KY作用在后面说明
uchar disp;     //显示汉字指针
uchar pic=0,num=0;     //pic为按键次数;num为中断次数
uchar code love[] = {
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x3F,0x00,0x20,0x00,0x20,0x00,0x20,
0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x0F,
0x04,0x10,0x02,0x20,0x02,0x20,0x02,0x20,0x02,0x20,0x04,0x10,0xF8,0x0F,0x00,0x00,
0x00,0x00,0x00,0x00,0xFE,0x07,0x00,0x08,0x00,0x10,0x00,0x20,0x00,0x20,0x00,0x10,
0x00,0x08,0xFE,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x3F,0x82,0x20,0x82,0x20,
0x82,0x20,0x82,0x20,0x82,0x20,0x82,0x20,0x82,0x20,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*LOVE*/
uchar code loveyou[] = {
0x78,0x00,0xFC,0x00,0xFE,0x01,0xFE,0x03,0xFE,0x07,0xFE,0x0F,0xFE,0x1F,0xFC,0x3F,
0xF8,0x7F,0xFC,0x3F,0xFE,0x1F,0xFE,0x0F,0xFE,0x07,0xFE,0x03,0xFE,0x01,0xFC,0x00,
0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*心形图案*/
uchar code hehe[] = {
0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x01,0x40,0x01,0xC0,0x01,0x00,0x00,0x00,0x00,
0xF0,0x0F,0x08,0x10,0x04,0x20,0x00,0x00,0x00,0x00,0xF0,0x3F,0x08,0x00,0x04,0x00,
0x04,0x00,0x04,0x00,0x08,0x00,0xF0,0x3F,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x20,
0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,0xF0,0x3F,0x08,0x00,0x04,0x00,
0x04,0x00,0x04,0x00,0x08,0x00,0xF0,0x3F,0x00,0x00,0x00,0x00,0x04,0x20,0x08,0x10,
0xF0,0x0F,0x00,0x00,0x00,0x00,0xC0,0x01,0x40,0x01,0xC0,0x01,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*呵呵o(∩_∩)o图案*/
unsigned char code hanzi[] = {
   0x20,0x04,0x20,0x04,0x22,0x42,0x22,0x82,
   0xFE,0x7F,0x21,0x01,0x21,0x01,0x20,0x10,
   0x20,0x10,0xFF,0x08,0x20,0x07,0x22,0x1A,
   0xAC,0x21,0x20,0x40,0x20,0xF0,0x00,0x00,/*"我",0*/
   0x00,0x40,0x40,0x20,0xB2,0xA0,0x96,0x90,
   0x9A,0x4C,0x92,0x47,0xF6,0x2A,0x9A,0x2A,
   0x93,0x12,0x91,0x1A,0x99,0x26,0x97,0x22,
   0x91,0x40,0x90,0xC0,0x30,0x40,0x00,0x00,/*"爱",1*/
/* (16 X 16 , 宋体 ) */
   0x80,0x00,0x40,0x00,0xF0,0x7F,0x2C,0x00,
   0x43,0x10,0x20,0x0C,0x98,0x03,0x0F,0x21,
   0x0A,0x40,0xE8,0x3F,0x08,0x00,0x88,0x00,
   0x28,0x03,0x1C,0x1C,0x08,0x08,0x00,0x00,/*"你",2*/
   0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x5F,
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"!",3*/
/*****函数声明*****/
void display1_ltor(void);
void display2_ltor(void);
void display2_rtol(void);
void display3(void);
void display4(void);
/*****n(us)延时子程序*****/
void DelayUs(uint N)
 uint x;
 for(x=0; x<=N;x++);
/*****中断服务程序*****/
void intersvr0(void) interrupt 0
 KY=~KY;      //每个摇动来回水银开关会在摆幅两端分别产生下降沿中断,只提取其中一次(从左向右摇才显示)
 if(KY==0)
   num++;     //计算中断次数
   switch(pic)      //选择画面
        case 0:{display1_ltor();}break;
    case 1:{display2_ltor();}break;
    case 2:{display3();}break;
    case 3:{display4();}break;
    default:{display1_ltor();}
/*****显示子程序1(汉字)*****/
 uchar i;
 if(num>10){disp++;num=0;}     //12个汉字分为3次显示完(每次显示4个),每中断10次切换
 if(disp>2)disp=0;
  DelayUs(5200);     //此处延时时间依各硬件差别而各不相同,试着调整使得显示内容居中即可
 for(i=0;i<64;i++)
     P0=~hanzi[disp*128+i*2];
     P2=~hanzi[disp*128+i*2+1];
     DelayUs(100);
/*****显示子程序2(LOVE)*****/
 uchar i;
 DelayUs(4000);
 for(i=0;i<64;i++)
     P0=~love[i*2];
     P2=~love[i*2+1];
     DelayUs(140);
/*****显示子程序3(心形图案)*****/
void display3(void)
 uchar i;
  DelayUs(4000);
 for(i=0;i<64;i++)
     P0=~loveyou[i*2];
     P2=~loveyou[i*2+1];
     DelayUs(120);
/*****显示子程序4(呵呵o(∩_∩)o图案)*****/
void display4(void)
 uchar i;
 DelayUs(4000);
 for(i=0;i<64;i++)
     P0=~hehe[i*2];
     P2=~hehe[i*2+1];
     DelayUs(120);
/*****主函数*****/
void main(void)
 IT0=1;
 EX0=1;
 EA=1;      //开中断,下降沿中断
 KY=0;
 KEY=1;
 while(1)     //主程序中只检测按键
  if(KEY==0)     //画面切换键按下
     DelayUs(10000);     //按键去抖
     if(KEY==0);
     pic++;
     while(KEY==0);
  if(pic>3)pic=0;
/*****END*****/
秀图
关键词: 摇摇棒     电路图     程序
2014-09-10 19:00:18     打赏
有效果图吗?来个效果图开开眼
2014-09-11 16:13:15     打赏
同求效果图
2014-09-11 16:47:06     打赏
效果图,看着不是特别明显,而且手机像素有点渣,看着效果不是很好。
2014-09-11 16:47:18     打赏
共5条 1/1 1 跳转至
