/*----------------------------------------------- 这里需要用到2G的SD卡,SD卡插上后,会在串口中对数据进行读写。显示0-9 ------------------------------------------------*/ #include <reg52.h> #include <intrins.h> #include <stdio.h> #include<9325TP.h> //============================================================= //定义SD卡需要的4根信号线 sbit SD_CLK = P1^1; sbit SD_DI = P1^2; sbit SD_DO = P1^0; sbit SD_CS = P1^3; //=========================================================== //定义按键端口 sbit KEY = P3^2; //=========================================================== //定义512字节缓冲区,注意需要使用 xdata关键字 unsigned char xdata DATA[75]={0}; unsigned char xdata DATA1[75]={0}; //=========================================================== //写一字节到SD卡,模拟SPI总线方式 void SdWrite(unsigned char n) { unsigned char i; for(i=8;i;i--) { SD_CLK=0; SD_DI=(n&0x80); n<<=1; SD_CLK=1; } SD_DI=1; } //=========================================================== //从SD卡读一字节,模拟SPI总线方式 unsigned char SdRead() { unsigned char n,i; for(i=8;i;i--) { SD_CLK=0; SD_CLK=1; n<<=1; if(SD_DO) n|=1; } return n; } //============================================================ //检测SD卡的响应 unsigned char SdResponse() { unsigned char i=0,response; while(i<=8) { response = SdRead(); if(response==0x00) break; if(response==0x01) break; i++; } return response; } //================================================================ //发命令到SD卡 void SdCommand(unsigned char command, unsigned long argument, unsigned char CRC) { SdWrite(command|0x40); SdWrite(((unsigned char *)&argument)[0]); SdWrite(((unsigned char *)&argument)[1]); SdWrite(((unsigned char *)&argument)[2]); SdWrite(((unsigned char *)&argument)[3]); SdWrite(CRC); } //================================================================ //初始化SD卡 unsigned char SdInit(void) { int delay=0, trials=0; unsigned char i; unsigned char response=0x01; SD_CS=1; for(i=0;i<=9;i++) SdWrite(0xff); SD_CS=0; //Send Command 0 to put MMC in SPI mode SdCommand(0x00,0,0x95); response=SdResponse(); if(response!=0x01) { return 0; } while(response==0x01) { SD_CS=1; SdWrite(0xff); SD_CS=0; SdCommand(0x01,0x00ffc000,0xff); response=SdResponse(); } SD_CS=1; SdWrite(0xff); return 1; } //================================================================ //往SD卡指定地址写数据,一次最多512字节 unsigned char SdWriteBlock(unsigned char *Block, unsigned long address,int len) { unsigned int count; unsigned char dataResp; //Block size is 512 bytes exactly //First Lower SS SD_CS=0; //Then send write command SdCommand(0x18,address,0xff); if(SdResponse()==00) { SdWrite(0xff); SdWrite(0xff); SdWrite(0xff); //command was a success - now send data //start with DATA TOKEN = 0xFE SdWrite(0xfe); //now send data for(count=0;count<len;count++) SdWrite(*Block++); for(;count<512;count++) SdWrite(0); //data block sent - now send checksum SdWrite(0xff); //两字节CRC校验, 为0XFFFF 表示不考虑CRC SdWrite(0xff); //Now read in the DATA RESPONSE token dataResp=SdRead(); //Following the DATA RESPONSE token //are a number of BUSY bytes //a zero byte indicates the MMC is busy while(SdRead()==0); dataResp=dataResp&0x0f; //mask the high byte of the DATA RESPONSE token SD_CS=1; SdWrite(0xff); if(dataResp==0x0b) { //printf("DATA WAS NOT ACCEPTED BY CARD -- CRC ERROR\n"); return 0; } if(dataResp==0x05) return 1; //printf("Invalid data Response token.\n"); return 0; } //printf("Command 0x18 (Write) was not received by the MMC.\n"); return 0; } //======================================================================= //从SD卡指定地址读取数据,一次最多512字节 unsigned char SdReadBlock(unsigned char *Block, unsigned long address,int len) { unsigned int count; //Block size is 512 bytes exactly //First Lower SS //printf("MMC_read_block\n"); SD_CS=0; //Then send write command SdCommand(0x11,address,0xff); if(SdResponse()==00) { //command was a success - now send data //start with DATA TOKEN = 0xFE while(SdRead()!=0xfe); for(count=0;count<len;count++) *Block++=SdRead(); for(;count<512;count++) SdRead(); //data block sent - now send checksum SdRead(); SdRead(); //Now read in the DATA RESPONSE token SD_CS=1; SdRead(); return 1; } //printf("Command 0x11 (Read) was not received by the MMC.\n"); return 0; } /******************************************************************** * 名称 : Com_Init() * 功能 : 初始化串口程序,晶振11.0592, 波特率9600 * 输入 : 无 * 输出 : 无 ***********************************************************************/ void Com_Init(void) { TMOD = 0x20; PCON = 0x00; SCON = 0x50; TH1 = 0xFd; TL1 = 0xFd; TR1 = 1; } //============================================================ //主程序 main() { unsigned long AddTemp=262144;//SD卡地址第一个数据物理地址初始值,可以用winhex查看,这里是512扇区,512x512=262144,根据实际SD卡内容更改 unsigned char i; unsigned char *p; CS=1; delayms(5); RES=0; delayms(5); RES=1; delayms(5); SdInit(); //SD卡初始化 Com_Init(); for(i=0;i<75;i++) { DATA1[i]=i; } SdWriteBlock(DATA1, AddTemp, 75); SdReadBlock(DATA, AddTemp, 75); p= DATA; while(1) for(i=0;i<75;i++) { SBUF = *p+48; while(!TI) //如果发送完毕,硬件会置位TI { _nop_(); } p++; TI = 0; //TI清零 delayms(500); } }
/*----------------------------------------------- 名称:写彩屏 公司:上海浩豚电子科技有限公司 网站:www.doflye.net 编写:师访 日期:2009.12 修改:无 内容:320x240像素、16位BMP图片的HEX数据,依次写到屏上,还原图片 注意事项: ------------------------------------------------*/ #include"reg52.h" //============================================================ //根据芯片资料定义 #define WINDOW_XADDR_START 0x0050 // Horizontal Start Address Set #define WINDOW_XADDR_END 0x0051 // Horizontal End Address Set #define WINDOW_YADDR_START 0x0052 // Vertical Start Address Set #define WINDOW_YADDR_END 0x0053 // Vertical End Address Set #define GRAM_XADDR 0x0020 // GRAM Horizontal Address Set #define GRAM_YADDR 0x0021 // GRAM Vertical Address Set #define GRAMWR 0x0022 // memory write //============================================================= //定义液晶屏接口 sbit CS=P2^2; //片选 sbit RES=P2^1; //复位 sbit RS=P2^4; //数据/命令选择 sbit RW=P2^5; //数据口使用P0 //====================================================// //函数声明 void ILI9325_Initial(void); void Write_Cmd_Data(unsigned char x, unsigned int y); void Write_Cmd(unsigned char DH,unsigned char DL); void Write_Data(unsigned char DH,unsigned char DL); void delayms(unsigned int tt); void Write_Data_U16(unsigned int y); static void LCD_SetPos(unsigned int x0,unsigned int x1,unsigned int y0,unsigned int y1); void ClearScreen(unsigned int bColor); //=============================================================== //清屏 void ClearScreen(unsigned int bColor) { unsigned int i,j; LCD_SetPos(0,240,0,320);//320x240 for (i=0;i<320;i++) { for (j=0;j<240;j++) Write_Data_U16(bColor); } } //=============================================================== //写命令数据 void Write_Cmd_Data (unsigned char x,unsigned int y) { unsigned char m,n; m=y>>8; n=y; Write_Cmd(0x00,x); Write_Data(m,n); } //============================================================== //写16位数据 void Write_Data_U16(unsigned int y) { unsigned char m,n; m=y>>8; n=y; Write_Data(m,n); } //============================================================= //写命令 void Write_Cmd(unsigned char DH,unsigned char DL) { CS=0; RS=0; P0=DH; RW=0; RW=1; P0=DL; RW=0; RW=1; CS=1; } //=================================================================== //写数据 void Write_Data(unsigned char DH,unsigned char DL) { CS=0; RS=1; P0=DH; RW=0; RW=1; P0=DL; RW=0; RW=1; CS=1; } //============================================================ //延时程序 void delayms(unsigned int count) { int i,j; for(i=0;i<count;i++) { for(j=0;j<260;j++); } } //============================================================= //液晶初始化 void ILI9325_Initial(void) { delayms(50); //根据不同晶振速度可以调整延时,保障稳定显示 Write_Cmd_Data(0x0001,0x0100); Write_Cmd_Data(0x0002,0x0700); Write_Cmd_Data(0x0003,0x1030); Write_Cmd_Data(0x0004,0x0000); Write_Cmd_Data(0x0008,0x0207); Write_Cmd_Data(0x0009,0x0000); Write_Cmd_Data(0x000A,0x0000); Write_Cmd_Data(0x000C,0x0000); Write_Cmd_Data(0x000D,0x0000); Write_Cmd_Data(0x000F,0x0000); //power on sequence VGHVGL Write_Cmd_Data(0x0010,0x0000); Write_Cmd_Data(0x0011,0x0007); Write_Cmd_Data(0x0012,0x0000); Write_Cmd_Data(0x0013,0x0000); //vgh Write_Cmd_Data(0x0010,0x1290); Write_Cmd_Data(0x0011,0x0227); //delayms(100); //vregiout Write_Cmd_Data(0x0012,0x001d); //0x001b //delayms(100); //vom amplitude Write_Cmd_Data(0x0013,0x1500); //delayms(100); //vom H Write_Cmd_Data(0x0029,0x0018); Write_Cmd_Data(0x002B,0x000D); //gamma Write_Cmd_Data(0x0030,0x0004); Write_Cmd_Data(0x0031,0x0307); Write_Cmd_Data(0x0032,0x0002);// 0006 Write_Cmd_Data(0x0035,0x0206); Write_Cmd_Data(0x0036,0x0408); Write_Cmd_Data(0x0037,0x0507); Write_Cmd_Data(0x0038,0x0204);//0200 Write_Cmd_Data(0x0039,0x0707); Write_Cmd_Data(0x003C,0x0405);// 0504 Write_Cmd_Data(0x003D,0x0F02); //ram Write_Cmd_Data(0x0050,0x0000); Write_Cmd_Data(0x0051,0x00EF); Write_Cmd_Data(0x0052,0x0000); Write_Cmd_Data(0x0053,0x013F); Write_Cmd_Data(0x0060,0xA700); Write_Cmd_Data(0x0061,0x0001); Write_Cmd_Data(0x006A,0x0000); // Write_Cmd_Data(0x0080,0x0000); Write_Cmd_Data(0x0081,0x0000); Write_Cmd_Data(0x0082,0x0000); Write_Cmd_Data(0x0083,0x0000); Write_Cmd_Data(0x0084,0x0000); Write_Cmd_Data(0x0085,0x0000); // Write_Cmd_Data(0x0090,0x0010); Write_Cmd_Data(0x0092,0x0600); Write_Cmd_Data(0x0093,0x0003); Write_Cmd_Data(0x0095,0x0110); Write_Cmd_Data(0x0097,0x0000); Write_Cmd_Data(0x0098,0x0000); Write_Cmd_Data(0x0007,0x0133); // Write_Cmd_Data(0x0022);// } //=============================================================== //定义坐标 static void LCD_SetPos(unsigned int x0,unsigned int x1,unsigned int y0,unsigned int y1) { Write_Cmd_Data(WINDOW_XADDR_START,x0); Write_Cmd_Data(WINDOW_XADDR_END,x1); Write_Cmd_Data(WINDOW_YADDR_START,y0); Write_Cmd_Data(WINDOW_YADDR_END,y1); Write_Cmd_Data(GRAM_XADDR,x0); Write_Cmd_Data(GRAM_YADDR,y0); Write_Cmd (0x00,0x22);//LCD_WriteCMD(GRAMWR); }
