电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » keil 512最新版本抢先体验 做了众多优化 重点如下.
共3条 1/1 1 跳转至
2014-09-25 22:13:38     打赏
传说中的512版本出来了.哈哈 赶紧下载,和谐照旧.
http://www.keil.com/download/files/mdkcm512.exe
同学们赶紧下载体验.
说说更新吧:
1, This MDK version introduces support for ARM Cortex-M7 processor based devices.
此版本引入了对最新的m7的支持.
2This MDK release contains two ARM Compiler versions that can be selected in the dialog Project - Options for Target - Target (under Code Generation):
ARM Compiler 5.05 (build 41) (in directory ..\ARM\ARMCC\) with support for Cortex-M7 and other enhancements (see release notes).
ARM Compiler 5.04u2 (build 82) (in directory ..\ARM\ARMCC_504u2\) for safety critical applications in combination with the ARM Compiler Qualification Kit (only available with a license for MDK-Professional).
此版本引入了2个arm编译器, 在项目配置中,可以通过下拉选择;
3 Enhanced performance in the Project View and new file, group, and component attributes.
工程显示 菜单,组件的更新.
还有其他一些中间件软件的更新.
关键词: keil 512 更新 cortex -M7
2014-09-27 15:24:51     打赏
用的511a
2014-09-29 08:39:29     打赏
嗯 差不多,就是多了M7的支持,然后就是ide方便的一些优化.
共3条 1/1 1 跳转至
