输入条件:SysKind=0--->EasmChip的操作,SysKind=1-->CpuCard的操作。
输出项目:RecvData。
unsigned char ResetReceive(bool SysKind)
unsigned short Temp;
unsigned char RecvData=0;
WDT();
SysErrInfo = 0x00;
//超时时间12*372/2M=4000circle
Temp = 20000;
if(SysKind)
CpuCardSdaDirIn;//----------------------------------------------------------
while(--Temp)
if(!(CpuCardSdaInSt&BIT5))
RecvData = AckRecv(SysKind);
break;
if(Temp==0)
SysErrInfo = 0xFF;
else
EasmChipSdaDirIn;//---------------------------------------------------------
while(--Temp)
if(!(EasmChipSdaInSt&BIT1))
break;
if(Temp==0)
SysErrInfo = 0xFF;
return RecvData;
