* @file GPIO/IOToggle/main.c
* @author MCD Application Team
* @version V3.5.0
* @date 08-April-2011
* @brief Main program body.
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
* <h2><center>© COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
GPIO_InitTypeDef GPIO_InitStructure;
//以内部高速晶振为时钟源
void RCC_Configuration(void)
RCC_DeInit(); /*将外设RCC寄存器重设为缺省值*/
RCC_HSICmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET); //等待HSI就绪
RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI); //选择内部高速时钟作为系统时钟
RCC_HSEConfig(RCC_HSE_OFF); //关闭外部时钟
RCC_LSEConfig(RCC_LSE_OFF); //使能或者失能内部低速晶振(LSI)
RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz
RCC_PLLCmd(ENABLE); //启动PLL
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); //设置PLL为系统时钟源
RCC_ADCCLKConfig(RCC_PCLK2_Div4); //设置ADC时钟(ADCCLK)
RCC_PCLK2Config(RCC_HCLK_Div1); //配置APB2(PCLK2)钟==AHB时钟
RCC_PCLK1Config(RCC_HCLK_Div2); //配置APB1(PCLK1)钟==AHB1/2时钟
RCC_HCLKConfig(RCC_SYSCLK_Div1); //配置AHB(HCLK)时钟等于==SYSCLK
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //配置系统时钟 = PLL时钟
while(RCC_GetSYSCLKSource() != 0x08); //0x00:HSI作为系统时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //RCC_APB2Periph_AFIO
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE); //disable JTAG
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //选中管脚2
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //端口的翻转速度级别为50MHz
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //LED 推挽输出
GPIO_Init(GPIOD, &GPIO_InitStructure); //调用函数GPIO_Init()
GPIO_ResetBits(GPIOD,GPIO_Pin_2); //清除指定数据端口位
void GPIO_INIT()
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //使能GPIOC时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1; //开漏输出
GPIO_Init(GPIOC, &GPIO_InitStructure); //调用函数GPIO_Init()
void delay_us(u32 n)
u8 j;
while(n--)
for(j=0;j<10;j++);
void delay_ms(u32 n)
while(n--)
delay_us(1000);
* @brief Main program.
* @param None
* @retval None
int main(void)
RCC_Configuration();
GPIO_INIT();
while(1){
GPIO_ResetBits(GPIOC,GPIO_Pin_1|GPIO_Pin_0);
delay_ms(100); //延时100ms
GPIO_SetBits(GPIOC,GPIO_Pin_1|GPIO_Pin_0);
delay_ms(100);}
