Fri Oct 31 09:07:54 2014: Failed to set hardware breakpoint. All available resources are already in use.
Fri Oct 31 09:07:54 2014: Virtual breakpoints can be enabled in Options dialog under Debugger->FET
Debugger->Breakpoints
程序里面用的是P1口的中断,没有其他的断点,为啥会有这几句提示呢
