电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 430仿真,谁遇见过这个问题啊,
430仿真,谁遇见过这个问题啊,
2014-10-31 09:39:33     打赏
Fri Oct 31 09:05:20 2014: Performance warning: Lack of breakpoints forces single-stepping.
Fri Oct 31 09:07:54 2014: Failed to set hardware breakpoint. All available resources are already in use.
Fri Oct 31 09:07:54 2014: Virtual breakpoints can be enabled in Options dialog under Debugger->FET
Debugger->Breakpoints
程序里面用的是P1口的中断,没有其他的断点,为啥会有这几句提示呢
2014-11-04 08:46:39     打赏
我在程序里面没有设置断点,只是用了P1口本身的中断
