- if ... fi 语句;
- if ... else ... fi 语句;
- if ... elif ... else ... fi 语句。
if [ expression ] then Statement(s) to be executed if expression is true fi如果 expression 返回 true,then 后边的语句将会被执行;如果返回 false,不会执行任何语句。
最后必须以 fi 来结尾闭合 if,fi 就是 if 倒过来拼写,后面也会遇见。
注意:expression 和方括号([ ])之间必须有空格,否则会有语法错误。
举个例子:
运行结果:
- #!/bin/sh
- a=10
- b=20
- if [ $a == $b ]
- then
- echo "a is equal to b"
- fi
- if [ $a != $b ]
- then
- echo "a is not equal to b"
- fi
a is not equal to b2) if ... else ... fi 语句 if ... else ... fi 语句的语法:
if [ expression ] then Statement(s) to be executed if expression is true else Statement(s) to be executed if expression is not true fi如果 expression 返回 true,那么 then 后边的语句将会被执行;否则,执行 else 后边的语句。
举个例子:
执行结果:
- #!/bin/sh
- a=10
- b=20
- if [ $a == $b ]
- then
- else
- fi
a is not equal to b3) if ... elif ... fi 语句 if ... elif ... fi 语句可以对多个条件进行判断,语法为:
if [ expression 1 ] then Statement(s) to be executed if expression 1 is true elif [ expression 2 ] then Statement(s) to be executed if expression 2 is true elif [ expression 3 ] then Statement(s) to be executed if expression 3 is true else Statement(s) to be executed if no expression is true fi哪一个 expression 的值为 true,就执行哪个 expression 后面的语句;如果都为 false,那么不执行任何语句。
举个例子:
运行结果:
- #!/bin/sh
- a=10
- b=20
- if [ $a == $b ]
- then
- elif [ $a -gt $b ]
- then
- echo "a is greater than b"
- elif [ $a -lt $b ]
- then
- echo "a is less than b"
- else
- echo "None of the condition met"
- fi
a is less than b
if ... else 语句也可以写成一行,以命令的方式来运行,像这样:
- if test $[2*3] -eq $[1+5]; then echo 'The two numbers are equal!'; fi;
if ... else 语句也经常与 test 命令结合使用,如下所示:
输出:
- num1=$[2*3]
- num2=$[1+5]
- if test $[num1] -eq $[num2]
- then
- echo 'The two numbers are equal!'
- else
- echo 'The two numbers are not equal!'
- fi
The two numbers are equal!test 命令用于检查某个条件是否成立,与方括号([ ])类似。
