- #include "stm32f10x.h"
- #include "stm32_eval.h"
- #include
- #define VREF 3.3
- unsigned char i=0;
- EXTI_InitTypeDef EXTI_InitStructure;
- NVIC_InitTypeDef NVIC_InitStructure;
- GPIO_InitTypeDef GPIO_InitStructure;
- USART_InitTypeDef USART_InitStructure;
- USART_ClockInitTypeDef USART_ClockInitStructure;
- void delay_us(u32 n)
- u8 j;
- while(n--)
- for(j=0;j<10;j++);
- void delay_ms(u32 n)
- while(n--)
- delay_us(1000);
- void RCC_Configuration(void)
- RCC_DeInit();
- RCC_HSICmd(ENABLE);
- while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
- RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
- RCC_HSEConfig(RCC_HSE_OFF);
- RCC_LSEConfig(RCC_LSE_OFF);
- RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz
- RCC_PLLCmd(ENABLE);
- while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
- RCC_ADCCLKConfig(RCC_PCLK2_Div4);
- RCC_PCLK2Config(RCC_HCLK_Div1);
- RCC_PCLK1Config(RCC_HCLK_Div2);
- RCC_HCLKConfig(RCC_SYSCLK_Div1);
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
- while(RCC_GetSYSCLKSource() != 0x08);
- //SystemInit();
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
- GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- GPIO_ResetBits(GPIOD,GPIO_Pin_2);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
- GPIO_Init(GPIOC, &GPIO_InitStructure);
- GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
- void USART_int(long BaudRate)
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- /* PA10 USART1_Rx */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- /* USARTx configured as follow:
- - BaudRate = 115200 baud
- - Word Length = 8 Bits
- - One Stop Bit
- - No parity
- - Hardware flow control disabled (RTS and CTS signals)
- - Receive and transmit enabled
- USART_InitStructure.USART_BaudRate = BaudRate;
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;
- USART_InitStructure.USART_StopBits = USART_StopBits_1;
- USART_InitStructure.USART_Parity = USART_Parity_No;
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;e
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
- USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
- USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
- USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
- USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
- USART_ClockInit(USART1, &USART_ClockInitStructure);
- USART_Init(USART1, &USART_InitStructure);
- USART_Cmd(USART1, ENABLE);
- USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
- void GPIO_INIT()
- RCC_Configuration();
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- void Iic1_Init(void)
- I2C_InitTypeDef I2C_InitStructure;
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2, ENABLE);
- //PB6-I2C2_SCL PB7-I2C2_SDA PB10-I2C2_SCL PB11-I2C2_SDA
- /* Configure IO connected to IIC*********************/
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
- I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
- I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
- I2C_InitStructure.I2C_OwnAddress1 = 0xA0;
- I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
- I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
- I2C_InitStructure.I2C_ClockSpeed = 400000;
- I2C_Cmd(I2C2, ENABLE);
- I2C_Init(I2C2, &I2C_InitStructure);
- I2C_AcknowledgeConfig(I2C2, ENABLE);
- /*IIC????? */
- void I2C2_WriteByte(unsigned char id,unsigned char write_address,unsigned char byte)
- while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY));
- I2C_GenerateSTART(I2C2,ENABLE);
- while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_MODE_SELECT));
- I2C_Send7bitAddress(I2C2,id,I2C_Direction_Transmitter);
- while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
- I2C_SendData(I2C2, write_address);
- while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
- I2C_SendData(I2C2, byte);
- I2C_GenerateSTOP(I2C2, ENABLE);
- do
- /* Send START condition */
- I2C_GenerateSTART(I2C2, ENABLE);
- /* Read I2C2 SR1 register */
- /* Send EEPROM address for write */
- I2C_Send7bitAddress(I2C2, 0xA0, I2C_Direction_Transmitter);
- }while(!(I2C_ReadRegister(I2C2, I2C_Register_SR1) & 0x0002));
- /* Clear AF flag */
- I2C_ClearFlag(I2C2, I2C_FLAG_AF);
- /* STOP condition */
- unsigned char I2C2_ReadByte(unsigned char id, unsigned char read_address)
- unsigned char temp;
- while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY)){}
- I2C_Send7bitAddress(I2C2, id, I2C_Direction_Transmitter);
- I2C_SendData(I2C2, read_address);
- I2C_Send7bitAddress(I2C2, id, I2C_Direction_Receiver);
- while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
- I2C_AcknowledgeConfig(I2C2, DISABLE);
- while(!(I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_RECEIVED)));
- temp = I2C_ReceiveData(I2C2);
- return temp;
- void EXTIkeyS1_Config(void)
- /* Enable GPIOA clock */
- /* Configure PA.00 pin as input floating */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
- /* Enable AFIO clock */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
- GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource8);
- EXTI_InitStructure.EXTI_Line = EXTI_Line8;
- EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
- EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
- EXTI_InitStructure.EXTI_LineCmd = ENABLE;
- EXTI_Init(&EXTI_InitStructure);
- NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- void EXTI9_5_IRQHandler(void)
- if(EXTI_GetITStatus(EXTI_Line8) != RESET)
- i=0;
- I2C2_WriteByte(0xA0,0,0);
- printf("上电清0\r\n",i);
- /* Clear the EXTI line 8 pending bit */
- EXTI_ClearITPendingBit(EXTI_Line8);
- void IIC_TEST()
- printf(" config done...\r\n");
- i = I2C2_ReadByte(0xA0,0);
- i++;
- printf("从地址读出数据:%d\r\n",i);
- I2C2_WriteByte(0xA0,0,i);
- printf("向地址输入数据:%d\r\n",i);
- printf("上电次数%d\r\n",i);
- int main(void)
- /*!< At this stage the microcontroller clock setting is already configured,
- this is done through SystemInit() function which is called from startup
- file (startup_stm32f10x_xx.s) before to branch to application main.
- To reconfigure the default setting of SystemInit() function, refer to
- system_stm32f10x.c file
- /* System Clocks Configuration */
- EXTIkeyS1_Config();
- GPIO_INIT();
- USART_int(115200);
- Iic1_Init();
- IIC_TEST();
- #ifdef USE_FULL_ASSERT
- void assert_failed(uint8_t* file, uint32_t line)
- while (1)
- #endif
- #ifdef __GNUC__
- #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
- #else
- #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
- #endif /* __GNUC__ */
- PUTCHAR_PROTOTYPE
- USART_SendData(EVAL_COM1, (uint8_t) ch);
- while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
- return ch;
共3条
IIC上电计数和外部中断清零代码
共3条
| OrangePiZero2W系统被打赏¥33元 | |
