电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » safe910的dry 功放进程贴
共19条 1/2 1 2 › 跳转至页
safe910的dry 功放进程贴
2015-02-12 09:48:03     打赏
大家好
我的功放进程贴开始了,我会记录我的每一步动向,谢谢大家的分享。
2
2015-02-12 09:51:35     打赏
收到快递开始焊接,跟大家分享下吧 。
3
2015-02-12 11:55:09     打赏
焊接完成,通电测试12V  ,5V电压正常,LED灯闪烁。
注意供电的适配器用12V1A  功率大于10W以上的最好。
焊接完成通电正常
2015-02-12 12:40:28     打赏
由于原PCB板上没有丝印位号,我将PCB的丝印做了一份PDF文档,方便焊接。
jpg文档和pdf文档同时上传,欢迎下载。
电路板(PCB).pdf
2015-02-12 13:34:10     打赏
开始我的程序设计,一点一滴记录,欢迎大家指正。
/************* 功能说明 **************
本文件为STC15xxx系列的端口初始化程序,用户几乎可以不修改这个程序.
#include "GPIO.h"
// 函数: u8 GPIO_Inilize(u8 GPIO, GPIO_InitTypeDef *GPIOx)
// 描述: 初始化IO口.
// 参数: GPIOx: 结构参数,请参考timer.h里的定义.
// 返回: 成功返回0, 空操作返回1,错误返回2.
// 版本: V1.0, 2012-10-22
if(GPIO > GPIO_P5) return 1; //空操作
if(GPIOx->Mode > GPIO_OUT_PP) return 2; //错误
if(GPIO == GPIO_P0)
if(GPIOx->Mode == GPIO_PullUp) P0M1 &= ~GPIOx->Pin, P0M0 &= ~GPIOx->Pin; //上拉准双向口
if(GPIOx->Mode == GPIO_HighZ) P0M1 |=  GPIOx->Pin, P0M0 &= ~GPIOx->Pin; //浮空输入
if(GPIOx->Mode == GPIO_OUT_OD) P0M1 |=  GPIOx->Pin, P0M0 |=  GPIOx->Pin; //开漏输出
if(GPIOx->Mode == GPIO_OUT_PP) P0M1 &= ~GPIOx->Pin, P0M0 |=  GPIOx->Pin; //推挽输出
if(GPIO == GPIO_P1)
if(GPIOx->Mode == GPIO_PullUp) P1M1 &= ~GPIOx->Pin, P1M0 &= ~GPIOx->Pin; //上拉准双向口
if(GPIOx->Mode == GPIO_HighZ) P1M1 |=  GPIOx->Pin, P1M0 &= ~GPIOx->Pin; //浮空输入
if(GPIOx->Mode == GPIO_OUT_OD) P1M1 |=  GPIOx->Pin, P1M0 |=  GPIOx->Pin; //开漏输出
if(GPIOx->Mode == GPIO_OUT_PP) P1M1 &= ~GPIOx->Pin, P1M0 |=  GPIOx->Pin; //推挽输出
if(GPIO == GPIO_P2)
if(GPIOx->Mode == GPIO_PullUp) P2M1 &= ~GPIOx->Pin, P2M0 &= ~GPIOx->Pin; //上拉准双向口
if(GPIOx->Mode == GPIO_HighZ) P2M1 |=  GPIOx->Pin, P2M0 &= ~GPIOx->Pin; //浮空输入
if(GPIOx->Mode == GPIO_OUT_OD) P2M1 |=  GPIOx->Pin, P2M0 |=  GPIOx->Pin; //开漏输出
if(GPIOx->Mode == GPIO_OUT_PP) P2M1 &= ~GPIOx->Pin, P2M0 |=  GPIOx->Pin; //推挽输出
if(GPIO == GPIO_P3)
if(GPIOx->Mode == GPIO_PullUp) P3M1 &= ~GPIOx->Pin, P3M0 &= ~GPIOx->Pin; //上拉准双向口
if(GPIOx->Mode == GPIO_HighZ) P3M1 |=  GPIOx->Pin, P3M0 &= ~GPIOx->Pin; //浮空输入
if(GPIOx->Mode == GPIO_OUT_OD) P3M1 |=  GPIOx->Pin, P3M0 |=  GPIOx->Pin; //开漏输出
if(GPIOx->Mode == GPIO_OUT_PP) P3M1 &= ~GPIOx->Pin, P3M0 |=  GPIOx->Pin; //推挽输出
if(GPIO == GPIO_P4)
if(GPIOx->Mode == GPIO_PullUp) P4M1 &= ~GPIOx->Pin, P4M0 &= ~GPIOx->Pin; //上拉准双向口
if(GPIOx->Mode == GPIO_HighZ) P4M1 |=  GPIOx->Pin, P4M0 &= ~GPIOx->Pin; //浮空输入
if(GPIOx->Mode == GPIO_OUT_OD) P4M1 |=  GPIOx->Pin, P4M0 |=  GPIOx->Pin; //开漏输出
if(GPIOx->Mode == GPIO_OUT_PP) P4M1 &= ~GPIOx->Pin, P4M0 |=  GPIOx->Pin; //推挽输出
if(GPIO == GPIO_P5)
if(GPIOx->Mode == GPIO_PullUp) P5M1 &= ~GPIOx->Pin, P5M0 &= ~GPIOx->Pin; //上拉准双向口
if(GPIOx->Mode == GPIO_HighZ) P5M1 |=  GPIOx->Pin, P5M0 &= ~GPIOx->Pin; //浮空输入
if(GPIOx->Mode == GPIO_OUT_OD) P5M1 |=  GPIOx->Pin, P5M0 |=  GPIOx->Pin; //开漏输出
if(GPIOx->Mode == GPIO_OUT_PP) P5M1 &= ~GPIOx->Pin, P5M0 |=  GPIOx->Pin; //推挽输出
return 0; //成功
2015-02-12 13:35:32     打赏
时钟控制
本文件为STC15xxx系列的定时器初始化和中断程序,用户可以在这个文件中修改自己需要的中断程序.
#include "timer.h"
/********************* Timer0中断函数************************/
//void timer0_int (void) interrupt TIMER0_VECTOR
/********************* Timer1中断函数************************/
void timer1_int (void) interrupt TIMER1_VECTOR
/********************* Timer2中断函数************************/
void timer2_int (void) interrupt TIMER2_VECTOR
P10 = ~P10;
// 函数: u8 Timer_Inilize(u8 TIM, TIM_InitTypeDef *TIMx)
// 描述: 定时器初始化程序.
// 参数: TIMx: 结构参数,请参考timer.h里的定义.
if(TIM > Timer2) return 1; //空操作
if(TIM == Timer0)
TR0 = 0; //停止计数
if(TIMx->TIM_Interrupt == ENABLE) ET0 = 1; //允许中断
else ET0 = 0; //禁止中断
if(TIMx->TIM_Polity == PolityHigh) PT0 = 1; //高优先级中断
else PT0 = 0; //低优先级中断
if(TIMx->TIM_Mode >  TIM_16BitAutoReloadNoMask) return 2; //错误
TMOD = (TMOD & ~0x03) | TIMx->TIM_Mode; //工作模式,0: 16位自动重装, 1: 16位定时/计数, 2: 8位自动重装, 3: 16位自动重装, 不可屏蔽中断
if(TIMx->TIM_ClkSource == TIM_CLOCK_12T) AUXR &= ~0x80; //12T
if(TIMx->TIM_ClkSource == TIM_CLOCK_1T) AUXR |=  0x80; //1T
if(TIMx->TIM_ClkSource == TIM_CLOCK_Ext) TMOD |=  0x04; //对外计数或分频
else TMOD &= ~0x04; //定时
if(TIMx->TIM_ClkOut == ENABLE) INT_CLKO |=  0x01; //输出时钟
else INT_CLKO &= ~0x01; //不输出时钟
TH0 = (u8)(TIMx->TIM_Value >> 8);
TL0 = (u8)TIMx->TIM_Value;
if(TIMx->TIM_Run == ENABLE) TR0 = 1; //开始运行
return 0; //成功
if(TIM == Timer1)
TR1 = 0; //停止计数
if(TIMx->TIM_Interrupt == ENABLE) ET1 = 1; //允许中断
else ET1 = 0; //禁止中断
if(TIMx->TIM_Polity == PolityHigh) PT1 = 1; //高优先级中断
else PT1 = 0; //低优先级中断
if(TIMx->TIM_Mode >= TIM_16BitAutoReloadNoMask) return 2; //错误
TMOD = (TMOD & ~0x30) | TIMx->TIM_Mode; //工作模式,0: 16位自动重装, 1: 16位定时/计数, 2: 8位自动重装
if(TIMx->TIM_ClkSource == TIM_CLOCK_12T) AUXR &= ~0x40; //12T
if(TIMx->TIM_ClkSource == TIM_CLOCK_1T) AUXR |=  0x40; //1T
if(TIMx->TIM_ClkSource == TIM_CLOCK_Ext) TMOD |=  0x40; //对外计数或分频
else TMOD &= ~0x40; //定时
if(TIMx->TIM_ClkOut == ENABLE) INT_CLKO |=  0x02; //输出时钟
else INT_CLKO &= ~0x02; //不输出时钟
TH1 = (u8)(TIMx->TIM_Value >> 8);
TL1 = (u8)TIMx->TIM_Value;
if(TIMx->TIM_Run == ENABLE) TR1 = 1; //开始运行
return 0; //成功
if(TIM == Timer2) //Timer2,固定为16位自动重装, 中断无优先级
AUXR &= ~(1<<4); //停止计数
if(TIMx->TIM_Interrupt == ENABLE) IE2  |=  (1<<2); //允许中断
else IE2  &= ~(1<<2); //禁止中断
if(TIMx->TIM_ClkSource >  TIM_CLOCK_Ext) return 2;
if(TIMx->TIM_ClkSource == TIM_CLOCK_12T) AUXR &= ~(1<<2); //12T
if(TIMx->TIM_ClkSource == TIM_CLOCK_1T) AUXR |=  (1<<2); //1T
if(TIMx->TIM_ClkSource == TIM_CLOCK_Ext) AUXR |=  (1<<3); //对外计数或分频
else AUXR &= ~(1<<3); //定时
if(TIMx->TIM_ClkOut == ENABLE) INT_CLKO |=  0x04; //输出时钟
else INT_CLKO &= ~0x04; //不输出时钟
TH2 = (u8)(TIMx->TIM_Value >> 8);
TL2 = (u8)TIMx->TIM_Value;
if(TIMx->TIM_Run == ENABLE) AUXR |=  (1<<4); //开始运行
return 0; //成功
return 2; //错误
2015-02-12 13:42:27     打赏
7楼
这个赞~!今天收到今天就做好了
2015-02-12 15:05:32     打赏
8楼
单片机烧掉了 ,上电很烫
看来要重新买单片机了
2015-02-12 16:31:35     打赏
9楼
悲剧 ,希望下次嗜好的 ,
2015-02-12 16:47:33     打赏
10楼
动作真快!!!
共19条 1/2 1 2 › 跳转至页
