C |
Complementary format. Type C and press Enter to change the display to a complementary format, which views thermals and antipads on plane layers. Type C a second time and press Enter to restore the normal non complementary view. |
D |
Toggles the Active layer comes to front setting in the General options. |
DO |
Drill outline on/off. The display of the drill is disabled when you give a net a specific highlight color in View > Nets. |
E |
Cycles through the End Via modes:
Tip: See the Status bar to know what mode you have switched to. |
I |
Database Integrity Test. |
L <n> |
Change the current layer to <n>. <n> can be a number or name, for example (L 2) or (L top). |
T |
Toggle Transparent Mode. See also: To Use Transparent View Mode |
X |
Text outline on/off. |
W <n> |
Changes width to <n>, for example W 5. |
Line/Trace Angle Commands |
AA |
Any angle mode. Sets the Line/trace angle setting in the Design options to Any angle. |
AD |
Diagonal angle mode. Sets the Line/trace angle setting in the Design options to Diagonal. |
AO |
Orthogonal angle mode. Sets the Line/trace angle setting in the Design options to Orthogonal. |
On-line Design Rule Checking (DRC) Commands |
DRP |
Prevent errors mode. Sets the On-line DRC setting in the Design options to Prevent errors. |
DRW |
Warn errors mode. Sets the On-line DRC setting in the Design options to Warn errors. |
DRI |
Ignore clearance mode Sets the On-line DRC setting in the Design options to Ignore clearance. |
DRO |
Turn off on-line DRC mode. Sets the On-line DRC setting in the Design options to Off. |
Cartesian Grid Commands |
G <x> {<y>} |
Design and Via grid settings simultaneously. The second parameter is optional. For example, G 25, G 8.3 or G 16-2/3, G 5 25. |
GD <x> {<y>} |
Dot grid setting, for example, GD 8-1/3, GD 25 25, or GD 100. The second parameter is optional. |
GR <xx> |
Design grid setting, for example, GR 8-1/3, GR 25 25, GR 25. |
GV <xx> |
Via grid setting, for example, GV 8-1/3, GV 25 25, or GV 25. |
Polar Grid Commands |
GP |
Polar grid on/off. Use the polar grid for Radial Move, circular component arrays, and to create radial drawings. Requirement: Routing on the polar grid requires you to set the Angle Mode to Any Angle. See the AA modeless command for more info. |
GP r a |
Move to a point specified by polar coordinates (radius and angle). |
GPR r |
Move to a point specified by the radius, using the existing angle. |
GPA a |
Move to a point specified by the angle, using the existing radius. |
GPRA da |
Move to a point specified by the current angle (da) value, using the existing radius. |
GPRR dr |
Move to a point specified by the current radius (dr), using the existing angle. |
Grid Tips:
Drafting Objects Commands |
HC |
Circle shape draw mode. |
HH |
Path shape draw mode. |
HP |
Polygon shape draw mode. |
HR |
Rectangle shape draw mode. |
Line Styles Commands |
LS |
Shows the current line style setting in the status bar. |
LSS |
Sets the default line style for new 2D line objects to Solid lines. |
LSD |
Sets the default line style for new 2D line objects to Dashed lines. |
LSO |
Sets the default line style for new 2D line objects to Dotted lines. |
LSA |
Sets the default line style for new 2D line objects to Dash Dotted lines. |
LSB |
Sets the default line style for new 2D line objects to Dash Double-dotted lines. |
Net Highlighting |
N <s> |
Highlights nets one by one. To place the highlighted net <s> at the top of the stack, repeat the command, for example, N GND. Tip: Highlighted nets take on the Highlight color specified in the Display Colors dialog box. |
N- |
Unhighlights each highlighted net in the reverse order to which they were added using the N command. |
N |
Removes all highlighting from the nets. |
Net Name Visibility |
NN |
Toggles the visibility of net names. Tips:
NNP |
Toggles the display of net names on pins. Tip: This command toggles the Net names on...Pins check box in the Display Colors Setup Dialog Box. Sizing is controlled by the settings in the Display Options. Restriction: The display of net names also depends on the Net Name visibility check box and the presence of a non-background color tile on the layer in the Display Colors Setup Dialog Box. |
NNT |
Toggles the display of net names on traces. Tip: This command toggles the Net names on...Traces check box in the Display Colors Setup Dialog Box. Sizing and frequency of placement is controlled by the settings in the Display Options. Restriction: The display of net names also depends on the Net Name visibility check box and the presence of a non-background color tile on the layer in the Display Colors Setup Dialog Box. |
NNV |
Toggles the display of net names on vias. Tip: This command toggles the Net names on...Vias check box in the Display Colors Setup Dialog Box. Sizing is controlled by the settings in the Display Options. Restriction: The display of net names also depends on the Net Name visibility check box and the presence of a non-background color tile on the layer in the Display Colors Setup Dialog Box. |
Outline Mode |
O <r> |
Toggles outline mode on and off. The OH and OL modeless command determine the resolution mode of outline mode. Displays an outline of pads, traces and all lines. Traces are displayed at their true width to the limits of the Minimum Display Width setting in the Global / General Options. See also: To Use Outline View Mode |
OH |
Toggles outline mode with High resolution. Displays all objects with their true shape. |
OL |
Toggles outline mode with Low resolution. Design objects appear drawn with a square pen. Displays rounded objects with squared corners. Oval and rectangular pads look the same. Trace segments don’t have arcs at the ends. Exception: Round pads are drawn as circles. |
Object Snapping |
OS |
Toggles Snap to Objects mode on/off in the Object Snap options. |
OSR<n> |
Sets the snapping radius to the specified value (in current design units) in the Object Snap options. If no value is given, OSR displays current value of snap radius in the status bar. |
OS <n> |
Sets the Snap to object types in the Object Snap options and clears those not selected. You can use one or more of the following values:
For example: If you want to only snap to midpoints, type OS M. Or if you want to snap to all objects, type OS CEIMOPQ. |
PO |
Pour outline on/off. This toggles the Display mode of copper pours between Pour outline and Hatch outline in the Hatch and Flood options. See the SPO modeless command for use with plane areas. |
PN |
Toggles pin number display on/off. Tip: This command toggles the Pin Num. column check box in the Display Colors Setup Dialog Box. Sizing is controlled by the settings in the Display Options. |
Q |
Quick Measure with a dynamic ruler. Place the cursor at the starting point then type the “q” modeless command. Drag the cursor to create a line between the start and end point of your measurement. Snaps to the design grid when Snap to grid is on. Measurements are gridless when Grid Snap is off. Dynamically reports delta x, delta y, and delta x,y in current design units. You can also measure precise Euclidean distances between polar grid nodes using this command. Quick Measure mode also works with Object Snapping. But unless you are within the snap radius of an object type, you are not given the option to choose between snapping to the grid or an object for your starting point. Snapping to object types takes priority over snapping to the grid. You can enable Snapping to Objects on the popup menu during the measure operation, in the Options dialog box, or by using the OS modeless commands. See also: Measuring |
QL |
Quick Length.
A report of the route item lengths for routed, unrouted, and total length appears in the default text editor. See also: Measuring |
R <n> |
Sets the minimum display width in the General options to <n>, for example, R 50. Any line widths that are less than this value are drawn as single pixel center lines. This feature helps you select tiny line segments. |
RV |
Toggles Make Like Reuse operations to compare or ignore value and tolerance attributes. See also: To Make a Like Reuse in Verb Mode, To Make a Like Reuse in Object Mode |
Origin Setting Commands |
SO <x> {<y>} |
Sets the origin using relative coordinates.
If a component, pin, drafting corner, text, via, circle, or line intersection is selected, SO sets the board origin to the origin of the selected item. If nothing is selected, coordinates must be given. For example, SO 25, SO 8.3 or SO 16-2/3, SO 25 25. The second parameter is optional. |
SOA <x> {<y>} |
Sets the origin using absolute coordinates. Coordinates must be given. For example, SOA 25, SOA 8.3 or SOA 16-2/3, SOA 25 25. The second parameter is optional. |
Split/Mixed Plane Display Setting Commands |
SPD |
Display generated plane data for split/mixed planes. This command sets the Mixed plane display option in the Split/Mixed Plane options. |
SPI |
Display plane thermal indicators. This command sets the Mixed plane display option in the Split/Mixed Plane options. |
SPO |
Display plane polygon outlines for split/mixed planes. This command sets the Mixed plane display option in the Split/Mixed Plane options. |
Search Commands |
S <s> |
Search for reference designator/pin <s>, for example SU 1.1 or SU 1. |
S <n> <n> |
Search absolute at <n> <n>, for example S 1000 1000. |
SR <n> <n> |
Search relative X and Y, for example SR -200 100. |
SRX <n> |
Search relative X, for example SRX 300. |
SRY <n> |
Search relative Y, for example SRY 400. |
SS <s> |
Search and Select components by reference designator, for example SS U10. You can also search and select more than one component by typing multiple entries, for example SS U10 U5 R6. Tip: Spaces may be important in modeless commands. For example, SS W1 and S SW1 have different meanings. SS W1 tells PADS Layout to search and select W1, while S SW1 tells it to search for SW1. |
SS <s>* |
You can search and select using an asterisk, *. Type SS, a space, the character you want to search by, and an asterisk. For example, to search and select all components beginning with a C, type SS C*. All components with a reference designator starting with C are selected. Tip: This command is useful for placing parts. For example, you can select all resistors using SS R* and then choose Move Sequential from the pop-up menu to place the selected parts. |
SX <n> |
Absolute move to <n>, current Y, for example SX 300. |
SY <n> |
Absolute move to <n>, current X, for example SY 400. |
XP |
Search for and select route segments using pixels instead of segment width, allowing you to adjust a trace whose corners are less than the width of the trace. |
Design Units |
UM |
Sets Design Units to mils (thousands of an inch) in the General options. |
UMM |
Sets Design Units to metric (millimeters) in the General options. |
UI |
Sets Design Units to inches in the General options. |
Quick Layer View Commands |
Z |
Quick layer view. With no command arguments, Z displays the initial layer view. |
Z {+<layer>} {-<layer>} |
Add or remove layer from the current set of displayed layers. Examples:
Z <n-m> |
View only the range of layers you type. For example, Z 2-4 displays layers 2, 3, and 4. Do not enclose the range with square brackets. |
Z <layer n> {<layer m> ...} |
View only the layers you type. For example, Z 2 4 d displays layers 2, 4, and the documentation layer. |
Z * |
View all layers. Restriction: Z supports only the asterisk * regular expression. |
Z A |
View the active layer. If the active layer is changed, it has no effect on the display. |
Z ADB |
View the Assembly Drawing Bottom layer. |
Z ADT |
View the Assembly Drawing Top layer. |
Z B |
View only the bottom layer. |
Z C <-C> |
View only the current layer. If the active layer is changed, only the new current layer is displayed. Unlike Z A, it puts you in a continuous mode where all layers are hidden except the active layer. When you change layers, the new layer becomes visible and all other layers are hidden. Use Z -C to exit the mode. |
Z D |
View all documentation layers. |
Z E |
View all electrical layers. |
Z I |
View all internal layers. |
Z O |
View only the outside layers, that is, the top and bottom layers. |
Z PMB |
View the Paste Mask Bottom. |
Z PMT |
View the Paste Mask Top. |
Z SMB |
View the Solder Mask Bottom. |
Z SMT |
View the Solder Mask Top. |
Z SSB |
View the Silkscreen Bottom. |
Z SST |
View the Silkscreen Top. |
Z T |
View only the top layer. |
Z U |
Toggles the view of unrouted connections that are visible on all layers. |
Z Z |
View all layers. |
ZR <name> |
Restore a quick layer view configuration. For example, ZR L23 restores the configuration stored as L23. Tip: Type ZR and press Enter to see a list of all layer configurations created by ZS in this session. See also: ZS. |
ZS <name> |
Saves the current set of displayed layers as a quick layer view configuration. For example, ZS L23 stores the current configuration as L23. The quick layer view configuration is available until you exit the program. See also: ZR. |
Undo Commands |
UN [<n>] |
Multiple undo command (1-100), <n> is optional. (Ex. UN 2) UN will undo 1 time. |
RE [<n>] |
Multiple redo command (1-100), <n> is optional. (Ex. RE 2) RE will redo 1 time. |
Routing Commands |
E |
Toggle between end via, end no via, and end test point modes. |
LD |
Toggle between horizontal and vertical routing layer direction on the current layer. Changes the Routing Direction setting for the active layer in the design. |
PL <n> <n> |
Paired Layer command, where <n> can be layer numbers or layer names. (for example, PL 1 2 or PL top bottom). Sets the Layer pair setting in the Routing options. |
SH |
Toggles Shove mode on or off. |
V |
Opens the Vias dialog box. |
VA |
Automatic via and mode selection. |
VP |
Use partial via. |
VT <name> |
Use through hole via. If multiple vias exist, you can also type the name of the via to use. |
T |
Toggle Transparent Mode. |
Other Commands |
Show this help topic. |
BMW |
Opens the Basic Media Wizard dialog box.
See also: BMW and BLT |
BMW ON |
Starts BMW session logging. |
BMW OFF |
Stops BMW session logging. |
BLT |
Basic Log Test. Opens the Log Test Dialog Box. BLT finds and runs BMW session playback media. See also: BMW and BLT |
F <s> |
Open file <s>, where <s> is the path and name of the file to open. |
PADS9.5快捷键
只看楼主 1楼
关键词: PADS9.5 快捷键
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! |
打赏帖 | |
老胖子聊电路--分析一个反馈电路被打赏50分 | |
