型号 功率 增益 电压 频率 工作状态 封装 123脚
2N3375 10W 5dB 28V 400MHz FM/AM/SSB TO-60 2N3553 2,5W 10dB 28V 175MHz FM/AM TO-39 C B E 2N3632 20W 7dB 28V 175MHz FM TO-60 2N3866 5W 10dB 28V 400MHz WINTransceiver TO-39 C B E 2N3924 4W 6dB 13,6V 175MHz WINTransceiver TO-39 2N4427 2W 10dB 12V 175MHz WINTransceiver TO-39 2N5108 1W 5dB 24V 1200MHz WINTransceiver TO-39 2N5109 3,5W 11dB 15V 200MHz WINTransceiver TO-39 2N5421 3W 9dB 13,5V 175MHz WINTransceiver TO-39 2N5913 2W 7dB 12,5V 175MHz WINTransceiver TO-39 2N5943 1W 8dB 15V 400MHz FM TO-39 2SC730 0,8W 10dB 13,5V 175MHz FM TO-39 C B E 2SC1096 10W 60MHz FM TO-220 2SC1173 10W 100MHz FM/AM/SSB TO-220 2SC1306 16W 30MHz FM/AM/SSB TO-220 B C E 2SC1307 16W 12dB 12V 30MHz FM/AM/SSB TO-220 B C E 2SC1590 5W 10dB 12,5V 136-174MHz FM TO-220 B E C 2SC1591 14W 7,5dB 12,5V 136-174MHz FM TO-220 B E C 2SC1678 5W 30MHz WINTransceiver TO-220 B C E 2SC1728 8W 80MHz WINTransceiver TO-202 E B C 2SC1729 14W 10dB 13,5V 175MHz FM T-31E 2SC1909 10W 14,5dB 13,5V 50MHz FM/AM/SSB TO-220 B C E 2SC1944 13W 11,1dB 12V 30MHz WINTransceiver TO-220 B C E 2SC1945 16W 14,5dB 12V 30MHz FM/AM/SSB TO-220 B E C 2SC1946 25W 6,7dB 13,5V 175MHz FM T-31E 2SC1946A 30W 10dB 13,5V 175MHz FM T-31E 2SC1947 3W 10dB 13,5V 175MHz FM TO-39 C B E 2SC1957 1,8W 17dB 12V 30MHz WINTransceiver TO-126 E C B 2SC1966 3W 7,8dB 13,5V 470MHz FM T-31E 2SC1967 7W 6,7dB 13,5V 470MHz FM T-31E 2SC1968 14W 3,7dB 13,5V 470MHz FM T-31E 2SC1968A 14W 5,4dB 13,5V 470MHz FM T-31E 2SC1969 18W 12dB 12V 30MHz FM/AM/SSB TO-220 B C E 2SC1970 1,5W 10dB 13,5V 175MHz WINTransceiver TO-220 B E C 2SC1971 7W 10dB 13,5V 175MHz WINTransceiver TO-220 B E C 2SC1972 14W 10dB 13,5V 175MHz WINTransceiver TO-220 B E C 2SC1973 1W 50MHz WINTransceiver TO-92L B C E 2SC1974 13W 10dB 13,5V 30MHz WINTransceiver TO-220 B C E 2SC1975 4W 10dB 13,5V 30MHz WINTransceiver TO-220 B C E 2SC2028 1,8W 30MHz WINTransceiver TO-126 E C B 2SC2029 6W 30MHz WINTransceiver TO-220 B C E 2SC2036A 1,4W WINTransceiver TO-202 B C E 2SC2050 10W 12dB 13,5V 30MHz FM/AM/SSB TO-220 B C E 2SC2053 0,2W 15,7dB 12V 175MHz FM/AM TO-92L B C E 2SC2055 0,25W 15,3dB 12V 175MHz FM/AM TO-92L B C E 2SC2056 1,5W 9dB 12V 175MHz FM TO-39 C B E 2SC2075 4W 13,5V 27MHz WINTransceiver TO-220 B C E 2SC2078 4W 13dB 12V 100MHz FM/AM TO-220 B C E 2SC2086 0,45W 13dB 12V 175MHz FM/AM TO-92L B C E 2SC2092 4W 13dB 12V 100MHz FM/AM/SSB TO-220 B C E 2SC2094 15W 8,8dB 13,5V 175MHz FM/AM/SSB T-31E 2SC2166 6W 13,8dB 12V 30MHz FM/AM/SSB TO-220 B C E 2SC2207 16W WINTransceiver TO-220 B C E 2SC2237 6W 13,8dB 13,5V 175MHz FM T-31E 2SC2312 18,5W 27MHz FM/AM/SSB TO-220 B C E 2SC2314 1,8W 17dB 12V 180MHz FM/AM TO-126 E C B 2SC2509 13W 14dB 30MHz WINTransceiver TO-220 B C E 2SC2527 60W WINTransceiver TO-220 2SC2538 0,6W 10dB 12V 175MHz FM/AM TO-92L B C E 2SC2539 14W 14,5dB 13,5V 175MHz FM T-31E 2SC2660 30W 30MHz WINTransceiver TO-220 2SC2695 23W 1,9dB 13,5V 520MHz FM T-31E 2SC3001 6W 13dB 7,2V 175MHz FM T-31E 2SC3017 1W 11dB 13,5V 175MHz FM TO-39 C B E 2SC3018 3W 13dB 7,2V 175MHz FM T-31E 2SC3020 3W 10dB 12,5V 520MHz FM T-31E 2SC3021 7W 7,7dB 12,5V 520MHz FM T-31E 2SC3022 18W 4,8dB 12,5V 520MHz FM T-31E 2SC3103 2,8W 6,7dB 7,2V 520MHz FM T-31E 2SC3104 6W 4,8dB 7,2V 520MHz FM T-31E 2SC3133 13W 14dB 12V 1,5-30MHz FM/AM/SSB TO-220 B E C 2SC3297 15W 100MHz WINTransceiver TO-220 2SC3299 20W WINTransceiver TO-220 2SC3668 1W 100MHz WINTransceiver 2SC3807 15W 260MHz WINTransceiver TO-126 2SC4137 4W 400MHz WINTransceiver TO-126 2SC4693 FM/AM TO-92L B C E KTC1006 1W 100MHz FM/AM TO-92L E C B KTC1969 16W 12dB 12V 100MHz FM/AM TO-220 B C E KTC2078 4W 11dB 12V 100MHz FM/AM TO-220 B C E MRF161 5W 13,5dB 12,5V 225-500MHz FM/AM TO-220 B E C MRF162 15W 13,5dB 12,5V 225-500MHz FM/AM TO-220 B E C MRF163 25W 12dB 12,5V 225-500MHz FM/AM TO-220 B E C MRF237 4W 12dB 18V 175MHz WINTransceiver TO-39 MRF260 5W 10dB 12,5V 136-174MHz FM TO-220 B E C MRF261 10W 5,2dB 12,5V 136-174MHz FM TO-220 B E C MRF262 14W 7,5dB 12,5V 136-174MHz FM TO-220 B E C MRF264 30W 5,2dB 12,5V 136-174MHz WINTransceiver TO-220 B E C MRF340 8W 13dB 28V 70MHz WINTransceiver TO-220 B E C MRF342 24W 11dB 28V 70MHz WINTransceiver TO-220 B E C MRF344 60W 6dB 28V 70MHz WINTransceiver TO-220 MRF454 80W 12dB 12,5V 1,5-30MHz FM/AM/SSB MRF455 60W 13dB 12,5V 1,5-30MHz FM/AM/SSB MRF475 12W 10dB 13,5V 1,5-30MHz FM/AM/SSB TO-220 B C E MRF476 3W 15dB 13,5V 1,5-30MHz FM/AM/SSB TO-220 B C E MRF477 40W 15dB 13,5V 1,5-30MHz FM/AM/SSB TO-220 B E C MRF479 15W 10dB 13,5V 1,5-30MHz FM/AM/SSB TO-220 MRF485 15W 10dB 28V 1,5-30MHz WINTransceiver TO-220 MRF486 40W 15dB 28V 1,5-30MHz WINTransceiver TO-220 MRF496 40W 15dB 13,5V 1,5-30MHz WINTransceiver TO-220 MRF497 60W 10dB 13,5V 27-50MHz WINTransceiver TO-220 B E C MRF517 0,75W 10dB 20V 1000MHz WINTransceiver TO-39 MRF607 1,75W 11,5dB 16V 175MHz WINTransceiver TO-39 MRF660 7W 5,4dB 12,5V 400-512MHz WINTransceiver TO-220 MS1226 30W 18dB 28V 30MHz FM/AM/SSB MS1227 20W 15dB 12,5V 30MHz FM/AM/SSB有奖活动 | |
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
