The latest release of Arduino IDE (v1.6.8) has introduced a problem that
prevents sketches from running on many chipKIT boards, in addition to
some Arduino boards. It appears that any board using an FTDI chip for
serial bootloader communications is adversely affected.
A temporary solution is to re-install the previous version, Arduino IDE
v1.6.7, which has been well-tested and known to work fine with
chipKIT-core selected in the Boards Manager. For more information about
installing Arduino IDE and chipKIT-core, refer to the chipKIT-core Wiki page.
When the problem with v1.6.8 occurs, the sketch compiles and downloads
from the IDE just fine, but does not appear to execute on the chipKIT
board. This is because the serial DTR line between the FTDI chip and MCU
is being toggled approximately once per second. DTR is typically tied
to the MCU’s RESET line, causing the board to reset before the sketch
has had a chance to execute.
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
