Choosing FPGA or DSP for your Application Introduction The HERON range of modular DSP systems supports processing in either FPGA or DSP. The two approaches are markedly different. Here we look at when to use FPGA, and when to use DSP. See also the useful article from Xilinx on this subject. FPGA or DSP - The Two Solutions The DSP is a specialised microprocessor - typically programmed in C, perhaps with assembly code for performance. It is well suited to extremely complex maths-intensive tasks, with conditional processing. It is limited in performance by the clock rate, and the number of useful operations it can do per clock. As an example, a TMS320C6201 has two multipliers and a 200MHz clock – so can achieve 400M multiplies per second. In contrast, an FPGA is an uncommitted "sea of gates". The device is programmed by connecting the gates together to form multipliers, registers, adders and so forth. Using the Xilinx Core Generator his can be done at a block-diagram level. Many blocks can be very high level – ranging from a single gate to an FIR or FFT. Their performance is limited by the number of gates they have and the clock rate. Recent FPGAs have included Multipliers especially for performing DSP tasks more efficiently. – For example, a 1M-gate Virtex-II?device has 40 multipliers that can operate at more than 100MHz. In comparison with the DSP this gives 4000M multiplies per second. Where they Excel When sample rates grow above a few Mhz, a DSP has to work very hard to transfer the data without any loss. This is because the processor must use shared resources like memory busses, or even the processor core which can be prevented from taking interrupts for some time. An FPGA on the other hand dedicates logic for receiving the data, so can maintain high rates of I/O. A DSP is optimised for use of external memory, so a large data set can be used in the processing. FPGAs have a limited amount of internal storage so need to operate on smaller data sets. However FPGA modules with external memory can be used to eliminate this restriction. A DSP is designed to offer simple re-use of the processing units, for example a multiplier used for calculating an FIR can be re-used by another routine that calculates FFTs. This is much more difficult to achieve in an FPGA, but in general there will be more multipliers available in the FPGA. If a major context switch is required, the DSP can implement this by branching to a new part of the program. In contrast, an FPGA needs to build dedicated resources for each configuration. If the configurations are small, then several can exist in the FPGA at the same time. Larger configurations mean the FPGA needs to be reconfigured – a process which can take some time. The DSP can take a standard C program and run it. This C code can have a high level of branching and decision making – for example, the protocol stacks of communications systems. This is difficult to implement within an FPGA. Most signal processing systems start life as a block diagram of some sort. Actually translating the block diagram to the FPGA may well be simpler than converting it to C code for the DSP. Making a Choice There are a number of elements to the design of most signal processing systems, not least the expertise and background of the engineers working on the project. These all have an impact on the best choice of implementation. In addition, consider the resources available – in many cases, HERON I/O modules have FPGAs on board. Using these with a DSP processor may provide an ideal split. As a rough guideline, try answering these questions:
Some Examples Here are a few examples of signal processing blocks, along with how we would implement them:
FPGA and DSP represent two very different approaches to signal processing – each good at different things. There are many high sampling rate applications that an FPGA does easily, while the DSP could not. Equally, there are many complex software problems that the FPGA cannot address. As a result, the ideal system is often to split the work between FPGAs and DSPs. This is easily accomplished using the HERON system, and in many cases can be done simply using I/O and processor modules without any dedicated FPGA resource. |
共1条
共1条
| 2026年“我要开发板活动”第三季,开始了! | |
| PTC与NTC功能常规对比被打赏¥14元 | |
| 【分享开发笔记,赚取电动螺丝刀】关于3pin锂电池接口的介绍/使用被打赏¥16元 | |
