本文结构框架:
Creat New Project新建文档
C simulation
C systhesis
RTL级仿真
IP封装
总结
1.Creat New Project新建文档:
新建一个Project name,点next(这里选取简单的4选1数据选择器为例,主要是说明流程)
在Add Files里添加mux41.c文件,点next
添加mux41_test测试文件,点next
点Part,这里选择Board下面的Zedboard Zynq开发板,然后点OK和finish
注释:
mux41.c代码:
#include "mux41.h"
int1 mux41(int1 sig_a, int1 sig_b,int1 sig_c,int1 sig_d, int select)
if(select==0)
return sig_a;
else if(select==1)
return sig_b;
else if(select==2)
return sig_c;
else if(select==3)
return sig_d;
mux41.h代码:(头文件)
#include
mux41_tb代码:
#include
#include "mux41.h"
int main(void)
int res1 = 0;
int res2 = 0;
int res3 = 0;
int res4 = 0;
res1=mux41(1,0,0,0,0);
res2=mux41(0,1,0,0,1);
res3=mux41(0,0,1,0,2);
res4=mux41(0,0,0,1,3);
if(res1 && res2 && res3 && res4)
printf("test passed, well done!\n");
return 0;
2.C simulation:
在菜单里Project>Run C simulation,C simulation可以得到csim文件
从图中看到,可以看到test passed,well done!,证明结果是正确的:
3.C systhesis:
注意综合得到的verilog代码的可读性很差,不需要读懂,所以大多数优化都在C这个层面去做的,下面是综合后的verilog代码:
// RTL generated by Vivado(TM) HLS - High-Level Synthesis from C, C++ and SystemC
// Version: 2016.3
// Copyright (C) 1986-2016 Xilinx, Inc. All Rights Reserved.
`timescale 1 ns / 1 ps
(* CORE_GENERATION_INFO="mux41,hls_ip_2016_3,{HLS_INPUT_TYPE=c,HLS_INPUT_FLOAT=0,HLS_INPUT_FIXED=1,HLS_INPUT_PART=xc7z020clg484-
1,HLS_INPUT_CLOCK=10.000000,HLS_INPUT_ARCH=others,HLS_SYN_CLOCK=5.258000,HLS_SYN_LAT=0,HLS_SYN_TPT=none,HLS_SYN_MEM=0,HLS_SYN_DSP=0,HLS_SYN_FF=0,HLS_SYN_LUT=41}" *)
module mux41 (
ap_start,
ap_done,
ap_idle,
ap_ready,
sig_a,
sig_b,
sig_c,
sig_d,
select_r,
ap_return
parameter ap_const_lv32_0 = 32'b00000000000000000000000000000000;
parameter ap_const_lv32_1 = 32'b1;
parameter ap_const_lv32_2 = 32'b10;
input ap_start;
output ap_done;
output ap_idle;
output ap_ready;
input [0:0] sig_a;
input [0:0] sig_b;
input [0:0] sig_c;
input [0:0] sig_d;
input [31:0] select_r;
output [0:0] ap_return;
wire [0:0] tmp_fu_60_p2;
wire [0:0] tmp_1_fu_66_p2;
wire [0:0] sel_tmp1_fu_86_p2;
wire [0:0] sel_tmp2_fu_92_p2;
wire [0:0] sel_tmp_fu_78_p3;
wire [0:0] tmp_2_fu_72_p2;
wire [0:0] tmp7_fu_106_p2;
wire [0:0] sel_tmp5_fu_112_p2;
wire [0:0] p_0_fu_98_p3;
assign ap_done = ap_start;
assign ap_idle = 1'b1;
assign ap_ready = ap_start;
assign ap_return = ((sel_tmp5_fu_112_p2[0:0] === 1'b1) ? p_0_fu_98_p3 : sig_d);
assign p_0_fu_98_p3 = ((sel_tmp2_fu_92_p2[0:0] === 1'b1) ? sig_b : sel_tmp_fu_78_p3);
assign sel_tmp1_fu_86_p2 = (tmp_fu_60_p2 ^ 1'b1);
assign sel_tmp2_fu_92_p2 = (tmp_1_fu_66_p2 & sel_tmp1_fu_86_p2);
assign sel_tmp5_fu_112_p2 = (tmp7_fu_106_p2 | tmp_fu_60_p2);
assign sel_tmp_fu_78_p3 = ((tmp_fu_60_p2[0:0] === 1'b1) ? sig_a : sig_c);
assign tmp7_fu_106_p2 = (tmp_1_fu_66_p2 | tmp_2_fu_72_p2);
assign tmp_1_fu_66_p2 = ((select_r == ap_const_lv32_1) ? 1'b1 : 1'b0);
assign tmp_2_fu_72_p2 = ((select_r == ap_const_lv32_2) ? 1'b1 : 1'b0);
assign tmp_fu_60_p2 = ((select_r == ap_const_lv32_0) ? 1'b1 : 1'b0);
endmodule //mux41
4.RTL级仿真:
在菜单里Solution>RunC/RTL cosimulation,需要对Co-similation Dialog设置如下:
得到如下结果,我们会发现Verilog的Status是pass,证明C/RTL cosimulation成功:
然后我们点开波形查看窗口,此时会自动打开Vivado软件,从图中看到,mux41的功能正确:
5.IP封装:
在菜单里Solution>Export TL,设置如下:
IP封装后,会得到impl文件,其中就有我们所需要的三个子文件ip,verilog,vhdl
总结:
事实上,在整个流程中,用户先创建一个设计 C、C++ 或 SystemC 源代码,以及一个C的测试平台。随后需要用 GCC/G++或 Visual C++ 仿真器验证设计的系统行为。一旦行为设计运行良好,对应的测试台的问题全部解决,就可以通过 Vivado HLS Synthesis 运行设计,生成 RTL 设计,代码可以是 Verilog,也可以是 VHDL。有了 RTL 后,随即可以执行设计的 Verilog 或 VHDL 仿真,或使用工具的C封装器技术创建 SystemC 版本。然后可以进行System C架构级仿真,进一步根据之前创建的 C 测试平台,验证设计的架构行为和功能。设计固化后,就可以通过 Vivado 设计套件的物理实现流程来运行设计,将设计编程到器件上,在硬件中运行和/或使用 IP 封装器将设计转为可重用的 IP。随后使用 IP 集成器将 IP 集成到设计中,或在系统生成器 (System Generator) 中运行 IP。
