Given a binary tree, return the preordertraversal of its nodes' values.
For example:
Given binary tree{1,#,2,3},
1 \ 2 / 3
return[1,2,3].
Note: Recursive solution is trivial, could you do it iteratively?
方法一:非递归实现:[cpp] view plain copyclass Solution
public:
vector<int> preorderTraversal(TreeNode* root)
vector<int> res;
if (!root)
return res;
stack<TreeNode*> st;
st.push(root);
while (st.size())
TreeNode* tmp = st.top();
st.pop();
res.push_back(tmp->val);
if (tmp->right)
st.push(tmp->right);
if (tmp->left)
st.push(tmp->left);
return res;
class Solution
public:
vector<int> ans;
LRD(ans, root);
return ans;
void LRD(vector<int>&ans, TreeNode* root)
if (root==NULL)
return;
ans.push_back(root->val);
LRD(ans, root->left);
LRD(ans, root->right);
