电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » binary-tree-preorder-traversal
2018-02-01 13:24:47     打赏
Given a binary tree, return the preordertraversal of its nodes' values.
For example:
Given binary tree{1,#,2,3},
   1
     2
   3
return[1,2,3].
Note: Recursive solution is trivial, could you do it iteratively?
方法一:非递归实现:[cpp] view plain copy
  1. class Solution
  2. {
  3. public:
  4.     vector<int> preorderTraversal(TreeNode* root)
  5.     {
  6.         vector<int> res;
  7.         if (!root)
  8.         {
  9.             return res;
  10.         }
  11.
  12.         stack<TreeNode*> st;
  13.         st.push(root);
  14.
  15.         while (st.size())
  16.         {
  17.             TreeNode* tmp = st.top();
  18.             st.pop();
  19.
  20.             res.push_back(tmp->val);
  21.             if (tmp->right)
  22.             {
  23.                 st.push(tmp->right);
  24.             }
  25.             if (tmp->left)
  26.             {
  27.                 st.push(tmp->left);
  28.             }
  29.         }
  30.         return res;
  31.     }
  32. };
方法二:递归实现[cpp] view plain copy
  1. class Solution
  2. {
  3. public:
  5.     {
  6.         vector<int> ans;
  7.         LRD(ans, root);
  8.         return ans;
  9.     }
  10.
  11.     void LRD(vector<int>&ans, TreeNode* root)
  12.     {
  13.         if (root==NULL)
  14.         {
  15.             return;
  16.         }
  17.
  18.         ans.push_back(root->val);
  19.         LRD(ans, root->left);
  20.         LRD(ans, root->right);
  21.
  22.     }
  23. };
