这是关于蓝桥杯备赛路上练习的小程序,蓝桥杯的竞赛路上希望大家互相勉励。
祝大家有个好成绩。
以下代码是我利用手头上小红板(JW-51)训练的小程序。
希望大家一同进步。
#include<reg52.h> //按键1 使数码管数字+1 长按连续+1 按键2 使数码管数字-1 长按连续-1 typedef unsigned int u16; typedef unsigned char u8; unsigned char code smgduan[]={0x3f, 0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; unsigned char code smgwei[]={0xfe, 0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}; sbit rclk=P2^5; sbit srclk=P2^6; sbit ser=P2^7; sbit key0=P3^0; sbit key1=P3^1; sbit key2=P3^2; sbit key3=P3^3; u8 num; void smg_dis(); void send_595(u8 n); void delay(u16 n) { u8 i ; while (n--) for(i=0;i<125;i++); } void main() { while(1) { if(key0==0){ delay(100); if(key0==0){ num=num+1; if(num==256) num=0; } } if(key1==0){ delay(100); if(key1==0){ num=num-1; if(num==0) num=256; } } smg_dis(); } } void smg_dis() { send_595(smgwei[0]); send_595(smgduan[num/100]); rclk=0; rclk=1; delay(1); send_595(smgwei[1]); send_595(smgduan[num%100/10]); rclk=0; rclk=1; delay(1); send_595(smgwei[2]); send_595(smgduan[num%10]); rclk=0; rclk=1; delay(1); } void send_595(u8 n) { u8 i; for(i=0;i<8;i++) { if(n&0x80 ) ser=1; else ser=0; srclk=0; srclk=1; n=n<<1; } } /*课程设计自动计数器 数码管显示 一个按键每次按下使数字+1*/ /*同时LED灯闪一次,另一个按键按下后清零同时蜂鸣器响一声*/ #include<reg52.h> typedef unsigned char u8; typedef unsigned int u16; sbit ser=P2^7; //定义数码管端口 sbit srclk=P2^6; sbit rclk=P2^5; sbit key1=P3^0; //定义独立键盘端口 sbit key2=P3^1; sbit key3=P2^3; //定义蜂鸣器端口 unsigned char code smgduan[]={0x3f, 0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f, 0x77,0x7c,0x39,0x5e,0x79,0x71}; //段选数组 unsigned char code smgwei[]={0xfe, 0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}; //位选数组 void DelayMs(u16 n); //延时函数 u8 DispSmg(u8 n); //数码管显示函数 void send_595(u8 dat); //输送段选位选数据函数 void main() //主函数 { u16 n; while(1) { DispSmg(n); if(key2==0) //若key2按下 { DelayMs(100); if(key2==0) //消抖 确认key2被按下 { n=0; //n被赋值为0 key3=0; DelayMs(20); key3=1; //蜂鸣器响0.02秒后灭 } } if(key1==0) { DelayMs(100); if(key1==0) //消抖 确认key1被按下 { n++; //n每次在原来的基础上+1 P1=0xfe; DelayMs(100); P1=0xff; //发光二极管亮0.1秒后灭 } } }} void DelayMs(u16 n) { u8 i; while(n--) for(i=0;i<113;i++); } u8 DispSmg(u8 n) { send_595(smgwei[5]); //输送位码数据 提供显示位置 send_595(smgduan[n/100]); //输送段码数据 提供显示内容 rclk=0; rclk=1; //上升沿有效 说明输送数据到数码管 send_595(smgwei[6]); send_595(smgduan[n/10%10]); rclk=0; rclk=1; send_595(smgwei[7]); send_595(smgduan[n%10]); rclk=0; rclk=1; } void send_595(u8 dat) { u8 i; for(i=0;i<8;i++) //比较8次 每次提交一位数据 一共八位数据 { if(dat&0x80) ser=1; else ser=0; srclk=0; srclk=1; //上升沿有效 说明输送数据到数码管 dat=dat<<1; 被输送的数据左移一位 } }
