#include <reg52.h>
typedef unsigned char u8;
typedef unsigned int u16;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
sbit key1=P3^0;
sbit key2=P3^1;
sbit key3=P3^2;
sbit key4=P3^3;
u8 jianzhi;
u8 code smgduan[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delayms(u16 n)
u8 i;
while(n--)
for(i=0;i<113;i++);
void switch138(u8 i)//位选函数
switch(i)
case(0):
LSA=0;LSB=0;LSC=0; break;
case(1):
LSA=1;LSB=0;LSC=0; break;
case(2):
LSA=0;LSB=1;LSC=0; break;
case(3):
LSA=1;LSB=1;LSC=0; break;
case(4):
LSA=0;LSB=0;LSC=1; break;
case(5):
LSA=1;LSB=0;LSC=1; break;
case(6):
LSA=0;LSB=1;LSC=1; break;
case(7):
LSA=1;LSB=1;LSC=1; break;
void smgdisplay(u16 jianzhi)//数码管显示函数
switch138(0);
P0=smgduan[jianzhi];
delayms(300);
P0=0x00;
void keyscan()//按键扫描函数
if(key1==0)
delayms(10);
if(key1==0)
smgdisplay(1);
while(!key1);
else if(key2==0)
delayms(10);
if(key2==0)
smgdisplay(2);
while(!key2);
else if(key3==0)
delayms(10);
if(key3==0)
smgdisplay(3);
while(!key3);
else if(key4==0)
delayms(10);
if(key4==0)
smgdisplay(4);
while(!key4);
void main()
while(1)
smgdisplay(0);
keyscan();
}共2条
独立按键S4-S7,数码管分别显示键值1-4
只看楼主 1楼
| 为遥控小车巧添功能被打赏¥26元 | |
