The TCS3404 and TCS3414 digital color light sensors are designed to accurately derive the color chromaticity and illuminance (intensity) of ambient light and provide a digital output with 16-bits of resolution. The devices include an 8 × 2 array of filtered photodiodes, analog-to-digital converters, and control functions on a single monolithic CMOS integrated circuit. Of the 16 photodiodes, 4 have red filters, 4 have green filters, 4 have blue filters, and 4 have no filter (clear). With the advanced patent pending in-package trim capability, device-to-device and system-to-system tolerance can be minimized allowing very precise repeatability to be attained.
程序功能:
1,获取传感器所测颜色数据并以波形图方式显示;
2,实时显示当前传感器所测颜色数据;
3,实时显示传感器所测颜色并在界面上显示出来。
程序效果图:
共1条
利用Ginkgo USB-I2C适配器和TCS3414传感器实现一个颜色识别器
只看楼主 1楼
关键词: USB-I2C Ginkgo
共1条
| 电子价签墨水屏开发被打赏¥35元 | |
